Diagnostic Dad Posted March 18, 2022 Report Share Posted March 18, 2022 We have a 2011 Ford Edge Limited which my daughter acquired in the fall to use at a college. At school she rarely uses it. After a couple months she started getting symptoms of a dying battery. She started getting "battery saver" messages on the display. After couple more weeks it would not start without a jump. We figured it was just an old battery so we had her get a new battery. They did a test of the charging system and said there were no problems. A couple of months later the new battery was dead. When she came home I did some in-depth diagnostic testing. I put a multi-meter in line with the battery to monitor the current draw. Once the vehicle is "sleeping" I've monitored the current draw. The normal steady-state is about 17 milliamps. The problem comes every 15 minutes. The current draw suddenly spikes up to 2 amps, stays there for around 10 seconds, then slowly drops down to 1 amp over another 20 second before finally plunging back to the idle current of 17 mA. Note that the frequency is a bit faster when the vehicle first goes to sleep. Initially the frequency is every 5 minutes. It takes about a half hour before it goes to the 15 minute interval, but it then stays at that interval for a long time. To try to find the problem I started pulling fuses one at a time and seeing if the cycle continues. I tried all of the "small" fuses in the engine compartment fuse box first with no impact. I then moved on to the interior fuse panel. The most significant change happened with fuse 6. Fuse 6 is listed as "RF module". As soon as I pull that fuse the 15-minute high current draw stops. I figured that this circuit is probably for the remote keyless entry system. Sure enough, with that fuse unplugged the remote doesn't work at all. I was thinking she could live with using a key to get in, but it also makes the Start button not work. In fact, when you hit the button the car thinks it is being stolen and the alarm starts going off. Anyway, more research pointed me at TSB 13-6-18. This specifically deals with a current draw due to the remote system keeping the electronics awake. I took it to the dealer and they confirmed we had old software and updated the VMCU to version 2.2.14 at a cost of $140. When we got home I put my multimeter on again, waited the car to go to sleep and then watched what happened. No change. Every 15 minutes it's still drawing 2 amps. I'm open to suggestions on next steps in tracking this down as long as it doesn't involve leaving the car with the dealer with a blank check. Thanks 2 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 19, 2022 Report Share Posted March 19, 2022 you may actually need to replace the module, they do fail from time to time. usually it is the RKE module not the antennas at fault. every time a new battery is installed the battery management system has to be reset so it can recognize the new battery and charge it appropriately. Quote Link to comment Share on other sites More sharing options...
Diagnostic Dad Posted March 20, 2022 Author Report Share Posted March 20, 2022 Many thanks for the feedback. I found this page describing the parts to some degree: https://www.quirkparts.com/v-2011-ford-edge--sel--3-5l-v6-gas/electrical--keyless-entry-components In the section near the bottom there are two modules listed, but one is discontinued. The first module is listed as a "control module" BB5Z-15k602-N, and the description just makes it sound like a radio receiver. The second module is just called "module" BT4Z-19G481-F and no description of function is given. Would you happen to know which is the "RKE" module? If it is the second one is there a replacement part? I hadn't realized about the BMS reset. The videos I've found all show a car with a key and not push-button ignition. I'll keep searching for for a video showing this configuration. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 2, 2022 Report Share Posted April 2, 2022 Do you have an aftermarket remote system? Any electrical modifications done? Any repairs? Quote Link to comment Share on other sites More sharing options...
Diagnostic Dad Posted April 2, 2022 Author Report Share Posted April 2, 2022 No modifications or repairs. We also don't keep anything like phone chargers plugged in. I'd say it is completely original. I'm going to work on on tracking down the modules so I can replace them on her next visit home from school. Quote Link to comment Share on other sites More sharing options...
Machman64 Posted July 7, 2022 Report Share Posted July 7, 2022 Hey diagnostic dad, I am having the same exact problem on my wife's 2011 edge. It pulls 2.06 amps sporadically, sometimes it's a few minutes and sometimes its five to ten minutes. It stoos when I pull the rf module fuse. Did you ever figure out what the problem was? Quote Link to comment Share on other sites More sharing options...
