omar302 Posted February 21 Report Share Posted February 21 @1004ron I did not have the vibration/shimmy at acceleration, but a bad clunk. But based on your findings with the wear found on the axles, and as I had no other explanation for the clunking I got. Also the fact that the axle part numbers were superceded several times (at least 5), I went ahead and replaced the left side, OEM. The clunking is finally fixed, at least about 80% of it. Also the Edge felt smoother. So I replaced the right side too. Even better. Opening the inner bearings on both axles revealed similar wear. Both sides also had the grease come out in liquid form. Left side: Right side: 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 21 Author Report Share Posted February 21 @omar302 Good to hear. In my opinion this is a premature failure of this type of joint and suspect its improper lubricant. I occasionally had the clunk with the steering at full lock and pulling off. Another symptom is what sounded like gear whine to me and thought it was my transfer case going out. That whine is about gone - its very faint now and sounds like its coming from the rear and if I monitor the AWD to FWD transfer I can hear a decrease at that time goes into FWD, which has me thinking about changing the rear CV Axles and if I do I'll be looking the TrakMotive or GSP on RockAuto.com $85 per CV Axle, most likely also incorrect lubricant, experience changing these and the fact that it should be easier on the rear, makes me close to pulling the trigger on replacing the rear. I had symptoms 2, 3, 4 & 5 described in the attached document. https://www.rockauto.com/info/570/TrakMotive-Noise-Sumptoms-of-a-Worn-CV-Shaft-02.17.pdf Anyone have experience with TrakMotive or GSP CV Axles? 1 Quote Link to comment Share on other sites More sharing options...
Biker Posted February 22 Report Share Posted February 22 Thanks for the updates! 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 22 Report Share Posted February 22 On 2/21/2026 at 3:51 PM, 1004ron said: That whine is about gone - its very faint now and sounds like its coming from the rear and if I monitor the AWD to FWD transfer I can hear a decrease at that time goes into FWD, which has me thinking about changing the rear CV Axles If you want, you can disconnect the connector for the RDU clutch/module which will make it run in full FWD mode. This could help you feel the difference with no load to the rear. On 2/21/2026 at 3:51 PM, 1004ron said: Anyone have experience with TrakMotive or GSP CV Axles? I have no experience with any, but I did notice that the case of the inner CV for the TrakMotive is circular, while the GSP looks like the OEM one. Another thing I noticed, the rear OEM Axle part number was superceded once only, unlike the fronts which changed 5 times, at least. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 27 Report Share Posted April 27 On 2/21/2026 at 3:51 PM, 1004ron said: which has me thinking about changing the rear CV Axles and if I do I'll be looking the TrakMotive or GSP on RockAuto.com $85 per CV Axle, most likely also incorrect lubricant, experience changing these and the fact that it should be easier on the rear, makes me close to pulling the trigger on replacing the rear. I had symptoms 2, 3, 4 & 5 described in the attached document. https://www.rockauto.com/info/570/TrakMotive-Noise-Sumptoms-of-a-Worn-CV-Shaft-02.17.pdf Anyone have experience with TrakMotive or GSP CV Axles? Hi, Did you eventually change the rears? If so, how did you find the old ones? Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 27 Author Report Share Posted April 27 1 hour ago, omar302 said: Hi, Did you eventually change the rears? If so, how did you find the old ones? Not yet. Still contemplating the change as it's only a mildly irritating faint noise without vibration. 1 Quote Link to comment Share on other sites More sharing options...
