bruker Posted Friday at 04:28 PM Report Share Posted Friday at 04:28 PM What's the correct rear diff fluid for a 2020 Edge and where did you get it from? Thanks Quote Link to comment Share on other sites More sharing options...
1004ron Posted Friday at 05:17 PM Report Share Posted Friday at 05:17 PM Looks like the owner's manual calls for: Rear Axle Variant Quantity All. 28.1 ± 1.0 fl oz (830 ± 30 ml) Materials Name Specification Motorcraft® Disconnect Rear Drive Unit Fluid XY-75W-QL - MOTORCRAFT XY75WQL Gear Oil | Shop Now at RockAuto 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Saturday at 02:48 PM Report Share Posted Saturday at 02:48 PM The Owner's Manual? That's a funny place to look. 😉 That particular option is ridiculously / outrageously expensive. This is what I use : Redline MT-LV 70W/75W ( Full Synthetic ) 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted Saturday at 05:46 PM Report Share Posted Saturday at 05:46 PM 2 hours ago, Samurai Edge said: The Owner's Manual? That's a funny place to look. 😉 That particular option is ridiculously / outrageously expensive. This is what I use : Redline MT-LV 70W/75W ( Full Synthetic ) The Motorcraft oil is specifically made(formulated) for the Ford "Disconnect Rear Drive Unit". Hence assume it is not a general gear oil like other makes. The Motorcraft specs (link) states: Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is specifically formulated for Ford disconnect rear drive units with a low offset hypoid gear Developed with a lower viscosity to improve axle efficiency and fuel economy Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is formulated with synthetic base stocks, friction modifiers, antiwear and extreme pressure additives to provide gear protection and smooth clutch operation Use only in Ford Disconnect Rear Drive Units DO NOT use in conventional high-offset hypoid gear axles where SAE 75W-85, 75W-90, 80W-90 or 75W-140 is recommended 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Saturday at 06:51 PM Report Share Posted Saturday at 06:51 PM 59 minutes ago, omar302 said: The Motorcraft oil is specifically made(formulated) for the Ford "Disconnect Rear Drive Unit". Hence assume it is not a general gear oil like other makes. The Motorcraft specs (link) states: Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is specifically formulated for Ford disconnect rear drive units with a low offset hypoid gear Developed with a lower viscosity to improve axle efficiency and fuel economy Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is formulated with synthetic base stocks, friction modifiers, antiwear and extreme pressure additives to provide gear protection and smooth clutch operation Use only in Ford Disconnect Rear Drive Units DO NOT use in conventional high-offset hypoid gear axles where SAE 75W-85, 75W-90, 80W-90 or 75W-140 is recommended Good repeat of the manufacturer's position. It really means nothing. As long as someone uses an oil, gear oil, etc., that, at a minimum, meets the standards of the specified oil, gear oil, etc., then said oil performs the same, at a minimum, of the specified oil. Redline MT-LV 70W/75W ( Full Synthetic ) meets that specification. https://www.redlineoil.com/mt-lv-70w75w 2 Quote Link to comment Share on other sites More sharing options...