Diagnostic Dad Posted July 7, 2022 Author Report Share Posted July 7, 2022 Hi Machman64. No, we never found a solution. We tried replacing the RF module with a new one and it didn't help. I'm limited on the time I can work on it because my daughter normally has the vehicle at college. I did end up finding that the RF module seems to be triggering the current draw, but it isn't the circuit actually drawing the current. In other words, it seems like when the RF module wakes up, it wakes up other systems in the car which cause the current draw. I've done a bunch more research on it and the module seems to handle both the remote keyless entry as well as the tire pressure monitoring system. I'm wondering of something with that is causing the waking-up, but I still don't know how to actually fix the problem. Lastly, I ended up getting Forscan with an OBD2 connected in hopes that I'd find something there, but no luck. When the vehicle goes to see the OBD interface also goes dead, so I can't see what is happening when the vehicle is supposed to be sleeping. My current plan for a workaround hack is to put a physical switch in-line with the circuits that draw current and leave the RF module active. That should allow the remote entry to continue to work and once in the car she can flip the switch before starting the car. Hopefully someone will post a solution eventually. Quote Link to comment Share on other sites More sharing options...
Machman64 Posted July 8, 2022 Report Share Posted July 8, 2022 Thank you for your response. My next step was going to be to change out the rf module. But it sounds like that's a waste of time. I will keep working on it and if I figure it out I will let you know. Quote Link to comment Share on other sites More sharing options...
Haz Posted July 8, 2022 Report Share Posted July 8, 2022 Below is a PDF download link to a job aid on parasitic current draw analysis... Parasitic Battery Drain Job Aid.pdf Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Diagnostic Dad Posted April 14, 2023 Author Report Share Posted April 14, 2023 Slight update. Still no resolution to the problem. We have a workaround in place now where I put a switch in-line with the RF module. We use the physical key to unlock the door then flip the switch to make the key fob work for starting the Edge. When parking for the night (or longer) we lock the doors by hand and turn off the switch to stop the drain. On a possibly related note, we kept getting the battery saver message even after a long trip when the battery should be fully charged. We replaced both of the current sensors near the battery and it seems to have resolved that problem. The radio will keep playing after turning the car off now. Unfortunately there was no impact on the parasitic drawl. In doing research it seems like this is not an uncommon problem. I would have hoped someone would have identified the root cause. I wouldn't mind replacing a module or two if it fixed the problem. 1 Quote Link to comment Share on other sites More sharing options...
Cerberus Posted April 15, 2023 Report Share Posted April 15, 2023 3 hours ago, Diagnostic Dad said: Slight update. Still no resolution to the problem. We have a workaround in place now where I put a switch in-line with the RF module. We use the physical key to unlock the door then flip the switch to make the key fob work for starting the Edge. When parking for the night (or longer) we lock the doors by hand and turn off the switch to stop the drain. On a possibly related note, we kept getting the battery saver message even after a long trip when the battery should be fully charged. We replaced both of the current sensors near the battery and it seems to have resolved that problem. The radio will keep playing after turning the car off now. Unfortunately there was no impact on the parasitic drawl. In doing research it seems like this is not an uncommon problem. I would have hoped someone would have identified the root cause. I wouldn't mind replacing a module or two if it fixed the problem. while this would not locate or resolve the cause of the problem, this idea may work as a solution to the battery going dead.. have you considered a solar panel on the dash board to charge the battery while the car is parked & counteract the parasitic draw? Quote Link to comment Share on other sites More sharing options...
