Misfiring under load/low rpm, New coils/plugs/injectors
slideways
My 2008 has been doing this for almost 10years now but its so consistent that i'd like to actually fix it at some point. At low rpm when lugging the engine or basically cruising in O/D at any time or in any gear it will thump in the floorboard which is most certainly a misfire. The great thing is it never throws codes for it. Years ago i replaced the plugs around 100k which cured the heavy symptoms. Then at some point around 150-175 i replaced all 6 coils/plugs. Around 190k it actually threw a misfire code for a bad injector which i changed. At 195k i had all injectors replaced when i had my water pump job done as PM. Car has also had the OSS/TSS sensors done in the transmission. Basically at 218k this vehicle has had all of the items done that should cause this problem and still misfires religiously with no codes. Does the PCM itself actually control spark to the point where it would be the last item to change? I have never "fried" a coil that would have damaged it and the problem has continued throughout the last 120k miles of this thing's life despite all these parts being changed.
  • Sad 1
Bad coil pack or a bad coil pack connection.
If the connector is not properly secured, it will definitely cause this issue.
23 hours ago, 1004ron said:
What are you using to read codes?
What spark plugs are you using and where do you purchase them from?
These are also very pertinent questions.
  - Were the plugs purchased from an actual Ford dealer or an otherwise known trusted source?
Sometimes you can get symptoms and not get a code because the symptom is so brief, it does not get identified by the code reader  BUT  use the wrong type or cheap code reader will be of no help
100% OEM Motorcraft Plugs in both cases when i changed them before and more recently with the OEM coils. I only have a cheap code reader but like i said there are no codes and never has been except in the instance when i had the misfire caused by the bad injector which cleared when that was replaced. And then also replaced all others with OEM. I'd guess like you said its so intermittent that no codes presents itself.
That link doesnt cover an 08 Edge but its been so long i cant recall. I didnt get them from ebay it seems according to my past purchases. Must have been RockAuto. They were in motorcraft boxes both times i did the plugs and also the coils were motorcraft.
If you're unsure of where the plugs were purchased then they're suspect in my opinion and would recommend they're replaced using ones bought from a reliable supplier such as RockAuto, and not eBay or Amazon.
The knockoffs also come in Motorcraft boxes.
Yes, it typically will cost you more money but when you buy parts, make sure you are buying the real McCoy and  not some cheap knock-off.  Scammers selling cheap look-alike knock-offs are everywhere.  Companies, like Amazon for one, may buy from their Buyer but that doesn't mean what they bought was real.  Too many times a company's Buyer's instructions are to get the best price.  Best price on what is the real question.
Scammers are getting better at marking products to look just like the real thing.
So i guess my real question to this is can the PCM itself cause this high load/low rpm misfire? Assuming i have been using real Motorcraft plugs and coils for the last 150k miles since i've owned this vehicle. 2 rounds of plugs and one round of coils and this problem has been the same for 150k miles.
  • Confused 1
The PCM theory is an even deeper rabbit hole vs the unknown condition of the spark plugs and coils.
2 rounds of plugs and coils of uncertain origin and quality = 2 rounds of uncertainty.
Not having a reliable code reader is the reason why your diagnostics is floundering leaving you to guess and assume.
Use the free app Forscan Lite which will work with many but not all OBDII adapters, even many of the cheap OBDII adapters.
Amazon.com: vgate vLinker FD Plus OBD2 Adapter Bluetooth BLE Scanner for FORScan, Work with iPhone, Android, and Windows : Automotive
Just remember I said that something wrong with the PCM is a possibility, not the actual cause.  Agent 1004 seems confused.
As previously mentioned / questioned, are the spark plugs / coils of known origin?  You mentioned Rock Auto.
Have you checked all spark plug / coil connections to be certain they are secure?
Where do you buy your fuel?
I have had past issues with fuel sources that have created intermittent issues like you are mentioning.  Even trusted fuel stations in the past were no longer trusted.  Stations are susceptible to leaky tanks as well as buying cheap fuel from other sources, ie; not Mobil fuel from a certified Mobil distributor so they can increase profit on fuel sales.
"Must have been RockAuto." - That doesn't sound like a confident response to me.
Reliable code reading is the best starting point.
Edited by 1004ron