omar302 Posted Saturday at 07:21 PM Report Share Posted Saturday at 07:21 PM 22 minutes ago, Samurai Edge said: Good repeat of the manufacturer's position. It really means nothing. As long as someone uses an oil, gear oil, etc., that, at a minimum, meets the standards of the specified oil, gear oil, etc., then said oil performs the same, at a minimum, of the specified oil. Redline MT-LV 70W/75W ( Full Synthetic ) meets that specification. https://www.redlineoil.com/mt-lv-70w75w Generally I would agree with you, but I have not seen Ford develope a "specific" oil for no reason. Usually their oils have some spec and the manual would state you should use an oil that meets their minimum spec, for the "disconnect" PTU and RDU used on 2019+ Edges, I don't recall reading the same. In the link for for redline MT-LV specs you posted, it is clearly stated: MT-LV, MTL, MT-85 & MT-90 are not for use in differentials with hypoid gears Additionally, the OEM compatibility does not include Ford's disconnect oil. 2 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Saturday at 07:45 PM Report Share Posted Saturday at 07:45 PM 9 minutes ago, omar302 said: Generally I would agree with you, but I have not seen Ford develope a "specific" oil for no reason. I don't disagree with you but that doesn't mean they are the only game in town. I do use Motorcraft oils because 1.) As you said above and 2.) Many times they are equal or lower in price than a competitor, ie; Redline or Motul. However, the RDU Disconnect fluid is stupidly overpriced so I went looking for an alternative. When I called Redline's Tech Service line, they stated that their MT-LV 70W/75W ( Full Synthetic ) meets that specification of the Motorcraft Disconnect Rear Drive Unit Fluid XY-75W-QL. I don't just swap out one for another without researching alternatives. As far as I could find, only Redline clearly stated that their MT-LV 70W/75W ( Full Synthetic ) meets that specification of the Motorcraft Disconnect Rear Drive Unit Fluid XY-75W-QL. No one else did. I'll spend 1/2 the price on a known product line that I have been using for years. Quote Link to comment Share on other sites More sharing options...
1004ron Posted Saturday at 08:02 PM Report Share Posted Saturday at 08:02 PM Generally the differential oils contain friction modifiers which cause issues with wet clutches. Similar reason why its not good to use car engine oil in a motorcycle due to the wet clutch - motorcycle engine oil does not contain friction modifiers. Redline and Amsoil are top rated, so if they put it in writing that their oil is compatible I'd trust that. The Redline website kind-of indicates that its compatible. Interesting discussion here: https://bobistheoilguy.com/forums/threads/rear-differential-rdu-fluid-amsoil-alternative.401168/ And here: https://www.mavericktruckclub.com/forum/threads/rdu-rear-diff-non-oem-fluid-change-motocraft-xy-75w-qd-is-roughly-equivalent-to-a-synchromesh-gl-4-manual-transmission-fluid-not-a-gear-oil.75331/ Quote Link to comment Share on other sites More sharing options...
omar302 Posted Sunday at 07:01 AM Report Share Posted Sunday at 07:01 AM 1 hour ago, Samurai Edge said: When I called Redline's Tech Service line, they stated that their MT-LV 70W/75W ( Full Synthetic ) meets that specification of the Motorcraft Disconnect Rear Drive Unit Fluid XY-75W-QL. 1 hour ago, 1004ron said: The Redline website kind-of indicates that its compatible. Sorry, but I couldn't find on the Redline website where it states their oil MT-LV 70W/75W is compatible with the Motorcraft XY-75W-QL. It states it is compatible with Ford's XT-11-QDC (WSS-M2C200-D2) which is Ford's dual clutch fluid (link). Checking the recommended fluids based on car make/model does bring up the MT-LV 70W/75W as a recommendation for the rear differential, but if you enter a 2019 Edge it would bring up 75W90 GL-5 GEAR OIL, so their recommendation page is flawed. 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Sunday at 04:11 PM Report Share Posted Sunday at 04:11 PM 22 hours ago, omar302 said: The Motorcraft oil is specifically made(formulated) for the Ford "Disconnect Rear Drive Unit". Hence assume it is not a general gear oil like other makes. The Motorcraft specs (link) states: Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is specifically formulated for Ford disconnect rear drive units with a low offset hypoid gear Developed with a lower viscosity to improve axle efficiency and fuel economy Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is formulated with synthetic base stocks, friction modifiers, antiwear and extreme pressure additives to provide gear protection and smooth clutch operation Use only in Ford Disconnect Rear Drive Units DO NOT use in conventional high-offset hypoid gear axles where SAE 75W-85, 75W-90, 80W-90 or 75W-140 is recommended I think you are missing something here in this explanation. You have to remember that we are talking about the RDU gear oil and NOT the Viscous Coupler oil. These are two (2) different things, two (2) separate units that work independently of each other but, in unison, complete the transfer of power to the rear wheels. Every manufacturer states only use their brand fluid ( you pick which type of fluid ) in their vehicles. Ford is no different. That does not mean you HAVE to and it does not mean that using an appropriate alternate fluid is bad for the vehicle nor will it void warranty. You just have to meet the minimum spec of the original manufacturer specs but exceeding them is even better. Remember that the RDU itself is just gears and bearings. There are no clutches involved. The clutches are in the Viscous Coupler and you can not change that fluid as it is a sealed unit. In my opinion, after doing my own searches for alternates, and speaking directly to a Redline Tech concerning the differences between what is stated by Ford Manufacturing and what Redline states on their website for the Redline MT-LV 70W/75W gear oil, I am convinced one is equally compatible with the other. That's my opinion and Redline's opinion. If in doubt about a product, I go directly to the source and don't rely simply what I read on a label or a website. You don't have to take my advice. You, and anyone else that does not agree, or has doubts, should just use whatever Ford recommends. Quote Link to comment Share on other sites More sharing options...