ylwpaul Posted June 30, 2025 Report Share Posted June 30, 2025 (edited) Hello Diagnostic Dad, I have a 2011 Edge that has been displaying the same behaviour as what you’ve written about. I get a parasitic draw of 2.2A every 90secs for about 10-15secs. At first I disconnected the instrument cluster because I heard a relay or something making a sound, a tick when the draw started and then a double click sort of noise when the draw ended. But I think that was just a symptom. I also disconnected the APIM and noted that the 2.2A draw dropped to around 450mA but again I think that was just a symptom. Now I believe that the RF module is waking up for some reason which in turn wakes up the instrument cluster and APIM. So the problem I think is the RF Module. I’m wondering where and how you installed your switch? Did you install your switch on the RF Module power supply? Thanks Update: I have now tracked the problem to the TPMS module which also monitors the keyless entry fobs. I still don’t know what is waking up the module, whether it’s an internal problem or still something external. I do know that if it is off then the car goes to sleep and the current draw drops to 16mA. I’ve put a switch on the supply voltage to the module so I can turn off the module when the car is going to be parked for more than a day. I will get a replacement module to see if the problem will stop. Stay tuned. Another update: I received the TPMS/RF module today and installed it. Unfortunately the problem was not resolved. The car still “wakes up” about every 90 secs and draws 2.2A for about 15 secs. ☹️ I will continue to use the switch I installed to switch off the module and keep the battery draw at around 15mA. Whatever is causing the module to wake up must be external to the module. Maybe a signal on the MSbus? Edited July 29, 2025 by ylwpaul Update 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 30, 2025 Report Share Posted June 30, 2025 One easy (if not drawn out) method is to hook a ammeter across the battery positive lead and wait until the draw begins. Then start to withdrawal fuses, at the power fuse box in the engine compartment, one at a time. If the draw stops, you may have found the circuit (you'll need to wait until the next parasitic draw begins in 90 seconds to see if drawing out that particular fuse stops the drawl. These can be wierd. I remember one draw was found at a rear wiper. The gears had broken and not allowed the wiper blade to park. Every few minutes the wiper module turnd on to check if all of the wipers are parked. When checking the rear wiper, it found it wasn't parked and attempted for 15 seconds, to park it. Then parked or not, its programmed to stop and begin a timed wait cycle again. 15 seconds, hour after hour, the draw added up (after a few days.) Quote Link to comment Share on other sites More sharing options...
2016 Edge Titanium AWD Posted July 6, 2025 Report Share Posted July 6, 2025 Good morning All, Add our 2016 Edge Titanium to the group of vehicles experiencing parasitic draw when the vehicle should be asleep. To put context around this, I now believe this has been a hidden 'ghost' issue since we bought the vehicle in June 2019 at 44,000 Kms. Whatever killed the battery actually brought it well below 11 volts over a 4 hour period sitting in the driveway two days ago. The windows were part way down to allow heat dissipation in the cabin, there were no lights on or doors / hatch open and one would think that the vehicle should be asleep. We were going to go out for an early dinner, and the message on the Sync screen said it had shutdown all unnecessary modules to preserve battery power. The vehicle would not start and putting a Fluke voltmeter across the battery terminals gave a measurement of 3.56 volts. I mean really? 3.56 volts? I attempted to put my electronic battery charger on the battery set to 2 amps, but it kept kicking off because the draw on the battery from whatever was drawing power was much greater than the charger could handle at 2 amps. Didn't try boosting with another vehicle. I noticed that there was this clicking sound coming from the AC compressor clutch when the electronic charger was first activated, and the symptom would cycle on and off with the compressor clutch clicking on and off every 15 seconds. NOTE: This is the second CarQuest DieHard battery the vehicle has had since we bought the vehicle used in 2019. CarQuest was closed so we bought a new Kirkland battery at Costco and installed that in the vehicle so I could at least get the windows up and lock the vehicle. Meanwhile the DieHard battery, immediately taken from the vehicle, slowly recovered to 12.6 volts over night without any help, so I don't think the battery was the root cause. I checked the standby voltage of the new Kirkland battery at 12.27 volts fresh off the shelf, which is a normal reading (with a build date of 11/24 BTW) and proceeded to install it. You can install the battery positive first and then attach the negative cable, but it is easier to connect the negative first, slide the battery back into place and then attach the positive cable. Well, I wasn't particularly expecting a significant spark when I attached the positive cable to the battery, but there it was. And the compressor clutch clicked on the moment the battery was reattached. OK, now the charging system has a reliable power source and the engine will start and run. I haven't done the battery reset function yet, but I read somewhere that just sitting for 8 hours the battery monitor will reset to the new battery. I may be misinformed. I think there are at least 4 different recommended procedures on YouTube to reset the battery monitor. So then