Heated mirrors not working
Maybe they are working, only not warm enough for the freezing your getting. When there is no ice on them, feel them for heat after a while from turning the rear defrost on. An infrared thermometer would come handy to check. Do the mirrors have the heated mirror symbols on them?
I may be off base as I only have the schematic and manuals for 2009, 2010, but I believe it would be similar in yours.
Power comes from fuse #45 in the Battery Junction Box (BJB). It powers the heated mirror relay. As your rear window is heating ok, we can assume this fuse is good.
The power through the relay is controlled from fuse #28 in the Battery Junction Box (commonly called the fuse box in the engine compartment).
-Start by checking fuse #28 (refer to your owners manual to make certain that this is still the correct fuse).
-If it's ok (verify by replacing with an identical fuse known to be good) then it really comes down to the relay or wiring. I would guess the relay before the wiring, unless your or someone else has messed with the wiring. (In my 09 MKX, the relay is #29 in the BJB.)
  • 8 years later...
Ford Battery Reset …..
Firstly get in the car and close all the doors, but don’t lock them
Turn on the ignition, but don't start the engine.
Wait for battery light to come on.
Flash main beam 5 times
Then press and release brake pedal 3 times.
The Battery light should flash after 10 seconds.
The system is now reset
Heated mirrors and screen should now work
