ben senise
    11
Everything posted by ben senise
  1. one emblem for the back and one for the front? that's wild. did they mention why they do that?
  2. that's not bad. i thought it would be totally blank but i like this since it's just more discreet. i'll have to check this out. thanks
  3. what did you use to black out the ford emblem? i was thinking about doing that as well. do you have pics with a straight-on view? would be nice to see. did you do anything to the ST on the steering wheel? i'm not crazy about having tags all around a car. i don't need to tell everyone what car or engine i have. the red ST is a bit loud for my taste. i would prefer if i could remove all of them including the seat stitching. i was torn between the performance blue and black but my last two edges were black so i decided on a change but i do like the black and yours looks great.
  4. the seat heating doesn't stay on. the setting stays set to on so that when i get back to the car after stopping somewhere like a gas station the setting is on when i restart the car. not only did i de-badge the rear, i took off the front "ST" but i didn't like how that spot on the grill looked without the badge so i painted the badge gloss black and stuck it back on with 3M trim tape. i like it. it's very discreet.
  5. if they make an edge convertible, i'm in! ?
  6. ah, good to know. that supports the bad contact or loose wire theory even more. i did a super quick search and found a couple videos on youtube where a guy took apart a gen 1 edge. looked like a bit of work but certainly doable if you're comfortable with those things. be sure to come back and let everyone know how you did. good luck!
  7. i'm not at all familiar with the non-power liftgates having had power ones only but since your key fob works to open the liftgate and the button doesn't, i think it's safe to assume that the lock mechanism functions and it just isn't getting the message from the button. i don't know what happens when you press the button meaning that i don't know if it just sends a voltage somewhere or if there's more to it than that. the main point of this post is that if i were in this situation, i would try and get access to the inside of the switch and check for a loose/broken wire or bad contacts, etc. i have no idea of how to get into that back panel but there's a decent chance that you can find instructions on youtube or elsewhere. of course, that means that you would have to be comfortable with mechanical and/or electrical stuff.
  8. that's really interesting. since many here have talked about how sync 3 starts up on AM radio sometimes (often?) this makes me wonder what would happen if you removed AM radio from the list. i listen to either spotify or my USB stick 100% of the time. i never ever listen to radio, either AM or FM nor sirius. i'd love to delete these three sources. i did remove sirius from my last edge. haven't gotten around to doing it on this new edge yet. has anyone here deleted any sources?
  9. i thought this might interest a few people here. it includes the Edge. "Ford said Thursday that some some Ford F-150 pickup trucks and Edge crossover without certain electronic modules due to a twofold punch of a global semiconductor shortage and a lack of parts caused a winter storm." https://techcrunch.com/2021/03/18/ford-to-build-some-f-150-trucks-without-certain-parts-due-to-global-chip-shortage/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+Techcrunch+(TechCrunch)
  10. all the cars i owned during the 30 years i lived in europe had one single rear fog light on the driver's side. a few brands of cars had two but the vast majority had one. it has been more than 10 years since i left, so things could be different now.
  11. but don't forget that the toe opens up when the car is going forward. measuring the static value of the toe in/out won't tell you what's happening at 50 MPH. worn suspension parts could allow too much play.
  12. i just grabbed a random pic off the web since i don't have one of my car yet. i would guess that the sensor, which looks more or less like a coax cable for tv, is around 8" long. it is mounted on the top of the inside surface of the black plastic. if you reach up there with your palm facing you and then run your fingertips back and forth (don't cut yourself) you can probably find them. mine starts probably around 6" or so from the edge of the hitch and runs 8 or so inches as i mentioned above. if you're hitting the hitch, you're too close to center. that's what i was doing wrong. just move to the outside another 6-8 inches or so. once i knew where they were, i've been 100% in getting the liftgate to open. good luck.
  13. the rear foglights in europe are red and they are normally the same wattage as the brake lights if i recall correctly. don't know if the lenses and/or reflectors are made to concentrate the light. if you've ever seen a formula 1 race in the rain, they have them on and flashing. one time i politely told some d-bag that he was driving with his rear foglight on to which he replied that he liked it that way. i was so pissed off i took the crowbar from my trunk and smashed the a-hole's rear foglight 'cause i liked it that way.