I went into diagnostic mode trying to figure out what was drawing the power (still had no idea how much of a drain it was), but perhaps my 30 year old $300 Fluke meter can help me do that. I've noticed that remote entry may be misbehaving from time to time, for example the vehicle self locks on me at the gas station while I pump gas. In this scenario, the only way to unlock the driver's door (normally by touching the handle) is to open the rear passenger door first. Rolling my eyes! Refocusing on the parasitic draw issue, I noticed that if I leave the AC button on when the vehicle is shut down and parked, there is 'something' drawing power because the voltage will drop from 12.6 volts standby to as low as 12.11 volts over an 8 hour period. However, if I turn the AC off before I shut the vehicle down, standby voltage stays around 12.6 volts. And Oddly, I have two batteries I can monitor as my 'benchmark' for standby voltage, - the recently replaced DieHard that sits at 12.6 volts on the garage floor and the heavy duty 10 year old 12 volt battery in my 1978 Tbird that also registers 12.6 volts while disconnected. I could now pull the fuse on the AC compressor clutch (now that I know where it is), to see if that reduces the parasitic draw, because obviously there is something drawing power when the vehicle should be asleep. BTW, the vehicle has been sitting locked up since 8:30 last night and as of this posting it is 13 hours in sleep / standby. The AC was shut off last night before shutting the vehicle down and locking it, so I'll see what standby voltage is now and report back. I was going to replace the AC clutch relay thinking that possibly it was sticking on when the vehicle was parked but now, after reading through the original poster's story, I think this is more of a symptom than a root cause. Summary: Vehicle Mileage: 101,750 Kms or about 63,240 miles I think that whatever killed the original factory battery 3.5 years into its life may well have been the result of some 'ghost' parasitic draw from some module in the vehicle. This 'ghost' also killed the first DieHard battery two years after it was installed (and it probably didn't need replacement), and then this parasitic draw attempted to kill a second DieHard making me believe this is not a faulty battery issue at all. It would be great if a simple software update would fix this, but I am doubtful. Thoughts anyone? Quote Link to comment Share on other sites More sharing options...
2016 Edge Titanium AWD Posted July 6, 2025 Report Share Posted July 6, 2025 (edited) Opening the vehicle to release the hood latch partially woke the vehicle up, and first measurement of standby voltage was 12.38 volts. However, as the vehicle went back to sleep, the standby voltage rose to about 12.45 volts and climbing. Hood is open now, so I'll check again in about a half hour. Update: 12.56 volts standby Cracked the rear windows open and put the sun shade on the windshield; - a tad warm here in Niagara Falls Ontario today - 31C with the Humidex: 38C 🥵 Edited July 6, 2025 by 2016 Edge Titanium AWD Quote Link to comment Share on other sites More sharing options...
gonesail Posted July 6, 2025 Report Share Posted July 6, 2025 a fully charged 12v battery at rest is around 12.6 or 12.8 volts. but i have learned that these vehicles all have some level of parasitic draw. even staying alive waiting for you to unlock the doors takes something. but taking a battery down to 3.56 volts will definitely shorten battery life. i always turn the AC and wipers off before shutting the car down but that's just me. 1 Quote Link to comment Share on other sites More sharing options...
2016 Edge Titanium AWD Posted July 6, 2025 Report Share Posted July 6, 2025 One final note while many of the folks on the forum wait for a solution that works to be posted. After installing the new replacement battery, my wife took the vehicle shopping the next morning. I had turned the AC off the night before and reminded her that it would likely still be off when she started the vehicle. It was off, but she insisted that before she turned it on the re-circulate light was on even though the AC was off. Of course it automatically turns on the re-circulate when the AC comes on to help cool the cabin down. Went out later and tried to duplicate the scenario where the AC is off but the re-circulate comes on anyway. I wasn't able to duplicate it but something completely unrelated happened while I was doing my checks. The engine check light came on, and so I shut the engine off, and tried to see if it was an intermittent fault be restarting the vehicle several times. No dice. Figuring that the most likely sensor to trigger the ECL was EVAP, I shut the engine off, took a rag with some mineral spirits and wiped the inside of the 'fast fill' cap where the inner flap touches the inside of the filler neck. Let it dry for 5 minutes, re-started the vehicle and the ECL was now out. OK, I'll take that as a win! Which all leads me to wonder if every root cause of parasitic draw may be different based on what module is misbehaving. In one case it may be the RF module, or perhaps the HVAC module or even both at once (I believe there is even a trailer towing module) which further leads me to believe based on how many modules make up the complete vehicle, any combination of them could cause parasitic draw individually or in combination. Need to get back to basics I think. My '78 Tbird only has a fuse panel with 8 or 10 fuses, and pressing the trunk release when the AC compressor kicks in will blow the fuse because they are both on the same circuit. Go figure! Cheers, Everyone Quote Link to comment Share on other sites More sharing options...
