Mileage on OE brake pads and Tires
  • 2 months later...
We now have around 40k miles on our 2011 Edge and the tires are going to have to be replaced within 10k miles, probably more like 5k. I'm not replacing with the same brand as OEM. The brakes...I'm not sure about their life per se, but I have a bit of a pulsation and I'm not sure if it's the brakes or the tires. Probably the tires since I can sense it even when not applying the brakes, but the effect is exaggerated when braking. It could be a warped rotor that, when rotating at speed, is affecting the balance of the wheel.
  • 2 months later...
