AWD Malfunction Warning After Low Tire
Wubster100 replied to w102acd's topic in All Wheel Drive (AWD)
Please see supported adapters at forscan.org. The most reliable way is to use a wired adapter with a Windows computer. Supported adapters : OBDLink EX USB, recommended USB adapter for Windows version of FORScan, also for configuration and programming functions OBDLink MX+ BT, recommended Bluetooth adapter for Lite versions of FORScan (iOS, Android) OBDLink SX/LX/MX ELS27 (STN1170/2120) ELM327-compatible (fully compatible with original ELM327, please also see important note below) J2534 Pass-Thru -
Very confusing. @tamgc2 Are you looking at an image of a vehicle with two dotted lines on each side, and those lines may be grey, yellow, red, or green?
ABS,Brake, Stability Control warning lights on
Wubster100 replied to hilokamper's topic in Brakes, Chassis & Suspension
What is your model year? Can you add it to your profile signature? -
It is impossible for active park assist on the Ford Edge to control the vehicle's speed. The operator must control the accelerator, gearshift and brakes. The vehicle will control the steering. However, vehicles equipped with Active Park Assist 2.0, such as the 2024+ Lincoln Nautilus, will prompt you to shift into neutral. Then, you must hold down the park button. Active Park Assist 2.0 is not available on the Ford Edge. The driver must use the accelerator and brake to control the vehicle's speed.
2019 Ford Edge ST (cooled) PTU fluid replacement with pictures
Wubster100 replied to boostededge's topic in Edge ST
Great write up! -
I also have a 2021. I don't know what the red X means. It used to show a software version.
- 21 replies
- software update
- power up
Yes When you mention that they will light up red on screen, is it always the same sensor? Possible causes: Could there be any object nearby, such as a stop sign pole or plant? Could the sensor be pushed in or not mounted correctly? Is the road surface uneven that could cause the parking sensors to point down at the road? The side parking sensors can be sensitive to anything nearby.
It is available in other regions, but they have the headlights without amber reflectors on the side.
This is due to load shedding. If the battery is weak, the vehicle will slowly disable features to save power. The keyless entry touch points, except for the driver's door, may get disabled to save power. One of the parking sensors could be dirty or faulty. Do you have the side sensing system? Sometimes the side parking sensors may get close to objects and beep.
Retrofit 360 Camera Into Ford Edge
Wubster100 replied to Wubster100's topic in Accessories & Modifications
Still working on my cameras. I replaced the rear camera, so I have rear 180 Split View. I think that I will order an Explorer front camera bracket to mount a front camera without having to replace the bumper. I can’t confirm if it is possible to align the cameras with the pattern and FDRS. I haven’t tried yet. The only difference on your 2019 is that you have SYNC 3. Here is a picture of a SYNC 3 Edge with the 360 camera system: -
- 11 replies
- body control module
- bcm
If you did not remove the steering wheel air bag and physically replace the switch, then do not make any changes in the SCCM. There are differences in the steering wheel switches. If you are using the default cruise control switch, then you will be stuck at the default level 3 gap setting and you may not be able to enable lane centering.