omar302 Posted Sunday at 07:46 PM Report Share Posted Sunday at 07:46 PM 3 hours ago, Samurai Edge said: Every manufacturer states only use their brand fluid ( you pick which type of fluid ) in their vehicles. Ford is no different. That does not mean you HAVE to and it does not mean that using an appropriate alternate fluid is bad for the vehicle nor will it void warranty. You just have to meet the minimum spec of the original manufacturer specs but exceeding them is even better. The owners manual for the Ford Edge states to use oils that that meets the defined specification and viscosity grade. They do "recommend" Motorcraft, but does not state to only use Motorcraft. Link to the 2024 Edge manual. 3 hours ago, Samurai Edge said: Remember that the RDU itself is just gears and bearings. There are no clutches involved. The clutches are in the Viscous Coupler and you can not change that fluid as it is a sealed unit. Not all gears are engineered or made the same, hence the different oil types and viscosities. 3 hours ago, Samurai Edge said: You don't have to take my advice. You, and anyone else that does not agree, or has doubts, should just use whatever Ford recommends. Well said. 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted Monday at 03:13 AM Report Share Posted Monday at 03:13 AM I have heard nothing but good about Redline. Normally I stick with the manufacturer's product. I am going to do my PTU/RDU fluid changes at 15K on my 2024 ST. PTU Redline full synthetic 75W85 GL-5 gear oil RDU Redline full synthetic MT-LV 70W/75W GL-4 gear oil. Fords PTU/RDU are ticking timebombs, unless you stay up the fluid changes. Seems like frequency is the key. 2 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Monday at 02:42 PM Report Share Posted Monday at 02:42 PM 11 hours ago, STBEAST said: I have heard nothing but good about Redline. Normally I stick with the manufacturer's product. I am going to do my PTU/RDU fluid changes at 15K on my 2024 ST. PTU Redline full synthetic 75W85 GL-5 gear oil RDU Redline full synthetic MT-LV 70W/75W GL-4 gear oil. Fords PTU/RDU are ticking timebombs, unless you stay up the fluid changes. Seems like frequency is the key. Agreed. Too many posts about the discovery of the PTU gone bad and needing replacement and a hefty price tag to go with it. Ford states 30K miles between PTU gear oil changes. Changed mine @ 20K miles and the fluid was already black & disgusting. 1 Quote Link to comment Share on other sites More sharing options...
bruker Posted Monday at 03:08 PM Author Report Share Posted Monday at 03:08 PM Okay, dumb question but what is the PTU that everyone's referring too? 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Monday at 05:29 PM Report Share Posted Monday at 05:29 PM PTU = Power Transfer Unit It is a gear box connecting the engine to the transmission. The engine sits sideways / horizontally in the engine bay, as opposed to longitudinally as standard in a lot of cars. In order to get the power from the engine to the transmission, you essentially have to turn the gearing back to a longintudinal configuration, allowing the power from the engine to reach the transmission. The PTU sits closely nestled between the engine, the transmission and the exhaust. That is a very hot and hostile environment to live in. The gear oil in the PTU bakes surrounded by so much heat. As I mentioned, the manual states 30K miles between gear oil changes for the PTU. Not a good idea if yo want to save your PTU from severe damage / replacement. You could spend $2500 or more to have a dealer replace that PTU. 1 Quote Link to comment Share on other sites More sharing options...
