Custom Search
Sign In  Log in with Facebook
Create Account
Click here to signup now
Guest Message by DevFuse
Check out the Ford Edge ST Forum Here
* * * * * 1 votes
Double Edged
2011 Ford Edge Limiited comparison High mileage Low mileage DIY
  • Please log in to reply
656 replies to this topic
#561 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • Edge Platinum Member
  • 2,728 posts
  • Region:U.S. Mississippi Valley
  • Edge's Year:2011
Posted 01 January 2017 - 09:06 AM
I decided to REUSE the PCV tube from my wife's Edge for my Edge when I change the spark plugs. This is how you can remove the old PCV and install a new PCV into the old PCV tube.
#562 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 01 January 2017 - 09:07 AM
Removing and installing a new gasket in the upper plenum on a 3.5 Duratec
#563 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 01 January 2017 - 09:08 AM
Endoscopic view of the valves, Cylinders and piston tops of a 2011 Ford Edge 3.5 duratec with 90K miles
#564 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 01 January 2017 - 09:10 AM
Had drivers side front window #3 installed yesterday.  Let's hope this one does not break.  Rather annoying to replace this one window so many times.   All stress related.
  • WWWPerfA_ZN0W likes this
#565 OFFLINE   WWWPerfA_ZN0W
WWWPerfA_ZN0W
    Ford Edge Legal Resident
  • 8,701 posts
  • Region:U.S. Northeast
  • Edge's Year:Decline
Posted 01 January 2017 - 10:30 AM
Jurassic Park
John Hammond: Don't worry, I'm not making the same mistakes again.
Dr. Ian Malcolm: No, you're making all new ones.
  • macbwt likes this
#566 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 02 January 2017 - 11:24 AM
If a way this forum is responsible for everything I needed to get started and the help and assistance I received.  Thus getting me to where the Youtube channel is today and helping many folks work on their Edge.   Thank you to everyone.
#567 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 12 January 2017 - 07:46 AM
180,000 mile tune up approaching.   I will be replacing the coils, PCV and breather tube connectors, spark plugs, Upstream and down stream O2 sensors, Intake upper plenum gasket, TB gasket and cleaning everything as I go.
So far status on the AEM air filter is approaching 80,000 miles and untouched.  This means I have never cleaned or replaced the AEM filter.   No noted affects and the Filter Minder is still at 50 percent (yellow zone)
#568 OFFLINE   fmrcaptevil
fmrcaptevil
    New Edge Member
  • Edge Member
  • 14 posts
  • Edge's Year:2013
Posted 12 January 2017 - 09:16 PM
Hi MACT,
Will this be the first set of new coils for Lullubelle?
  • macbwt likes this
#569 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 12 January 2017 - 10:28 PM
Hi MACT,
Yes this is the first set of new coils.
#570 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 13 January 2017 - 07:45 PM
New plugs installed in the Blueberry.
#571 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 20 January 2017 - 11:54 PM
Window number #3 for the drivers side.  China made one that I installed failed and cracked.  Now let's see of this USA made window does any better.  I had it installed by safelite since my insurance paid for it.
#572 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 23 January 2017 - 10:16 PM
Isn't this just sweet.   Checking out Blueberry and coolant temps and observed again some high temps on interstate of about 200 degrees.  I then compared my Edge Lullubelle and the temps of 190 degrees on the interstate.  Further comparison on my Forscanlite revealed that the CHT (cylinder Head Temp) voltage on Blueberry is running wide open at 3.50 volts at 200 degrees and Lullubelle is running 190 degrees at .61 volts.  Comparisons of other Edge's with the 3.5 revealed similar voltages of the CHT to be comparable at operating temp of .60 volts.
Thus I am quickly determining I have a failing or failed CHT sensor on Blueberry.  The sucky part is I just changed the sparkplugs and literally was half way to the job if I had known the CHT was bad I would have continued to remove the lower intake and fuel rail and just replaced the CHT at the same time.
#573 OFFLINE   omar302
omar302
    Ford Edge Addict
  • 1,848 posts
  • Region:Middle East
  • Edge's Year:2016
Posted 23 January 2017 - 10:54 PM
Mac, if the voltage is out of range, shouldn't it prompt an error code?
#574 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 24 January 2017 - 07:54 AM
Omar
 Yes it would.  I am chasing this down as it was not really an Apples to Apples comparison.  I was experimenting with another device on wifi and I may have stumbled upon an issue with the new device.  I retested this morning on both Edge's at cold start up on my OBDLINKS MX and both provided exactly the same reading.  I will test out the ELM327 wifi on my run this morning and determine if it is not working or reading data the same way.   Both voltages dropped nearly identical at cold start up this morning and all pids read nearly equal as they can with one Edge having nearly 100K miles more on it there will be minor differences.
#575 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 24 January 2017 - 07:02 PM
Continuing to monitor the CHT, seems to be there may be some human error on my part, when switching devices.  Latest drives have been reading just as they are supposed to.  Testing new devices can create all sorts of interesting readings until you learn what is going on.
#576 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 31 January 2017 - 06:43 PM
Ok Akirby if I have done this once I have done it a 1000 times over the years on all of my Edge's.  This video if for you and specifically mentioned you.   All fun.
#577 OFFLINE   lildisco
lildisco
    Ford Edge Member
  • Edge Member
  • 325 posts
  • Region:U.S. Great Lakes
  • Edge's Year:2016
Posted 31 January 2017 - 08:17 PM
You only have 1,353.7 miles & 24H & 24 minutes on trip 2 ;)
I basically do what you do macbwt, but i usually change the pump speed to the slowest setting towards the end of the 1st fill before the 1st click. I then let it rest a few more moments, maybe 15-20 seconds between clicks. Each station is different, so you have to kinda pay attention depending on where you're at.
  • WWWPerfA_ZN0W and macbwt like this
#578 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 01 February 2017 - 05:35 AM
Actually the numbers for several have rolled over.  The numbers are based on a reset from the last oil change.
11,353.7 miles
224:24 hrs
So I am currently well past the oil life monitor reset also.
I will test the oil at 250hrs and based on the testing decide to change it or go another 50 hours
#579 OFFLINE   lildisco
lildisco
    Ford Edge Member
  • Edge Member
  • 325 posts
  • Edge's Year:2016
Posted 01 February 2017 - 07:13 AM
So the hour meter resets after 100 hours? I know that the trip meter will continue to roll as I've seen some with pretty much the factory mileage, not on an edge though.
#580 OFFLINE   macbwt
macbwt
    Ford Edge Fanatic
  • 2,728 posts
  • Edge's Year:2011
Posted 02 February 2017 - 09:47 AM
The miles on the trip will roll over at 9999.9
I have not rolled the gallons, but I am sure it resets at 999.9 gallons
Also tagged with one or more of these keywords: 2011 Ford Edge, Limiited, comparison, High mileage, Low mileage, DIY
