2020 PTU and RDU Fluid?
  • 1004ron changed the title to 2020 PTU and Rear Diff Fluid?
When the "Big Wigs" @ Gm fought bankrupcy a few years ago, one of the "Bean Counters' tried to kill the Corvette line.
That was until they found out sales of Corvette parts far outstrip car sales IIRC adding$100 or more million per year PROFIT.
Thank you, I have edited the original post for clarity. Did you ever get to stay up for "Route 66"? If I could make it,
"Sea Hunt" was on after that.
The edits as far as I can tell relate to the RDU in the video, which is the type found in my 2017 Sport, but don't believe its relative to the RDU being discussed in this thread.
I changed the PTU oil this afternoon, like the RDU it was a piece of cake. If you have a stubby 3/8" ratchet it will help to get the fill plug out but it's not necessary. The oil was a light pancake syrup color and smelled just like gear oil. I put Valvoline Advanced Pure Synthetic 75w-85 in and it was lighter than what came out but not by a lot.
  • Like 3
I changed the PTU and he other week, used the Redline 75w85 GL-5.
No drain plug or cooler, so I drained it by removing the block off plate where the cooler should be.
It looked fairly clean but smelled real bad (even for gear oil).
I still need to do the RDU, have the Redline MT-LV 70W/75W GL-4 on the shelf waiting.
If you look up changing the PTU fluid by removing the PTU cooler, it looks like a royal PITA.  The same would go for removing the plate where the PTU cooler would go.
That's why I opted for going the vacuum route.  It was simply, straight forward and very little mess.
However, you choose your own method.  Have fun.
Hi , I own a Ford Edge from 2021 2.0 Eropean version , my RDU is leaking from the main(center shaft) seal in the rear. I am waiting for OEM parts from Ford Germany , but in the same I would like to add some Oil in the RDU, I left pics of the Oil I have now , is it alright if I use it just to add to it I do not now how much is left in the Unit. Is it going to harm it for another 3000 miles until i put the right SAE75W Ford Specific?
Thank you have a good day .
Welcome.
That gear oil will be suitable dependant on which type of RDU you have - take a photo and post it here.
  • 1004ron changed the title to 2020 PTU and RDU Fluid?
