RPGR90s Posted October 10, 2025 Report Share Posted October 10, 2025 Original owner of my 2019 ST with the Panoramic Roof. 93k. Yesterday I went to open the shade and it sounded like glass was breaking. It moved about 1/2 way open until I pressed the button to stop it. It appears the shade ripped in the corner and became detached from whatever mechanism that drives it. Is this repair beyond a regular mechanic like myself? Are there any online videos that might help? Or should I just make an appt. with the local dealer? Thanks so much! 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted October 24, 2025 Report Share Posted October 24, 2025 To get your answer, a simple internet search will answer your question. However, to repair the sunshade, you are going to have to remove the glass panel. Are you up to the task? 1 Quote Link to comment Share on other sites More sharing options...
RPGR90s Posted November 6, 2025 Author Report Share Posted November 6, 2025 Just recently, I went to open the shade for my sunroof (2019 Edge ST) and near the end of travel, it sounded like gears stripping, etc. I just took it in to the local Ford dealer (Stillwell Ford in Hillsdale, MI) and they gave me an estimate of $1800 (OUCH!) I declined obviously, so I wanted to ask if that is a known issue and maybe get pointed to some repair it yourself videos. I am capable, having been a mechanic/engineer for over fifty years. Thanks very much. (Love the car, lament that I got the panaorama roof) RPG 2 Quote Link to comment Share on other sites More sharing options...
garycrist Posted November 7, 2025 Report Share Posted November 7, 2025 Moral of the story often repeated, Never open the pano roof and never encounter a problem. 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted November 16, 2025 Report Share Posted November 16, 2025 (edited) If it sounds like gears stripping, it could be something is simply off track and needs to be put back into place OR gears are stripping. They want to change you $1800 because to determine the problem, the glass roof will need to be removed. So, most of it is labor time @ $200+ / hour. There are videos on Youtube on how to do this yourself so if you feel capable, then go for it. If not, just leave it closed and never open it again. And I just realized you asked this exact same question less than a month ago and I gave you the same answer. Edited November 16, 2025 by Samurai Edge Quote Link to comment Share on other sites More sharing options...
STBEAST Posted November 16, 2025 Report Share Posted November 16, 2025 Not to get off track (no pun intended) but I have a 2024 ST with about 9000 miles. About 2 months ago I noticed a metallic popping/tapping/snapping sound coming from the right rear corner of the moonroof area. Right side rear corner. Doesn't matter if the shade or the moonroof is open or closed. It happens on bumpy roads and it is not there when it is cold out. It seems as the sun warms the top of the car, this noise becomes more noticeable. Thanks for any suggestions. And yes, turning the stereo up is a solution! Quote Link to comment Share on other sites More sharing options...
Davidoo Posted November 16, 2025 Report Share Posted November 16, 2025 1 hour ago, STBEAST said: Not to get off track (no pun intended) but I have a 2024 ST with about 9000 miles. About 2 months ago I noticed a metallic popping/tapping/snapping sound coming from the right rear corner of the moonroof area. Right side rear corner. Doesn't matter if the shade or the moonroof is open or closed. It happens on bumpy roads and it is not there when it is cold out. It seems as the sun warms the top of the car, this noise becomes more noticeable. Thanks for any suggestions. And yes, turning the stereo up is a solution! This is a common and annoying issue with a fairly easy fix. See this thread...... 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted November 22, 2025 Report Share Posted November 22, 2025 Davidoo, thank you for locating that thread. I actually made a couple of post and ended up putting one of those felt pads underneath the clip. fishx65 suggested it in a post and I did the same thing. I will keep everyone posted. I noticed in your last post on that thread you stated that the noise had come back on your 22 ST and it wasn't the bar? Do you have any updates on your situation regarding this? Thanks Quote Link to comment Share on other sites More sharing options...
RPGR90s Posted June 6 Author Report Share Posted June 6 2019 ST with 100,000 miles. The car has been pretty much trouble free until recently when I went to open the sunshade. it sounded like it was ripping itself apart and it stayed open all winter. I took it to the local Ford dealer (Stillwell Ford in Hillsdale, MI) and was quoted over $3,000.00. If anyone knows of a place in southern MI or even metro Detroit (not a dealer) that could repair this, I would sure appreciate it. Thanks in advance, RPGR90s 1 Quote Link to comment Share on other sites More sharing options...
RPGR90s Posted June 7 Author Report Share Posted June 7 My apologies. I forgot that I had posted this same question last fall. RPGR90s Quote Link to comment Share on other sites More sharing options...