  14. just out of curiosity, why would you want this? is it foggy in your area very often? if you want to use them in the rain, please don't. it's absolutely blinding to the people behind. i lived in europe for 30 years and there were tons of idiots who turned them on in the rain. caused horrendous glare.
  15. too much camber is not necessarily the cause of inside edge wear. the problem is actually toe out when driving which can happen when you have either a bad alignment or worn parts that allow the tires to go toe-out when driving. the natural tendency of wheels is to spread open at speed. you may have a static -0.6 frt/-1.1 rear but when driving it will always be greater. if this were my car, that's where i'd look.
  16. can you manually push the back hatch higher? it can be set to stop electronically at any height. just position it where you want it and then hold the button on the hatch until it beeps. that should set the height.
  17. not really answering your question but why would you want to do that? i copied all of my hundreds of CDs onto a hard disk and i put them on a USB thumb drive and i have that in my edge. if you copy to FLAC format, it's as good as CD quality. much better than mp3. you don't have to carry around loads of CDs, you can access any song by talking to Sync; "play song stairway to heaven" and it's done. i would never go back to handling CDs. just my two cents.
  18. okay, i solved the puzzle. when i was first looking, i was looking for an optical sensor which by definition needs a line of sight to "see" whatever it is that it's detecting. when i started looking for these cables, i just kept looking for something that could "see" the foot but of course, duh, an electrical field doesn't need line of sight. since plastic is invisible to an electric field, i figured that these sensors would likely be mounted on the bottom inside surface of the rear fascia. so i put my hand up there and found them. when i was kicking until now was immediately to either side of the tow hitch. now i know where to kick which is a bit farther to the outside and in the few tries that i had, it was 100% so hopefully it will work more consistently from now on. thanks @1004ron . it's great to have a sounding board to bounce ideas and questions off of. i appreciate your input.
  19. thanks for that link. it was one of the sources i found but despite looking at those pictures and lying under my car, i simply cannot see anything like that. let me check to make sure my assumptions are correct: - the second, third, and fourth pictures are of the inside of the rear bumper. - those two "cables" that kind of look like coax cables running across the bumper in photo 3 and are tied back with zip-ties in photo 2 are the sensors - each sensor on my edge is in two pieces since i have a factory hitch so they would be a short piece of that cable on each side and connected with a wire. if these above assumptions are correct, then i am stumped. i'll try and take some pictures of my setup and post them here this afternoon. thanks for your help. [edit to add:] to me it seems obvious that these sensors are not optical whereas i think the 2016 ones were. do these ones use some kind of electrical field? would one cable be a transmitter and the other a receiver, hence the need for two?
  20. i had a '16 Ti with the hands free liftgate and no trailer hitch. i used the hands free feature with no problems. when i got the car, i looked at the sensor and could see it no problem. now i've got my new '20 ST and it's really hit and miss putting my foot under the bumper. it often takes me two or three tries. so today i got down on the ground to look at the sensor to see where exactly it was, to check that it was not obstructed by mud or any other part of the car, or hadn't shifted out of position. for the life of me i cannot figure out where the sensors are! if i understand correctly there are two since the ST comes with the tow hitch. i've searched on this forum and the web for diagrams or photos. i see that whereas the sensor on my '16 was a rectangular box, this new sensor is two piece so it can be activated on either side of the hitch and they seem to be long slender pieces. armed with this knowledge i went back under the rear bumper with a good strong flashlight and i am stumped. i see nothing even closely related to the diagrams that i have found. does anyone have any photos of these sensors or can anyone describe where exactly they are? i would be extremely grateful for any help.
  21. hah! you guys are bad. i don't have that problem. my wife never complains. i've taken her on a track in a porsche and she wouldn't get out. i even lost control and spun out at 120kph, (70 mph?) and when i asked her if she was okay, she replied "THAT WAS GREAT!!!" guess i got lucky.
  22. thanks but no thanks! seems like the guy in the car behind the one recording didn't have pre-collision assist ? what is the passenger seat alarm?
  23. thanks. i went to that setting when i got the car and i put it on high to test it out. i still haven't gotten any alerts. guess i'll have to be a more aggressive driver. ?
