edjunior Posted yesterday at 02:25 AM Report Share Posted yesterday at 02:25 AM I got a message today, after my Edge wouldn't remote start, that the battery in the fob was low. Yeah, so low, it wouldn't remote start. I could still unlock the door though. Got the other fob, and as I figured, it was dead also. Luckily, I had some CR-2025 batteries at the house. Of course I didn't know that each fob took two batteries. Dang. And man, getting the cover off was a test of patience. If I had to get to the emergency key for something real, I think I might have broken the thing. After it broke my fingernails!! Anyway, I finally got them apart, changed the batteries, and all is good. Now to get the second TPMS sensor replaced. It's close to oil change time, so I might just wait until that comes up, or just get the oil change done a little early, and have the TPMS done at the same time. It's all good! 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted yesterday at 04:47 AM Report Share Posted yesterday at 04:47 AM You have no idea how much I appreciate this forum and appreciate you. This community is a lifesaver. 💗 1 Quote Link to comment Share on other sites More sharing options...
Oldandintheway Posted 16 hours ago Report Share Posted 16 hours ago The Edge FOB takes CR2450 batteries. they are 24mm diameter and 5mm thick The CR2025 is 20mm diameter and 2.5mm thick. Two of those can work in a pinch, but the diameter can be an issue. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 14 hours ago Report Share Posted 14 hours ago My 2017 Sport also uses the CR2450 Quote Link to comment Share on other sites More sharing options...
edjunior Posted 14 hours ago Author Report Share Posted 14 hours ago 2 hours ago, Oldandintheway said: The Edge FOB takes CR2450 batteries. they are 24mm diameter and 5mm thick The CR2025 is 20mm diameter and 2.5mm thick. Two of those can work in a pinch, but the diameter can be an issue. Interesting. I pulled out two 2025's out of each fob. And replaced them with 2025's. One went easy, and the batteries fit right in. The other one did have a little trouble holding the top battery, but both fobs work just fine now. Maybe the 2016 used the 2025?? I don't know, but they both work now. Quote Link to comment Share on other sites More sharing options...
omar302 Posted 11 hours ago Report Share Posted 11 hours ago They are two different fob styles. 2015/2016 used the older style (with 2x 2025 batteries) while 2017+ started using the newer type with a single 2450 battery. My 2016 came with the older type and I added fob of the newer style. You can see them side by side In this post I made at the time. 2 Quote Link to comment Share on other sites More sharing options...
Oldandintheway Posted 5 hours ago Report Share Posted 5 hours ago Makes sense, thanks for clarifying Quote Link to comment Share on other sites More sharing options...
1004ron Posted 2 hours ago Report Share Posted 2 hours ago 13 hours ago, Oldandintheway said: The Edge FOB takes CR2450 batteries. they are 24mm diameter and 5mm thick The CR2025 is 20mm diameter and 2.5mm thick. Two of those can work in a pinch, but the diameter can be an issue. Just to clarify and a word of caution to anyone that may consider this suggestion in a pinch - two of the CR2025 stacked would result in a 6v battery which could fry a device designed for 3v. 1 Quote Link to comment Share on other sites More sharing options...