garycrist Posted April 28 Report Share Posted April 28 This reminds me of servicing the CV joints on my '69 VW..😉 I think I still have the 12 point Snap-On fall off socket. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 26 Author Report Share Posted July 26 My wife used my car the other day and remarked about the sound which prompted me to give more thought to changing the rear CV Axles, but I'm not 100% sure that's the source of the noise. It's a faint gear whine just like the front CV axles caused, just no where near as loud - its there all the time but just a little more pronounced when power is being sent to the rear. I'm looking at the below parts, which wouldn't be too bad if it ended up not being the source of the wine - if its not the rear CV Axles I'll be leaving it like it is until I sell the car. Anyone know of good YouTube videos for rear CV Axle replacement? Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted July 26 Report Share Posted July 26 (edited) 2 hours ago, 1004ron said: Anyone know of good YouTube videos for rear CV Axle replacement? I found several possibilities by typing in the following: https://duckduckgo.com/?q=Rear+CV+Axle+replacement+Ford+Edge+AWD&t=osx&ia=web Pick your poison. Edited July 26 by Samurai Edge Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 26 Author Report Share Posted July 26 20 minutes ago, Samurai Edge said: I found several possibilities by typing in the following: https://duckduckgo.com/?q=Rear+CV+Axle+replacement+Ford+Edge+AWD&t=osx&ia=web Pick your poison. Thanks - Much the same results as Google - was hoping for something members could personally confirm . Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 26 Author Report Share Posted July 26 (edited) I might do the rear CV Axles first and then if needed do the wheel bearings at a later date. Here's a video I found for the rear CV Axle replacement: Edited September 12 by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 26 Author Report Share Posted July 26 (edited) Those that have removed the wheel bearing hubs, what type of puller/extraction tool did you use and recommend? Mine is nowhere near as corroded as many I've seen in the YouTube videos, but with the aluminium knuckle there is likely galvanic corrosion. I'm looking at these on Amazon: Hub Remover Tool 5 6 8 Lug Wheel Hub Puller Kits, OEM#40100 | Steel construction, threaded force screw design, including washers insert plate, supports removal tasks, auto repair 8629 Wheel Hub Removal Tool, Wheel Bearing Removal Tool, Wheel Hub Removal Tool, Replace for ATD Tools. SGT 40100 Hub Remover Set,Wheel Bearing Hub Remover Tool Set Compatible with 5 6 8 Lug Hub Assemblies Rear Axle Bearing Remove Puller Tool Kit, Slide Hammer and Bearing Remover Set with Slide Hammer Yoke 78834 New Upgraded Wheel Hub Removal Tool, Wheel Bearing Removal Tool for All Automotive Wheels with 2 Press Feet, 2 M12 Nuts and Bolts, 2 M14 Nuts and Bolts . Edited July 26 by 1004ron Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted July 26 Report Share Posted July 26 (edited) On 7/26/2026 at 6:43 PM, 1004ron said: Those that have removed the wheel bearing hubs, what type of puller/extraction tool did you use and recommend? Rear Axle Bearing Remove Puller Tool Kit, Slide Hammer and Bearing Remover Set with Slide Hammer Yoke I have used a slide hammer in the past to remove wheel bearings on my Subaru in the past. It worked out pretty well. I have something very similar to the one above. BTW: I like the TRQ videos. They are very well done NOTE: Just something to be aware of. One whack will not be enough to get this off. It's going to take several hard whacks at least. Edited July 29 by Samurai Edge 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 12 Author Report Share Posted September 12 I've held off buying parts to address this whining/humming noise because I'm unsure of what's actually causing it. Well, its got worse and it's loudest between 40 and 60 mph and doesn't respond to acceleration or deceleration so I'm leaning towards it being a wheel bearing, and I'm not sure if its front or rear. I'm thinking of getting four of the SKF BR931101 for around $100 each on RockAuto in the hope that will cure the irritating noise - or wait until it gets a lot worse making it more evident. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted September 12 Report Share Posted September 12 (edited) Have you tried having someone else in the car with you, sitting in the back to see if they hear it louder in the back than you hear it in the front? If not responding to deceleration, and I am presuming with brake added, then most likely not the brakes. Another possibility: Could the whining / humming noise be coming from the driveshaft bearings? Edited September 12 by Samurai Edge 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 12 Report Share Posted September 12 It's been sometime now and I don't remember if this was suggested before, but have you considered they might be coming from the tires? Maybe try rotating them to see if it changes the noise? If recall correctly, with bad bearings the noises would change on turns when the loads on them shift. 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 12 Author Report Share Posted September 12 Thanks for the comments and suggestions. The whine can be heard accelerating/decelerating with or without braking. I might hold-off buying parts until after the next service at which time I'll inspect the driveshaft, change PTU and RDU oils and check the drained oil. The tires have just under 10K miles on them - P Zeros bought and installed at Costco - I did inspect them and there's no sign of wear let alone cupping etc. Quote Link to comment Share on other sites More sharing options...
garycrist Posted September 14 Report Share Posted September 14 How far worn are the tires? A lot of them will become more noisy as they wear. I have chased wheel bearing and tire whine and I feel your pain. As a side note, when they used to ship cars by train, they would cinch them tight with chains. All of the pressure was put on sometimes 1 roller of a bearing set. The race would sometimes pick-up a small dent and the roller a flat spot. Those were only found by replacement. 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted 7 hours ago Author Report Share Posted 7 hours ago Tires have 11K miles on them and no sign of wear. I bought Chassis Ears and took it for a drive. Both front wheels signals got very noisy between 40 and 60 mph - all this time I've thought it was from the rear, and because of that I got my wife to drive while I sat in the cargo space in the back and it was completely quiet. My wife from the get go believed it was coming from the front. I'm ordering replacement wheel bearings for the front only at this time. Quote Link to comment Share on other sites More sharing options...
