Shimmy, shake, jiggle, when >50 mph and accelarating - RESOLVED - Bad CV Axles
1004ron
@1004ron
I did not have the vibration/shimmy at acceleration, but a bad clunk. But based on your findings with the wear found on the axles, and as I had no other explanation for the clunking I got. Also the fact that the axle part numbers were superceded several times (at least 5), I went ahead and replaced the left side, OEM.
The clunking is finally fixed, at least about 80% of it. Also the Edge felt smoother. So I replaced the right side too. Even better.
Opening the inner bearings on both axles revealed similar wear. Both sides also had the grease come out in liquid form.
Left side:
Right side:
Screenshot_2026-02-21-11-44-27-38_965bbf4d18d205f782c6b8409c5773a4.thumb.jpg.f23f5b75fad9f68202a15b16252ce4f3.jpg
Screenshot_2026-02-21-11-44-00-90_965bbf4d18d205f782c6b8409c5773a4.thumb.jpg.d8ab23bf0e4fa9c618e7b6edb052a90e.jpg
  • Thanks 1
@omar302
Good to hear.
In my opinion this is a premature failure of this type of joint and suspect its improper lubricant.
I occasionally had the clunk with the steering at full lock and pulling off.
Another symptom is what sounded like gear whine to me and thought it was my transfer case going out.
That whine is about gone - its very faint now and sounds like its coming from the rear and if I monitor the AWD to FWD transfer I can hear a decrease at that time goes into FWD, which has me thinking about changing the rear CV Axles and if I do I'll be looking the TrakMotive or GSP on RockAuto.com
$85 per CV Axle, most likely also incorrect lubricant, experience changing these and the fact that it should be easier on the rear, makes me close to pulling the trigger on replacing the rear.
I had symptoms 2, 3, 4 & 5 described in the attached document.
https://www.rockauto.com/info/570/TrakMotive-Noise-Sumptoms-of-a-Worn-CV-Shaft-02.17.pdf
Anyone have experience with TrakMotive or GSP CV Axles?
  • 1004ron changed the title to Shimmy, shake, jiggle, when >50 mph and accelarating - RESOLVED - Bad CV Axles
If you want, you can disconnect the connector for the RDU clutch/module which will make it run in full FWD mode. This could help you feel the difference with no load to the rear.
I have no experience with any, but I did notice that the case of the inner CV for the TrakMotive is circular, while the GSP looks like the OEM one.
Another thing I noticed, the rear OEM Axle part number was superceded once only, unlike the fronts which changed 5 times, at least.
  • 2 months later...
Hi,
Did you eventually change the rears?
If so, how did you find the old ones?
  • 2 months later...
My wife used my car the other day and remarked about the sound which prompted me to give more thought to changing the rear CV Axles, but I'm not 100% sure that's the source of the noise.
It's a faint gear whine just like the front CV axles caused, just no where near as loud - its there all the time but just a little more pronounced when power is being sent to the rear.
I'm looking at the below parts, which wouldn't be too bad if it ended up not being the source of the wine - if its not the rear CV Axles I'll be leaving it like it is until I sell the car.
Anyone know of good YouTube videos for rear CV Axle replacement?
