Everything posted by Cerberus
Are FRAM ULTIMATE oil filters safe to use?
Cerberus replied to 1004ron's topic in Accessories & Modifications
back when i was working on jaguars (XJ8 mostly for a while), i changed a lot of small cartridge style water pumps with plastic impellers that had shattered, and (again, in my experience) no, the plastic does not dissolve. If it did, it would not be a suitable material for an impeller in the first place. where all the fragments of impeller ended up, there is no way to know, but many vehicles had odd cooling issues after a pump went bad and grenaded. And a cast iron impeller will not fail, except perhaps by corrosion, and we've covered that angle well enough. -
2007 Ford Edge Alternator replacement & AC repair
Cerberus replied to Barbenae's topic in Interior, A.C., Heat, Interior Trim
intermittent failures are often challenging to trace down, and require as much information as possible. but just off the cuff, my first thought was the a/c clutch relay, or a loose connection at the compressor for the clutch also possible; software glitch/failure, loose ground, loose connection to a pressure sensor in the system if it were me, i'd bring it back to the guy who did the alternator and a/c service and say, i already paid you to fix this problem, which didn't start until you worked on the car, so fix it for free. but the likelihood that will turn out well is probably not great. -
to be fair, there is an obvious fluid leak stain at the output shaft, so it probably ran dry. If the fluid level is kept right, they last quite well. I know i ran with mine 'dry' or effectively empty for quite a while. like tens of thousands of miles, and yes its shot now, but i can't help but wonder if it would in this state if it had fluid in it the whole time. Bad mechanic (me), no donut. 😒
I have never seen a high side port cap that could hold back over 150PSI.. so i'm gonna have to call BS on this one. Shraders do not wear out either. Why would they? Unless they are being opened and closed (slam shut under pressure) there is no reason for a valve that is not moving ever to wear out. -
Exactly PTU suffers massive heat soak in 2.7L applications from the rear catalytic converter and turbo. Currently driving with my RDU torque coupling clutch unplugged which should equate to zero load on the PTU, but fluid temp is still well above trans fluid temp when driving around town.
One way to reduce the cruise control braking on downhill is to accelerate a bit above your cruise set point, then just coast and you'll notice less braking to bring you back down to the set number
zero disagreement from me!
cancel / resume button would make that pretty easy.
Well as an example, my 2011 fusion sport did not use brakes to slow down, it would downshift the transmission and use engine braking
not the first or likely the last time i've been wrong.. 🤣 i would bet there is a way to turn it off by adjusting a value with forscan.. but i don't know which one where. I do know there was a lot of overlap with the F150 forscan settings so that might be an avenue to research it, through those forums or obviously on the forscan site directly
if you turn off the adaptive cruise it should go to stupid cruise mode, which should not use brakes to decelerate if going above the cruise set point
https://www.ebay.com/itm/295569947003?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=MCXcvv1xTaG&sssrc=2047675&ssuid=Qivotis6TWO&widget_ver=artemis&media=COPY
logic is your friend
I have not replaced mine yet, but I got the one I have for the job off of ebay, it is a used unit harvested from a wreck or something, sticker numbers all match the unit in my ride. It took a while to find it on ebay, but it was cheap. Like less than 200. And when I pulled the fill plug, it had only the slightest film of magnetic dust sludge on it, so I'm optimistic about it's condition. Just waiting for the weather to cool off a bit before I do the job.
2.0 Eco-Boost BOV Upgrade - Possible to Add More Boost?
Cerberus replied to Coleon's topic in 2.0L EcoBoost
Engines are air pumps, so improving flow is a big part of the game. Specifically more free flowing exhaust and induction, BOV can be helpful if it is opening prematurely due to weak spring (supposedly an issue on some ) , upgraded intercooler is an option but likely delivers small return on investment as compared to a tune from Livernois. -
M-6766-B27 Ford Performance Air/Oil Separator
Cerberus replied to OmahaBob's topic in Accessories & Modifications
agreed on all! -
you may be right, but i would not want to have to battle it out in court with either a dealership or the manufacturer, whether or not the modification caused engine failure. I mean, i know a catch can won't cause an engine failure, but lawyers are expensive as heck.. -
that act only applies to who services the vehicle (maintenance or repairs) and invalidation of factory (manufacturer's) warranty. does not apply to modifications or 3rd party warranties. -
Oof. 3k sounds high.. but maybe that's just me
Cerberus replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
Mercon V & Mercon LV are entirely different specs.. or else Ford would not have created the different name.. (unless possibly just as a money grab?) So a fluid that sites both specs is automatically suspect in my book. -
Kendall Versatrans LV is specifically licensed to be in compliance with the spec my Trans requires. For whatever that is worth.. I buy it by the case of quarts, do not recall the price -
so i unplugged the electrical connector to the RDU and suddenly its silent. I'll take that as a temporary win Went for a ride for ~20 miles and noticed the PTU temperature is absolutely not any cooler than before, maintaining about a 10 degree bump above te transmission fluid temperature, which suggests that (as I suspected) the majority of the heat load that the PTU deals with is radiant from the rear catalyst, not from frictional heat. also, the 170 thermostat keeps the engine coolant (and also the average head temperature) around 15 degrees cooler without any special tune modification. Granted i was not in gridlock, but i was doing some stop and go traffic after the highway run. -
definite RDU is in self destruct mode. leave it unplugged to preserve it as long as possible. I just finally unplugged mine today and its amazing how much quieter it is. In hind sight, i wish i wrapped the loose electrical connector in silicone grease inside a bag to protect it. Next weekend perhaps.
So I went ahead and unplugged mine this morning, just to reduce the urgency of the swap. Surprising how much quieter it is now lol