bruker Posted Monday at 06:26 PM Author Report Share Posted Monday at 06:26 PM Thanks. Just watched a YT video and it's looks like a pretty simple process. It only takes 12+_ ounces? Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Monday at 06:39 PM Report Share Posted Monday at 06:39 PM Yes, 12.8 ounces. No idea which video you watched. I went ahead and purchased two (2) different vacuum pumps, one for sucking out dirty fluids and one for pumping in clean fluids. Very easy and the process was fairly quick. I moved around that hose a little into the corners, and I sucked out just about every ounce. I say that because when I pumped the new fluid back in, it took 14 ounces and barely dripped out the fill hole. Quote Link to comment Share on other sites More sharing options...
1004ron Posted Monday at 06:59 PM Report Share Posted Monday at 06:59 PM For extracting fluids where there's no drain plug I use a wire coat hanger inside some clear tubing forming a shepherds hook, connected to my regular oil extractor. 1 Quote Link to comment Share on other sites More sharing options...
bruker Posted Monday at 07:16 PM Author Report Share Posted Monday at 07:16 PM The video I watch was for a 2020 Edge (same as what I have) there was a drain plug. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Monday at 10:28 PM Report Share Posted Monday at 10:28 PM Please provide a link to whatever video you watched. The 2020 Ford Edge does not have a drain plug. I presume you have not looked at your PTU yet Did you buy this car used? If so, the PTU may have been replaced and the replacement may have a drain plug. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Monday at 10:29 PM Report Share Posted Monday at 10:29 PM 3 hours ago, 1004ron said: For extracting fluids where there's no drain plug I use a wire coat hanger inside some clear tubing forming a shepherds hook, connected to my regular oil extractor. The coat hanger is a good idea Quote Link to comment Share on other sites More sharing options...
bruker Posted Monday at 10:49 PM Author Report Share Posted Monday at 10:49 PM (edited) Here's the video, and yes, I did not look at my PTU yet. Edited Monday at 10:58 PM by 1004ron Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Monday at 11:33 PM Report Share Posted Monday at 11:33 PM That's interesting but I don't think that is an OEM PTU. I think that is a replacement PTU that has had the drain plug installed. I have found them listed by doing a search. Once you check your PTU, it will be interesting to see if you have a drain plug on yours. 1 Quote Link to comment Share on other sites More sharing options...
TourGuide Posted Tuesday at 12:53 AM Report Share Posted Tuesday at 12:53 AM Some of the 19-24 PTUs have the drain plug and some do not. This topic has been discussed previously and seems to generate a fair amount of interest every time it comes up. I have already expressed my feelings toward ford on this topic (they were less than positive) so I will refrain from adding them again here. It is fair to say two things on this topic - 1.) These transfer cases are poor engineering decisions on a couple of levels. 2.) Specifically - not ONE of these products should have ever rolled off the assembly line without a drain and fill plug on a gear box. 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Tuesday at 03:53 PM Report Share Posted Tuesday at 03:53 PM (edited) So, that's interesting. Depending on the specific wording you use on your search, some results say The 2020 Ford Edge did not have a drain plug in the PTU, and other results say the PTU drain plugs were installed in so=me vehicles starting in 2015. Either way, as you stated, " Specifically - not ONE of these products should have ever rolled off the assembly line without a drain and fill plug on a gear box. " I whole-heartedly agree with. If anyone expects a manufacturer to listen to them about a product improvement, they will hit a brick wall. No one can even suggest their designers screwed up. Edited Tuesday at 03:53 PM by Samurai Edge Quote Link to comment Share on other sites More sharing options...
