Whine/Roar when AWD is engaged
Pikuoff
Rear diff is toast.  The shop said all the sound was in from diff and coupler that's all one unit.  It had lots of metal in the fluid.  I tried to get most out with my pump but I guess that's why not much came out b/c my tube was pretty thin.  About a $3k replacement.  Probably not too surprising since it was never serviced for 170k miles.  Now I know...
Sorry to hear that you have a large repair bill.
My thoughts are that the RDU shouldn't suffer without maintenance at 170K miles.
Oof.
3k sounds high.. but maybe that's just me
  • 1 year later...
Thanks to all who contributed to this thread.  I started getting the whine noise a few weeks ago.  I stumbled into the PTU issue, and replaced the fluid in that.  Still, the sound remained, but would stop when I would get to around 40 mph.  I NEVER thought of looking at the Intelligent AWD display to troubleshoot.  As Pikuoff reported, I could track the sound to whenever power was sent to the rear wheels.  The fluid change of the rear diff didn't help.  Next step is to inspect the driveshaft center support bearing.
Until I get my GoPro set up to film under the car, I had a follow-up question.  Does the driveshaft always turn, or it is controlled by the PTU?  And if so, is it safe to assume that the rear diff isn't engaged until it receives a signal to engage?   (If it always spins, then if the center support bearing was bad, it would reason that the noise would always be present.)
Thanks!
Thanks!
Disregard!
Edited by Cerberus
I was wrong
  • Confused 1
4 hours ago, Cerberus said:
99% sure the driveshaft always turns regardless of year, but is only under load/ driven when the clutch is pulled in, in the RDU (diff plus clutch assy on the input side)
In other words, the driveshaft spins but the power is not delivered to the diff until the clutch ramps in.
As mentioned, it depends on the year. 2019+ has a disconnect in the PTU.
Disregard!
Yes but even if the PTU disconnect is disconnected,  the rear wheels are still rolling down the road, and driving the driveshaft. Unless there is a disconnect at both ends of the driveshaft?
I didn't think they did that..
Edited by Cerberus
I was wrong
  • Confused 1
All model years have RDU with clutches. So when the clutches are disengaged it effectively "disconnects" the rear differential from the driveshaft.
Pre 2019, the driveshaft will still turn because it is connected to the PTU/Transmission/Engine, while the rear differential will turn based on the speeds of the rear wheels.
2019+ models, the driveshaft stops rotating when the PTU disconnects. As can be seen in this video:
i don't have the patience to watch that video.
one second in, and i'm out.
I'll just trust you, apparently i'm wrong
mark the date .. lol
Edited by Cerberus
@GoshenTop as can be seen, it's valuable to have your Model/Year in your profile signature - Settings - Ford Edge Forum
@Cerberus no need to beat yourself up over this - I only learnt about this AWD setup on the later models just the other day.
MACT's videos are actually quite good, just need to fast forward past the intro which can be a little drawn-out on some of his videos.
  • Thanks 1
Looks like I might have gotten lucky (I might regret typing that).  On a whim, as a last ditch try, I sprayed the center alignment bearing with some silicone lubricant.  As of today (2 days now), no noise.  Even when seeing the Intelligent AWD indicate power sent to the rear wheels.  That leads me to wanting to change out the bearing.  My question to the group, what is the recommended approach to moving the exhaust out of the way?  I'm seeing that I can disconnect before the catalytic converter.  Hoping I can just lower it down enough to move it out of the way.  It's looking like the drive shaft bolts are T-45.  I've watched a few videos highlighting how to sperate the driveshaft.  Hoping mine isn't too stuck.
