Rear Trunk Does not open automatically
Hi,
So i have been facing problem with the rear trunk for quite some time, it used to open and go up once unlocked but did not stay up and starts going down by itself, and after few month it stopped going up at all, after unlock i have to pull it up manually and keep it holding otherwise the door would come down.
I replaced the both struts, now when i lift the trunk up manually, i goes up and stays there and does not come down by itself, but the auto unlock is not happening at all and there is no sound of power liftgate or motor at all.
  • 2 months later...
On 5/13/2026 at 10:48 AM, Samurai Edge said:
I seem to recall this very subject was recently discussed in another post.  You might search this section for that and find your answer
On 5/16/2026 at 9:56 PM, enigma-2 said:
Did you check the fuses?
I need to know how to get the top left strut out from behind the trim panel
