jasoneg Posted 11 hours ago Report Share Posted 11 hours ago (edited) I have a 2008 Edge with 242,000 miles! I need to replace the front brake pads (ceramic now). I have Raybestos Element 3 pads in the rear (have about 2000miles on them). I was going to use the same on the front, but I've seen some bad reviews about them, so now I am not so sure. The brakes on this Edge have never been great in my opinion. Had the brake booster replaced (it went bad) about 7 years ago and it didn't make any difference. Looking for some more stopping power if possible. Any thoughts on Raybestos? or something else?? Maybe semi metallic? Thanks Edited 11 hours ago by jasoneg Quote Link to comment Share on other sites More sharing options...
fishx65 Posted 8 hours ago Report Share Posted 8 hours ago I've always preferred Wagner Thermoquiet pads for their quality. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 7 hours ago Report Share Posted 7 hours ago Expect you'll get an abundance of personal preferences presented - here's mine. I have Akebono on my Edge Sport and wife's BMW X5 and very happy with them, and the bonus is "no dust". https://www.akebonobrakes.com/domestic Quote Link to comment Share on other sites More sharing options...
STBEAST Posted 3 hours ago Report Share Posted 3 hours ago Ford OEM. Can't go wrong Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted 2 hours ago Report Share Posted 2 hours ago (edited) For a 2008 Ford Edge the "PowerStop Z23 Evolution Sport Brake Kits" are considered the absolute best aftermarket replacement. (heh) (Make certain you're sitting down before clicking the link to the Powerstop page.) https://share.google/evDGs27DahsrqDt07 Before I go any further, I need to point out to remember that the OEM brakes are sufficient at locking the wheels. At that point, the brakes are no longer any consideration whatsoever. Then it falls to the width of the tires and the tread depth and design as to stopping the car. Any braking before reaching total lock up is simply the amount of pressure you apply to the peddle. (I'm big on OEM parts ) Personally, I have a 2009 a Lincoln MKX which (I believe) has the same braking setup as your 2008 Edge. I went with the Motorcraft pads and rotors, and I'm completely satisfied with them. (As a sidenote, my rear pads also had plenty of life on them (approx 110k miles) but I replaced them anyways. Glad I did. So, there are a couple of items you need to consider for your 2008 Edge. First is whether you have a FWD or a RWD car. There's a slight difference in the shape of the rear pads. (Theres also a change in the caliper pin torque specs between the two.) Also, Ford instituted a rolling change on Edge brake systems during the 2008 model year. You should make a note of the month and year of the build of your car (this was a mid-year change.) Check the manufacturer's the manufacturing sticker located inside your driver's door jamb to identify your exact build month and year. This ensures the anti-rattle clips included in your Motorcraft pad kit will snap correctly into your calipers. Last consideration, if your car has a factory towing package and you tow or haul heavy loads. For OEM Motorcraft performance, best for Daily Driving (non-towing) would be the standard premium BR series. For FWD or RWD 2008 Ford Edge: FRONT PADS: BR-1258-D (fits all 2008 regardless of drivetrain layout. It includes all necessary anti-rattle replacement hardware clips.) REAR PADS: FWD: Motorcraft 7U2Z-2V200-D. REAR PADS for AWD: BR-13396. (Do not use this set on FWD as it is designed with different backing plate alignment tabs specific to All-Wheel Drive.) According to the literature, they "deliver an incredibly quiet ride, low brake dust, and long-lasting pad life without wearing down your rotors prematurely." The best pads for towing & hauling are the Motorcraft Super Duty (BRSD) Series. Again, from the literature, "these semi-metallic pads are constructed to handle intense heat, offering superior resistance to brake fade when moving down long downhill grades under load. The tradeoff, they generate darker, more visible dust on your front wheels and are more prone to occasional cold-weather squealing." (These are what I have (I also have the factory towing package.) The dust isn't bad and the braking is sufficient for daily driving. (But, then again, I don't drive aggressively.) No complaints at all. For rotors. For FWD Front Brake Rotors with 12.60-inch diameter are the Motorcraft BRRC-72. (These are interchangeable with BRR-241). For AWD, Rear Brake Rotors with solid discs, use Motorcraft BRRC-85. These are interchangeable with BRR-226). For AWD, the front are the same as the FWD. For the rear with AWD, use the Motorcraft BR-13396. These are also interchangeable with the 7U2Z-2V200-E). The main difference i believe is that these use specialized pad backing plate tabs, which are meant to anchor into AWD rear brake calipers and do not fit FWD cars. Beware of any after market kits that try to sell you 'one size fits all, as there are differences. . Edited 2 hours ago by enigma-2 Quote Link to comment Share on other sites More sharing options...