clunk Posted August 30, 2025 Report Share Posted August 30, 2025 I have the same issue as above on a 2012 EDGE SL, 4-5 days of non-use and the battery is dead. I just went ahead an installed a toggle switch to kill the voltage (from fuse 6) to the RF module when parked unused for several days, why risk 100$ just to see if maybe a new module may/may not fix the problem. I'm glad I found this thread! Quote Link to comment Share on other sites More sharing options...
clunk Posted August 30, 2025 Report Share Posted August 30, 2025 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 30, 2025 Report Share Posted August 30, 2025 Consider obtaining a copy of TSB 13-6-18. This specifically deals with a current draw due to the remote system keeping the electronics awake. Sometimes it just requires a software reload/update. As you have isolated the problem to the RF module, there's three possibilities. The module, wiring becoming grounded and a faulty RF hub. Most likely cause is the module has failed. (Shorted wiring would cause the battery to drain much faster & network issues would probably affect several other devices.) I've read in another forum where it was traced to water entry getting into the module. Caused it to stay on. Quote Link to comment Share on other sites More sharing options...
Bob Rock Posted September 4, 2025 Report Share Posted September 4, 2025 I have experienced the Parasitic Battery Drain on my 2011 Ford Edge SEL and the fix was unbelievably simple. I experience very odd behavior with my SYNC software, such as filling the tank but didn't show full, getting an incoming phone call that did not match my uploaded address book (for example, my wife would call me, but the SYNC display showed some other contact that wasn't even close.) Same for outgoing calls, I would select the number from my iPhone contact list and when it dialed, a different name was shown on the SYNC display. Then I started having the dead battery symptoms, car not starting (just clicking sound), when I KNOW the battery was totally charged. Sometimes too I would get a weird flashing of the SYNC screen. I tried updating the software, but then I would get a message "You already have the latest software...". The solution? I simply did a Master Reset which resets everything to factory defaults. You lose all your Bluetooth devices, etc, but easy enough to link again. It's been 2 weeks now and not a single issue! So, before you start changing fuses, relays, etc, just try this simple Master Reset. It might work for you too. 1 Quote Link to comment Share on other sites More sharing options...
ylwpaul Posted September 5, 2025 Report Share Posted September 5, 2025 (edited) On 8/30/2025 at 6:33 AM, clunk said: I have the same issue as above on a 2012 EDGE SL, 4-5 days of non-use and the battery is dead. I just went ahead an installed a toggle switch to kill the voltage (from fuse 6) to the RF module when parked unused for several days, why risk 100$ just to see if maybe a new module may/may not fix the problem. I'm glad I found this thread! Using a switch to toggle the power to the TPMS/RF Module is a solution that works. I think there must be something on the MS CAN-Bus that wakes up the module. I replaced the module and the issue persisted. There is a watchdog timer that cycles the system every 90 seconds to prevent the car going into deep sleep. The 2011 Ford Edge uses a watchdog timer to prevent the vehicle's systems from becoming unresponsive. It periodically resets itself, waking up the MS-CAN bus every 90 seconds. This ensures proper communication between modules and prevents the system from entering a deep sleep loop mode that could cause issues. Here's a more detailed explanation: Watchdog Timer: The watchdog timer is a safety mechanism that resets the vehicle's systems if they become unresponsive. It's like a built-in "are you still there?" check. MS-CAN Bus: The MS-CAN (Medium Speed Controller Area Network) bus is a communication network within the vehicle that allows different electronic modules to talk to each other. 90-Second Cycle: The watchdog timer on the 2011 Ford Edge is configured to reset every 90 seconds. This means that the MS-CAN bus is briefly interrupted and then restored. Preventing Deep Sleep: This periodic reset is crucial for preventing the vehicle from entering deep sleep mode. Deep sleep can occur if the vehicle is inactive for an extended period (e.g., 14 days) or if the battery voltage drops too low. Deep sleep mode conserves battery power but can also cause issues when the vehicle is restarted. Edited September 8, 2025 by ylwpaul Quote Link to comment Share on other sites More sharing options...
