fishx65
Everything posted by fishx65
Was wondering when local stores would finally start carrying these little round ones. These work great with the 11-14 Edge vents.
Been thinking I need to clean my throttle body but I got a nice new shiny one installed today under the recall. Mine was still functioning fine at 80,000 miles but what the heck.
I don't think I've ever had a Ford starter go bad in 34 years. I'm going with a weak battery. Seems like 4-5 years is the average lifespan of a Motorcraft battery these days. Mine lasted just over 4 in my 2011 SEL.
That's pretty normal in the salt belts of Michigan. The previous owner probably parked it in an attached garage which makes salt damage even worse.
fishx65 replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
How many miles did you end up getting out of your Yoko's? I've got about 15,000 on mine and they have been really solid with minimal wear. Could be cuz I lost my lead foot about 10 years ago when I turned 40.. -
Besides the monster gap those do look pretty good for 108. I just changed a set on the old hunt camp Jeep Liberty and was surprised it was still running on them!!!!
What mileage did you replace your 3.5's spark plugs at and how did they look?? I'm approaching 80,000 and was thinking it might be time.
Ultra HID Kit -- DDM Tuning
fishx65 replied to Cellbine's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
My 4 year old 35/5000 DDM kit is still kickin but I did have to warranty a bad ballast during the first year. Probably the best fifty bucks I've spent on her!!- 35 replies
- HID Kit
- Ultra HID Kit
Got a chance to mess with her tonight. Did the test in the video and my purge valve tested bad. Installed a new one from Autozone ($26.99 and Lifetime Warranty) and disconnected the positive battery cable for 10 minutes. So far no messages or engine light:). It takes less then 5 minutes to change out the purge valve.
Great vid on how to check for a bad purge valve:
Oops, got this throttle body recall mixed up with a valve cover baffle problem I read about which could cause oil consumption. http://www.fordedgeforum.com/topic/17714-oil-in-throttle-body/
Just found out that there's a throttle body recall on my 2011 3.5. Not sure if there's a mileage limit but I'm approaching 80,000 miles. Sounds like the malfunction can cause oil usage and I'm definitely having to add about 2 quarts between 6,000 mile changes. Anyone take theirs in for this and did you notice any excess oil consumption??
Factor, let me know what happens to yours and I'll do the same. I took a look to see where the purge valve is located and, if I'm not mistaking, it's on the drivers side sitting right on top of the motor back by the firewall. Looks like it's super easy to replace. I also stopped by the dealer to see if there was a recall for the evap system but there isn't. I did find out that there's a recall on my throttle body which sounds like they will inspect it and replace if necessary .
Tried cleaning the inlet already to no avail but I'll try it again using the method in the vid. I wonder if the warning system is setup to show the warning message for a while before throwing the engine light.
2011 SEL with 75,000 miles. Been getting the "check fuel inlet" warning for a few weeks and now the check engine light is on. It's throwing an evap code. Pretty safe to assume it's the evap purge valve??? If so, I'll just go ahead and replace it myself.
I'm gonna crawl under there in the next couple of days with a grease needle and will be sure to hit the SB bushings if possible. Other option is to strap myself underneath while someone drives me around to locate the noise.
Still Creakin.
Both links installed and she's been quiet so far . I should have ripped open the boots on the old links to see how dry they were but I pitched them.
Got the $20.00 JPN links in the mail and they look and feel like a quality part. They are very similar in design to the Moogs with the same beefy build. Only had time to install one side so far but it's a pretty easy job if ya have the right tools. My best friend is a Dremel with a cutoff disc!!!!!
Current Honda owner interested in Ford Edge
fishx65 replied to Leah Maureen's topic in Welcome Forum!
I have to agree with Omar, it's definitely worth checking out the 11-15 Lincoln MKX. I have put lots of miles on a 2011 Edge and a 2014 MKX. Prices can be pretty close between these two on the used market and I personally think the MKX is way nicer. Lincoln vehicles seem to drop in value more then others when driven off the new car lot and this is something you can really take advantage of. The Lincoln's interior materials/design, ride quality and interior noise level is what really separates it from the Edge. -
Confused about unever rear brake pad wear
fishx65 replied to wlepse's topic in Brakes, Chassis & Suspension
I recently changed the pads and rotors on my 2011 SEL at 62,000 miles. One of the outside front pads must have been frozen in it's clip since new cuz it had zero wear. -
Cheaped out and ordered a set of links on ebay for 20 bones. They look a little beefier then most and have grease fittings so maybe they're decent. http://www.ebay.com/itm/221777391501?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I've driven Fords for over 30 years and never purchased the extended warranty. Luckily I've never had any major problems and have the mechanical ability to handle most minor and some major repairs myself. The old art of do-it-yourself car maintenance and repair has pretty much died with the younger generations so I do think it's a good idea for most consumers to pick up the extended warranty these days if they plan on keeping a vehicle past 36,000 miles.
