ben senise
    11
Everything posted by ben senise
  1. thanks, that's the kind of info i was looking for. i was tightening my nuts once and didn't have the socket on quite far enough and i distorted the outermost part. couldn't get the socket back on the nut and had to replace it. swollen nuts are a pain! ?
  2. yes, i have a breaker bar and socket. i even leave them in the edge so i don't have to deal with the stock stuff if i have to change a tire on the road. i have been using the breaker bar on wheels for years. i just thought about the impact wrench because of a fantastic deal that i found. it would just make changing wheels for the winter that much easier. thanks @akirby. that's exactly what i was wondering; how much torque is needed to loosen these lug nuts.
  3. i bought a battery electric 1/2" impact driver on sale last year. i made sure that i could return it since the torque on the lug nuts on our edges is so high. sure enough, the driver couldn't break them to loosen them so i took it back. i just saw a great price on what looks to me to be a pretty beefy impact driver. the description states "Up to 700 ft-lbs of max torque and 1200 ft-lbs of max breakaway torque." does anyone here use an electric impact driver that can loosen these lug nuts? if so, what is its breakaway torque? i'm just wondering how much i would need to get the lug nuts off. thanks
  4. thanks. i'll try swapping it out with another one and see what happens.
  5. 2016 Edge with Sync v3.0 build 18093 Up until recently, Sync would occasionally lose the USB drive. What I mean by that is that the USB drive does not show up in "sources." The usual AM, FM, Sirius, and even my phone show up but I have to unplug and re-plug the USB stick in order to get it to show up on the screen. Has anyone else come across this and is there a fix? I've got one of those really short USB sticks in there and it's a pain to get to. I didn't find any old threads on this. I guess I'll try a factory reset but wanted to check here first since i haven't had much luck with factory resets in the past. thanks
  6. i've seen pics of the stock grill sprayed with matte black Plasti Dip or similar. not too much of an investment and if you don't like the results, just peel it off.
  7. ^^^ exactly this. ford is a MASSIVE global company. they don't listen to their customers. if you don't like what you see, buy something else. the way things are today, i won't be replacing my 2nd edge with a 3rd. vote with your wallet.
  8. i usually get about two years out of mine. winters here on the left coast are fairly mild by canadian standards. car is garaged and rarely left parked in the sun. car has 40,000 km in just over three years.
  9. thanks for the info. i was just thinking that i'll probably put on a new set before winter.
  10. in my experience, the greatest factor in snow performance is the choice of tires. i remember people complaining that their BMW X5 sucked in the snow and i found out that they were using summer tires. four-wheel drive or not, summer tires do not work in the snow. neither do all-season tires. what kind of tires did you have on the fusion? if they weren't winter tires then that is why the car was horrendous. i have a 2016 edge Ti AWD 3.5 with michelin latitude x-ice and the car performs fantastically in the snow. we had a very big dump of snow last winter and the small roads don't get plowed. there was a good 20 cm of snow on the road and i just cruised right through it on curvy roads and hills. no problem at all. of course one has to adapt their driving to the conditions.
  11. although i like the new ones, if you offered to give me either set, i would take the '16 ones. i really like those ones. let me know if you want to get rid of them
  12. looks gorgeous. hope you enjoy it for many years to come.
  13. are you saying that the climate control was not functioning or just that you didn't see it displayed on the panel? i have noticed that when remote starting the car, the various indicators like seat heating and AC don't light up but the seats are warm or the AC is working. it's bizarre and i've wondered why this is so but it is what it is.
  14. the ford.ca (i'm in canada) website lists the following sizes for the SEL, SE, Titanium, and ST respectively: 245 60/18 245 55/19 245 50/20 265 40/21 as you can see, there are four different wheel diameters available. They all have a tire diameter of 29.6" except for the ST which has a diameter of 29.3" the car's dynamics are very much affected by wheel diameter, offset, and tire width. braking for example is much less effective with a larger diameter tire. simple physics and geometry. ABS, traction, stability are all affected by geometry that is different than stock. it may be true that the internal parameters in the system may have different settings but for the purpose of the OP's question, he does not need to change anything for the new tires if he got tires that are a standard factory size.
  15. the whole idea of larger wheels is that the tire has a shorter sidewall and conversely, the smaller wheels have tires with taller sidewalls. the overall diameter, and thus the circumference, is the same on all edges from the factory no matter what the wheel size is. go to https://tiresize.com/calculator/ and plug the old and the new tire/wheel sizes into the tire comparison tab. that will give you the circumference which should be the same. if it's the same then the wheel will rotate the same number of times in a given distance and your odometer and speedometer will be correct.
  16. looks great claude. congratulations. wasn't such a long wait after all
  17. i have arlo cameras. you can set up the hub and/or your phone to make an alarm when the cameras detect motion. you can also set up zone on the camera so it only activates when people step onto your property but not walking by on the sidewalk. plus it's free to record and it's stored for 7 days.
  18. ah, i assumed that you meant lock for both cases. so you're saying that it double honks when you unlock it? it isn't even supposed to honk at all with a single tap to lock it. just out of curiosity, i went to my garage and opened the hood of my edge. i clicked on lock and no honk. i unlocked and no honk. so i doubt it's that. i have had cars in the past that used the honk when locking to indicate a fault with the alarm system. i'm wondering if that's the same with the edge.
  19. i assume you mean "locking" the car rather than unlocking as you have written. from the user manual: Mislock If any door or the luggage compartment is open, or if the hood is open on vehicles with an anti-theft alarm or remote start, the horn sounds twice and the direction indicators do not flash. You can switch this feature on or off in the information display. have you checked the hood and hatch?
  20. all sound systems are amplified. otherwise you wouldn't get any sound. the question is how much i.e. how many watts.
  21. i stopped by a ford dealer in barcelona a few years ago to check out the euro-edge. i liked many of the features like fog lights and the stainless strip across the sill under the back lift gate. ours are cheapo plastic. i also liked the placement of the LED "signature lights" around the headlamp assembly much better than down on the bumper that we have here. be sure to post some pics when you get it. i'd also like to know what reaction you get when driving it. i think it's still pretty rare in europe, no?
  22. i never tried disconnecting the battery. i just let the dealer deal with it.
