dolsen
Everything posted by dolsen
Retrofit 360 Camera Into Ford Edge
dolsen replied to Wubster100's topic in Accessories & Modifications
Oooooooooo shiny -
It would be great if this was a Ford/industry standard diagram. This would be SOOOOOOOO helpful instead of hoping you find the right thing based on description 😅 -
Adding Adaptive suspension to my ST
dolsen replied to johnmarkp's topic in Brakes, Chassis & Suspension
I added an HCM to a 22 F150 and there was some programming that had to be done to it before I was able to program it. I believe it needs to be initialized to the vehicle. Don't ask me how to do that though because I didn't do it😅 -
Ooof, good luck, I am still following this project -
On the F150 forums several people added these after they were built and apparently the only thing needed is a large open parking lot as the straight lines are used for calibration. I’ll see if I can find a post/thread about it -
BOOOOO... thanks for the info though 😀 Honestly I'm a bit underwhelmed by the 93 tune from Livernois. My stock Explorer ST is still faster (or at least it still feels faster 🤷♂️)
I searched for "glare free" but I guess I didn't look far enough back in time, Thanks @Haz
Did anyone get glare free lighting to work? I loved it on my F150 and really want to activate it on my 22 ST if possible
Does anyone know if the Edge models with adaptive headlamps also have glare free lighting? With the F-150's, Canadian trucks from 22-23 were delivered to customers with this enabled. I am hoping Ford did the same with the Edge. I have s 22 ST that I would enable this on if it is possible.
Does LMS allow you to datalog for revisions/fine tuning?
Holy crap @Wubster100 , I love this thread. This, IMO, is a major oversight by Ford on the Edge, not having the 360 cams even as an option. WHEN you are successful, I will almost certainly be doing exactly this same project. I am no stranger to OEM upgrades on Ford vehicles. -
Ooooo I'm subbing, I wanna see this -
Also, here is a thread from 2018, the forum member that started the thread was a long standing member at the time with a heavily modded edge. I have not read through the entire thread though, but could be a good place to start
I believe the main thing that needs to be changed for E85 (and there could certainly be other things) is the HPFP. In the 2.7's it is in the engine compartment driven by one of the camshafts. I have linked one below, but it is listed as being used for the 2.7 in the F-150. I do not know if this is compatible, just trying to show an example https://morepowertuning.com/products/xdi-a007-27
popping comes from excess fuel in the exhaust, AKA running rich. I suppose changing timing could do that but I wouldn't rely on that as a way of forcing it because I am not sure it would work. I would think removing the cats is more likely to cause popping than removing mufflers, because the cats cannot burn off the combustion components if they are not installed. Also, you could cut the exhaust at a point that is straight for 6"+ and then use clamps to put the mufflers back on as needed
I'd have to agree with @dabangsta in that drilled/slotted isn't really the way to go. It could easily be the source of the noise, OR if you went with aggressive brake pads, those are notorious for squeaking. Frankly, unless you're racing the vehicle, hard, at a track, I would avoid drilled and/or slotted rotors altogether. Too many issues and too much wear
Software update or something?
dolsen replied to Brockdog12's topic in Audio, Backup, Navigation & SYNC
if anyone has access to PTS they can see if you got an update -
Im glad to see all this worked out for you. I used to be big on making my cars go faster, now I am at least as committed to making them stop faster too. I also like that you used that bolt to get the rotors off. It gets tiring hitting them with a sledge
It can absolutely be done, adding those features, however, it likely won't be "easy". I am not intimately familiar with how the edge is wired up, but you'll need the seats, probably some sort of driver seat module, the 8" screen and APIM, as well as all of the trim pieces required to house the 8" screen. I'm sure there's a some wire harness building involved too.
LIncoln MKX to Ford Edge Instrument Cluster Swap
dolsen replied to onyxbfly's topic in Accessories & Modifications
I think you need to wait and see if it is possible to swap a 2019+ nautilus cluster in there. If you had a 15-18, I would say for the MKX cluster- 110 replies
- 2
- digital instrument cluster swap
- digital dash swap
- (and 3 more)
Unleashed tuning charging for tune update?
dolsen replied to MrBelugaBiscuit's topic in 2.7L EcoBoost
I think post tuning support is more like "hey, my car is acting funny since I used your tune, any chance you could take a look at datalogs?" I've tuned 3 or 4 cars using unleashed with no issue, and even had one of them retuned about a year after the initial tune for no charge, but this was a case of the car acting up with the tune, not a retune for adding new parts. -
Couple FMIC questions before I pull the trigger.
This! This is the gold that people join forums for. This is an excellent reply. -
I could be wrong, but I believe the idea behind the FMIC isn't to add power, but to prevent the loss of power, which I believe you were alluding to. This helps keep the intake air cooler, and in turn allows the engine to run more advanced timing than if you keep the stock intercooler and allow IAT's to go up when pushing hard or sitting still.
