Ford Edge 2014 AWD 3.5L v6 intermittently hard start even engine cranks (No check light)
nomi
It starts perfectly fine in the morning but later in the day engine cranks but it takes time to start intermittently (No check light).
Worked on followings but no luck
  • New Battery Replaced
  • MAF sensor Cleaned
  • New Air Filter Repalced
  • New Cabin Filter Replaced
  • New Purge Valve Replaced
  • New Spark Plugs Replaced
  • New PCV Valve Replaced
  • No corelation with Refueling
Please check the attached video recording.
Edited by nomi
Added more details
  • nomi changed the title to Ford Edge 2014 AWD 3.5L v6 intermittently hard start even engine cranks (No check light)
My 2009 MKX has done this three times to me. Year or two between events. Always started on second try so I ignored it.
My guess at the time was it was related to the immobilizer circuit had gotten the wrong signal or a spike had occurred during the start sequence.
If it happens again and doesn't start on the second try, try disabling (or resetting) the immobilizer by putting the key in, turn to on, then off and wait a few seconds. (With keyless not certain, perhaps push "srmtart" button (goes to accrssory), then off and wait a few seconds for the immobilizer to reset.)
I tend to believe that the immobilizer is what's  involved,  inasmuch as the car reacts exactly like the wrong key (or fob) is in the car.
I visited ford dealer few days ago for diagnonsis and this is the response I got. (But No Check Light)
IDS TEST. CODE P-0316. EVAP TEST. PURGE VAVLE STUCK OPEN.
VAPOUR CANISTER FUEL CONTAMINATED.
PURGE VAVLE is replaced now but the issue is persistent. VAPOUR CANISTER FUEL CONTAMINATED is expensive so I am not doing it at this stage because I doubt it is the reason. (It has no corelation with Refueling)
Why I said Engine coolant temperature sensor because it always start perfectly fine in the morning and also when I start immediately ( or ~5 min) after parking.
When it is parked for around ~45 min and more then it takes time to start.
Edited by nomi
None of those codes or the engine temperature sensor would prevent the engine start.
Puzzled why the Ford Dealership couldn't diagnose the issue.
What did they report following their diagnosis? - did they confirm that the codes were unrelated to the no-start issue?
If the no-start is repeatable with regards the 45 minute wait then you need to make them aware of that and they can diagnose accordingly - could be fuel rail pressure bleeding off.
Another thing, is there any other info you haven't disclosed, such as the Ford Dealership doing diagnostics?
Did you get this solved? Ours occasionally does this as well sometimes hard start when cold in the morning after sitting overnight and other times when it's warm. I've seen others suggest turning it on, but not trying to start for a few seconds to give the fuel pump time to pressurize the system. The suggestion there is fuel drains back and the solution is to replace fuel pump. Those are costly and labor intensive so I'd like more confidence that's the issue before diving in.
8 minutes ago, smcmurray said:
Any updates? I've watched ours more closely and it does match your symptoms. First start in the morning is quick and restarting after a few minutes is fine. But anything 1 to 3 hours takes a lot of cranking. Maybe some kind of vapor lock from the hot engine?
Any codes?
OK this is a good thread for me to ask a question. In the event that I wanted to buy a diagnostic code reader for download to my iPhone, which one is best for me.
I have a 2024 Edge ST. I don't mind paying for it as the free stuff is usually very basic. Bottom line, what diagnostic program would you guys recommend for my vehicle. Free or not, I would love to have it on my phone. I also would need a Bluetooth adaptor. Thanks for the advice.  Jim
For me I would recommend ForScan lite with the OBDLink MX+ adapter.
The OBDLink MX+ also comes with an included app that can also read enhanced diagnostic codes, not just the check engine light, and for most vehicles. The license included with the OBDlink MX+ allows to read enhanced codes for most 1996+ vehicles.
