fordedgenashvilletennessee Posted February 25, 2021 Report Share Posted February 25, 2021 I have a 2015 Edge with the EPS. I am trying to change my rear pads. I can not get the left caliper piston to retract, even with the EPS maintenance mode. I have put it in maintenance mode and used a C clamp and a brake compressor tool and it is rock hard and won't go back in. Any suggestions? Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 25, 2021 Report Share Posted February 25, 2021 (edited) On my 2016, it's not compressed, it needs to be turned to get the piston back in. Believe that there's a special tool that will make your life easier. Looks like a cube with different extensions on it to fit in the piston & ratchet it back. https://shop.advanceautoparts.com/p/lisle-disc-brake-piston-tool-28600/25961363-p?product_channel=local&store=6997&adtype=pla&product_channel=local&store_code=6997&gclsrc=aw.ds&&gclid=EAIaIQobChMI9M240eiD7wIV1YtaBR0DgQ6wEAQYASABEgJkYPD_BwE Edited February 25, 2021 by lildisco 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted March 2, 2021 Report Share Posted March 2, 2021 On 2/24/2021 at 7:09 PM, fordedgenashvilletennessee said: I have a 2015 Edge with the EPS. I am trying to change my rear pads. I can not get the left caliper piston to retract, even with the EPS maintenance mode. I have put it in maintenance mode and used a C clamp and a brake compressor tool and it is rock hard and won't go back in. Any suggestions? Was lildisco suggestions any help? Quote Link to comment Share on other sites More sharing options...
lildisco Posted March 5, 2021 Report Share Posted March 5, 2021 I can confirm that the 2020 rears are also screw in style 1 Quote Link to comment Share on other sites More sharing options...
dolsen Posted March 5, 2021 Report Share Posted March 5, 2021 My 2015 also has screw in calipers. I just replaced the rear brakes on mine about 2 weeks ago. 1 Quote Link to comment Share on other sites More sharing options...
kizite Posted March 10, 2021 Report Share Posted March 10, 2021 My 2011 is also screw in. But one of mine i couldn't get to screw in all the way, ended up having to replace the caliper. Quote Link to comment Share on other sites More sharing options...
Don Mulvey Posted November 13 Report Share Posted November 13 So, those of you who have done the rear brakes ... what tool did you use for the electric parking brake calipers? Used the C clamp on the fronts. Put car in brake service mode, removed the caliper ... but the cheap tool I bought to screw in the brake piston would not budge the piston. Thinking I need to rent a tool? What did you guys do? Quote Link to comment Share on other sites More sharing options...
Don Mulvey Posted November 13 Report Share Posted November 13 So, I just ordered another tool but I learned that some pistons (rear with electric parking) are right hand threaded and some are left hand threaded. Anyone know which it is for a 2015 SEL? I don't want to crank on it in the wrong direction. Thanks. -D Quote Link to comment Share on other sites More sharing options...
dabangsta Posted November 14 Report Share Posted November 14 If service mode is actually activated, that means the electronic parking brake actuator is not engaged, you just need to compress the pistons in, like with that same C clamp you used on the front. Only time you might need to rotate it clockwise (either side, same direction) is if it won't compress enough to be fully compressed/you can't install the caliper with new pads over a new rotor. 1 Quote Link to comment Share on other sites More sharing options...
Don Mulvey Posted Friday at 06:49 PM Report Share Posted Friday at 06:49 PM Did not want to hijack a similar thread ... same topic but different model year Edge. I have a 2015 SEL3.5L FWD. Replacing pads with OEM. Fronts fit fine. Rears are way too thick. The caliper won't fit over them. Pads are too thick. I ... - put rear brakes in service mode - used a rear brake piston compression tool for electric parking brakes ... worked perfect ... piston is left hand threaded BTW - bought Motorcraft BRF-1474 pads - verified fitment with the online Ford parts store - bought hardware kit too I just looked online and a different online store says to use part DG92-2200 Anybody know what the correct pads might be for this 2015 ? Getting tired of pulling it apart only to find a problem in stalling new pads. Thanks! Quote Link to comment Share on other sites More sharing options...
dabangsta Posted Friday at 08:03 PM Report Share Posted Friday at 08:03 PM BRF1474 is the same as DG9Z2200F. Did you put in your VIN in the FordParts site, or just manually enter in your vehicle specs? There is a part year (maybe earlier than 1/19/2015 build date) change that maybe they are different. I had to compress my rear pistons again after a couple of minutes because they started popping out before I could get it assembled. How flush is it after you have compressed them? Did you also replace the rotors? A ridge on old rotors might make it harder than the full thickness of new rotors. 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted Friday at 08:18 PM Report Share Posted Friday at 08:18 PM Do your existing pads have a spring at the top of the inboard pad and a large spring on the outside of the caliper: Or does it have stainless rattle and glides that go on the end of the pads on the ears? 1 Quote Link to comment Share on other sites More sharing options...
Don Mulvey Posted Sunday at 06:35 PM Report Share Posted Sunday at 06:35 PM On 3/2/2021 at 5:59 PM, 1004ron said: Was lildisco suggestions any help? My rear brakes are rock solid in service mode till I turn the piston just a bit. I've only played with the right side ... and this side is left hand threaded ... so you turn it counter clockwise to loosen it up. Then it seems fairly easy to turn and compress. My problem is that I cannot get it compressed enough to fit over the new brake pads. I need about 1/8 an inch. I am going to try again. This time I will be more careful to constantly turn it as it compresses. Fingers crossed. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 23 hours ago Report Share Posted 23 hours ago (edited) Just to clear up any confusion on the rear pad part #: So, any of the above part #'s will fit, allegedly. I have never had to rotate the piston to get a brake pad to fit. Ever. Did you recently top off your brake fluid? If you did, then you do not have enough room to push the piston back enough for the new pad to fit. I have seen people do this before. It's one of those " Duh " moments. Another possibility: Are your pistons showing an edge, or ring of corrosion, on the outside edge of the piston? If true, you need to scrape that corrosion off so the piston is the same diameter from back to front Edited 23 hours ago by Samurai Edge Quote Link to comment Share on other sites More sharing options...
Don Mulvey Posted 1 hour ago Report Share Posted 1 hour ago Responding ... - I have cracked the bleeder open and tried compressing ... just to see if I can get an extra 1/8 inch of compression - Used a very nice EPB compression tool ... cheap but very nice ... even better than my C clamp - Used the vehicle VIN to order parts - Used OEM BRF 1474 pads ... not listed above !!! WT - Yes, they look identical to original pads ... but new pads are thicker naturally - live in Texas ... underside of car still looks new ... very little brake dust ... no corrosion ... piston not pristine but looks very good - rinsed caliper and piston .. plus the caliper holding bracket ... with brake cleaner and a soft brush ... looks nice Things I am going to try. First ... screw in the piston ... turning it a lot more while compressing ... to see if I can get that extra 1/8 inch Next ... order the DG9Z-2200 pads and try them if still can't fit the BRF-1474 pads I'll post my findings but it will be a few days. If I get the new pads I'll compare thickness. Quote Link to comment Share on other sites More sharing options...
