Just finished changing batteries in fobs
I got a message today, after my Edge wouldn't remote start, that the battery in the fob was low.  Yeah, so low, it wouldn't remote start.  I could still unlock the door though.  Got the other fob, and as I figured, it was dead also.  Luckily, I had some CR-2025 batteries at the house.  Of course I didn't know that each fob took two batteries.  Dang.  And man, getting the cover off was a test of patience.  If I had to get to the emergency key for something real, I think I might have broken the thing.  After it broke my fingernails!!  Anyway, I finally got them apart, changed the batteries, and all is good.  Now to get the second TPMS sensor replaced.  It's close to oil change time, so I might just wait until that comes up, or just get the oil change done a little early, and have the TPMS done at the same time.  It's all good!
2 hours ago, Oldandintheway said:
The Edge FOB takes CR2450 batteries.
they are 24mm diameter and 5mm thick
The CR2025 is 20mm diameter and 2.5mm thick. Two of those can work in a pinch, but the diameter can be an issue.
Interesting.  I pulled out two 2025's out of each fob.  And replaced them with 2025's.  One went easy, and the batteries fit right in.  The other one did have a little trouble holding the top battery, but both fobs work just fine now.  Maybe the 2016 used the 2025??  I don't know, but they both work now.
Just to clarify and a word of caution to anyone that may consider this suggestion in a pinch - two of the CR2025 stacked would result in a 6v battery which could fry a device designed for 3v.
  • Like 3
Thanks! I kinda knew that but wasn’t thinking. Good catch.
Pay no attention to the man behind the curtain. 😉
