RPGR90s Posted April 30, 2025 Report Share Posted April 30, 2025 I have a 2019 Edge ST AWD with 86k. Original owner. I am starting to notice an unusual noise from the right rear (as best as I can estimate) when making right hand turns from a dead stop. It's very subtle but noticeable, like a loose shock or something. I replaced both rear shocks with Bilstein's but the problem was happening before the shock replacement. And it only happens when starting off in a right hand turn. Like at an intersection where you stop and then turn right. I'm just trying to figure out what it might be so I can tackle it before it's a huge issue. Thanks so much. Quote Link to comment Share on other sites More sharing options...
fastback89 Posted May 1, 2025 Report Share Posted May 1, 2025 I have 2020 ST that was making bump noise when accelerating from a dead stop when turning. I fixed it by changing the fluid in the rear differential. I will warn you that the fluid is somewhat expensive but it only required 1 quart. Quote Link to comment Share on other sites More sharing options...
Haz Posted May 2, 2025 Report Share Posted May 2, 2025 Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted July 16, 2025 Report Share Posted July 16, 2025 I had the same issue with my 2020 Edge ST with only 20K miles. There is a TSB that covers this. A PDM update resolves the issue. However, if the RDU fluid has never been changed, or if the wrong fluid was used, then the RDU fluid should be changed soonest. 1 Quote Link to comment Share on other sites More sharing options...
jaydubau Posted April 11 Report Share Posted April 11 This is my typical luck throughout life. 😁 Others on this thread had their noises cured by merely changing the diff fluid. But me and my wife's 2020 Edge Titanium with only 40k miles? We heard the noise and took it to our dealer and had them change the diff fluid. Couple hundred dollars tops. Right? WRONG. They saw metal bits when they were changing the fluid!! Differential is SHOT. Only 40k miles. A $6,000 repair!!! Story of my life. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted April 12 Report Share Posted April 12 Extended Warranty? If the dealership tells you that your car is over 5 years old, and Ford does not warranty Ford cars that old, they are outright lying to you. There a number of reasons that the rear diff broke up. Here are only two (2): - Are you the original owner? - Did you ever have the rear diff fluid changed before? 1 Quote Link to comment Share on other sites More sharing options...
boostededge Posted April 12 Report Share Posted April 12 This thread makes me want to go change my RDU fluid again just for the heck of it 😅 Quote Link to comment Share on other sites More sharing options...
jaydubau Posted Wednesday at 11:02 PM Report Share Posted Wednesday at 11:02 PM On 4/12/2026 at 11:13 AM, Samurai Edge said: Extended Warranty? If the dealership tells you that your car is over 5 years old, and Ford does not warranty Ford cars that old, they are outright lying to you. There a number of reasons that the rear diff broke up. Here are only two (2): - Are you the original owner? - Did you ever have the rear diff fluid changed before? No, I hadn't changed the fluid. Heard back from Ford and they AGREED to pay about $4,500 of the $6,000 bill. I can live with that. Thank you Ford!! Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Thursday at 03:41 PM Report Share Posted Thursday at 03:41 PM I could live with that as well. You may have a $100 deductible that goes with that but still acceptable. Could be that the fluid was never changed, hence a solid reason for the failure. The RDU fluid is only a 75W straight fluid so it's not the typical 75W90 or 75W140 found in earlier models. Plan to replace that RDU fluid every 20K miles so you never have a repeat of this issue 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted Friday at 07:49 PM Report Share Posted Friday at 07:49 PM I have a 2024 ST and just hit 11000 miles. I am planning on the the PTU and RDU at 15000 just to be safe. I am going to used Redline full synthetic because of all the good reviews it gets. 75W85 GL-5 for the PTU and MT-LV 70/75W GL-4 for the RDU. Quote Link to comment Share on other sites More sharing options...
jaydubau Posted Saturday at 10:45 PM Report Share Posted Saturday at 10:45 PM I just picked up the car today, Saturday. What a difference!! So many little noises are gone. The car is so smooth, now. I've attached a copy of what they did to the car in the event anyone has to go through this in the future. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 16 hours ago Report Share Posted 16 hours ago On 4/17/2026 at 3:49 PM, STBEAST said: I have a 2024 ST and just hit 11000 miles. I am planning on the the PTU and RDU at 15000 just to be safe. I am going to used Redline full synthetic because of all the good reviews it gets. 75W85 GL-5 for the PTU and MT-LV 70/75W GL-4 for the RDU. I have used Redline products for 20+ years and have never had an issue. Motul is another brand I use for the same reason. Both high quality This is what I used for my change-over Change PTU Gear Oil - Motul 75W90 ( 14 oz ) Change RDU Gear Oil - Redline 70W75W MT-LV ( 28 oz ) Quote Link to comment Share on other sites More sharing options...
1004ron Posted 15 hours ago Report Share Posted 15 hours ago I too have used Redline products and consider them top grade. Did wonders in my Harley Nightrain's gearbox. Quote Link to comment Share on other sites More sharing options...
