nomi Posted February 25 Report Share Posted February 25 (edited) It starts perfectly fine in the morning but later in the day engine cranks but it takes time to start intermittently (No check light). Worked on followings but no luck New Battery Replaced MAF sensor Cleaned New Air Filter Repalced New Cabin Filter Replaced New Purge Valve Replaced New Spark Plugs Replaced New PCV Valve Replaced No corelation with Refueling Please check the attached video recording. WhatsApp Video 2025-02-24 at 21.40.59.mp4 Edited March 3 by nomi Added more details Quote Link to comment Share on other sites More sharing options...
nomi Posted February 26 Author Report Share Posted February 26 Please check the attached video recording for Morning Perfect Start. WhatsApp Video 2025-02-25 at 17.26.50.mp4 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 4 Report Share Posted March 4 My 2009 MKX has done this three times to me. Year or two between events. Always started on second try so I ignored it. My guess at the time was it was related to the immobilizer circuit had gotten the wrong signal or a spike had occurred during the start sequence. If it happens again and doesn't start on the second try, try disabling (or resetting) the immobilizer by putting the key in, turn to on, then off and wait a few seconds. (With keyless not certain, perhaps push "srmtart" button (goes to accrssory), then off and wait a few seconds for the immobilizer to reset.) I tend to believe that the immobilizer is what's involved, inasmuch as the car reacts exactly like the wrong key (or fob) is in the car. Quote Link to comment Share on other sites More sharing options...
nomi Posted March 4 Author Report Share Posted March 4 Thank you very much @enigma-2 for the reply, will find out how can I try this with push start button but I know what you mean. just a wild guess, do you think any corelation with Engine coolant temperature sensor OR O2 sensor? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted March 4 Report Share Posted March 4 Honestly I would doubt it. You getting any codes when this happens? Quote Link to comment Share on other sites More sharing options...
nomi Posted March 4 Author Report Share Posted March 4 (edited) I visited ford dealer few days ago for diagnonsis and this is the response I got. (But No Check Light) IDS TEST. CODE P-0316. EVAP TEST. PURGE VAVLE STUCK OPEN. VAPOUR CANISTER FUEL CONTAMINATED. PURGE VAVLE is replaced now but the issue is persistent. VAPOUR CANISTER FUEL CONTAMINATED is expensive so I am not doing it at this stage because I doubt it is the reason. (It has no corelation with Refueling) Why I said Engine coolant temperature sensor because it always start perfectly fine in the morning and also when I start immediately ( or ~5 min) after parking. When it is parked for around ~45 min and more then it takes time to start. Edited March 4 by nomi Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 4 Report Share Posted March 4 None of those codes or the engine temperature sensor would prevent the engine start. Puzzled why the Ford Dealership couldn't diagnose the issue. What did they report following their diagnosis? - did they confirm that the codes were unrelated to the no-start issue? If the no-start is repeatable with regards the 45 minute wait then you need to make them aware of that and they can diagnose accordingly - could be fuel rail pressure bleeding off. Another thing, is there any other info you haven't disclosed, such as the Ford Dealership doing diagnostics? Quote Link to comment Share on other sites More sharing options...
nomi Posted March 4 Author Report Share Posted March 4 (edited) Thank you very much @1004ron for your reply. This is the screenshot of the Ford Dealership diagnostics. please review Edited March 4 by nomi Quote Link to comment Share on other sites More sharing options...
nomi Posted March 8 Author Report Share Posted March 8 @enigma-2 I tried disabling (or resetting) the immobilizer by putting the fob inside the given slot but it doesn't fix the problem. 1 Quote Link to comment Share on other sites More sharing options...
smcmurray Posted April 23 Report Share Posted April 23 Did you get this solved? Ours occasionally does this as well sometimes hard start when cold in the morning after sitting overnight and other times when it's warm. I've seen others suggest turning it on, but not trying to start for a few seconds to give the fuel pump time to pressurize the system. The suggestion there is fuel drains back and the solution is to replace fuel pump. Those are costly and labor intensive so I'd like more confidence that's the issue before diving in. 1 Quote Link to comment Share on other sites More sharing options...
nomi Posted April 23 Author Report Share Posted April 23 @smcmurray I don't think its fuel pump pressurize the system issue because my ford edge starts perfectly fine in the morning. it hard starts after parked for ~45 minutes. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 23 Report Share Posted April 23 1 hour ago, nomi said: @smcmurray I don't think its fuel pump pressurize the system issue because my ford edge starts perfectly fine in the morning. it hard starts after parked for ~45 minutes. Ever consider changing the purge valve? 1 Quote Link to comment Share on other sites More sharing options...
nomi Posted April 24 Author Report Share Posted April 24 I replaced the purge valve but it doesn't fix the issue. 1 Quote Link to comment Share on other sites More sharing options...
smcmurray Posted 10 hours ago Report Share Posted 10 hours ago Any updates? I've watched ours more closely and it does match your symptoms. First start in the morning is quick and restarting after a few minutes is fine. But anything 1 to 3 hours takes a lot of cranking. Maybe some kind of vapor lock from the hot engine? Quote Link to comment Share on other sites More sharing options...
1004ron Posted 10 hours ago Report Share Posted 10 hours ago 8 minutes ago, smcmurray said: Any updates? I've watched ours more closely and it does match your symptoms. First start in the morning is quick and restarting after a few minutes is fine. But anything 1 to 3 hours takes a lot of cranking. Maybe some kind of vapor lock from the hot engine? Any codes? Quote Link to comment Share on other sites More sharing options...
