Everything posted by 1004ron
I wouldn't trust a Lemon Law lawyers website to be an accurate reference.
- 31 replies
- oil
- consumption
(and 2 more)
After trying two sets of drilled and slotted I went back to solid rotors (high carbon) and they're still good after many thousands of miles.
Yes, and if it ran like that for a few miles the bearings will be trashed.
Engine wants to stall - Code P1450 & P144A/C - Evap Purge Valve
1004ron replied to shumax's topic in 2017-2018 Edge & MKX
@Shanejohn13 @Haz posted instructions on the second page in the link I attached - they're not as clear as the other Ford instructions Haz posts. I haven't pulled mine off yet to replace the one white clip, so will look for tips from you on how to detach and re-install.
Welcome. How sure are you that those clips will cure your issue? - where is the noise actually coming from? The clips linked above in this thread are for the plastic trim piece just behind the top edge of the windshield - since a poor job of the windshield replacement I've been driving with one of these out and don't notice any issues. You can see the location these clips are used in the below thread.
Thanks, At first Forscan only displayed only the PCM module, so time to Google and first suggestion was to downgrade to an older version which didn't work, then deleted my vehicles profile and then it took longer to load up but all modules displayed. Change made and will try it for a couple of days to see if I prefer it.
@omar302 Please tell us how to enable this using Forscan - I'm thinking of tinkering with this.
2022 Ford Edge Titanium - Auto Start System Not Working
1004ron replied to OhhBnertt's topic in 2.0L EcoBoost
Welcome @OhhBnertt Yes, it does sound like the battery is at its end of life, but before going out and buying a replacement do a load test on the battery and scan for codes - both those can be done at your local AutoZone or that type of store. If you go with a different spec battery then the vehicle needs to be coded to match, and whenever the battery is replaced the Battery Condition Monitor needs to be reset. -
Tail Light Moisture Condensation 2019-2024
1004ron replied to Wubster100's topic in 2019-Current Edge & Nautilius
Lucky in regards to not having the atmospheric/climatic conditions that would result in condensate inside the lamp assembly. My 2017 has also had condensate form a couple of times - I've not done anything to avoid it but haven't had a recurrence so not too bothered by it. -
Low Oil Pressure warning keeps coming on!!!
1004ron replied to vtchopperdude's topic in EcoBoost Mod & Tech
Welcome. What have you tried? What's the mileage? What oil change interval? What oil and oil filter used, and who does the oil changes? -
@Will2U Have you confirmed that those are in fact holes ? -
Two tanks trial on the Dorman resulted in no fault codes and no stuttering immediately after gassing up, and just for to satisfy the tinkerer in me I tried a $9 solutions which also had a flawless two tank trial. -
As with the OEM mats, only the drivers mat has stubs holding them in place - the 3D mats engage in the same posts in the floor but have a cover on the topside which looks neater than the original mat. All the 3D mats have a material on the underside that grips the floor carpet reducing the chance of them sliding around.
