Rear caliper wont retract
On my 2016, it's not compressed, it needs to be turned to get the piston back in. Believe that there's a special tool that will make your life easier. Looks like a cube with different extensions on it to fit in the piston & ratchet it back.
https://shop.advanceautoparts.com/p/lisle-disc-brake-piston-tool-28600/25961363-p?product_channel=local&store=6997&adtype=pla&product_channel=local&store_code=6997&gclsrc=aw.ds&&gclid=EAIaIQobChMI9M240eiD7wIV1YtaBR0DgQ6wEAQYASABEgJkYPD_BwE
Edited by lildisco
On 2/24/2021 at 7:09 PM, fordedgenashvilletennessee said:
I have a 2015 Edge with the EPS. I am trying to change my rear pads. I can not get the left caliper piston to retract, even with the EPS maintenance mode. I have put it in maintenance mode and used a C clamp and a brake compressor tool and it is rock hard and won't go back in. Any suggestions?
Was lildisco   suggestions any help?
  • 5 years later...
So, those of you who have done the rear brakes ... what tool did you use for the electric parking brake calipers?   Used the C clamp on the fronts.   Put car in brake service mode, removed the caliper ... but the cheap tool I bought to screw in the brake piston would not budge the piston.   Thinking I need to rent a tool?    What did you guys do?
So, I just ordered another tool but I learned that some pistons (rear with electric parking) are right hand threaded and some are left hand threaded.  Anyone know which it is for a 2015 SEL?   I don't want to crank on it in the wrong direction.   Thanks. -D
If service mode is actually activated, that means the electronic parking brake actuator is not engaged, you just need to compress the pistons in, like with that same C clamp you used on the front. Only time you might need to rotate it clockwise (either side, same direction) is if it won't compress enough to be fully compressed/you can't install the caliper with new pads over a new rotor.
Did not want to hijack a similar thread ... same topic but different model year Edge.
I have a 2015 SEL3.5L FWD.   Replacing pads with OEM.  Fronts fit fine.  Rears are way too thick.  The caliper won't fit over them.   Pads are too thick.
I ...
- put rear brakes in service mode
- used a rear brake piston compression tool for electric parking brakes ... worked perfect ... piston is left hand threaded BTW
- bought Motorcraft BRF-1474 pads
- verified fitment with the online Ford parts store
- bought hardware kit too
I just looked online and a different online store says to use part DG92-2200
Anybody know what the correct pads might be for this 2015 ?   Getting tired of pulling it apart only to find a problem in stalling new pads.
Thanks!
BRF1474 is the same as DG9Z2200F.
Did you put in your VIN in the FordParts site, or just manually enter in your vehicle specs? There is a part year (maybe earlier than 1/19/2015 build date) change that maybe they are different.
I had to compress my rear pistons again after a couple of minutes because they started popping out before I could get it assembled. How flush is it after you have compressed them? Did you also replace the rotors? A ridge on old rotors might make it harder than the full thickness of new rotors.
My rear brakes are rock solid in service mode till I turn the piston just a bit.   I've only played with the right side ... and this side is left hand threaded ... so you turn it counter clockwise to loosen it up.   Then it seems fairly easy to turn and compress.   My problem is that I cannot get it compressed enough to fit over the new brake pads.   I need about 1/8 an inch.   I am going to try again.  This time I will be more careful to constantly turn it as it compresses.   Fingers crossed.
  • 1004ron changed the title to Rear caliper wont retract
Just to clear up any confusion on the rear pad part #:
So, any of the above part #'s will fit, allegedly.
I have never had to rotate the piston to get a brake pad to fit.  Ever.
Did you recently top off your brake fluid?  If you did, then you do not have enough room to push the piston back enough for the new pad to fit.  I have seen people do this before.  It's one of those " Duh " moments.
Another possibility:
Are your pistons showing an edge, or ring of corrosion, on the outside edge of the piston?
If true, you need to scrape that corrosion off so the piston is the same diameter from back to front
Edited by Samurai Edge
Responding ...
- I have cracked the bleeder open and tried compressing ... just to see if I can get an extra 1/8 inch of compression
- Used a very nice EPB compression tool ... cheap but very nice ... even better than my C clamp
- Used the vehicle VIN to order parts
- Used OEM BRF 1474 pads ... not listed above !!!   WT
- Yes, they look identical to original pads ... but new pads are thicker naturally
- live in Texas ... underside of car still looks new ... very little brake dust ... no corrosion ... piston not pristine but looks very good
- rinsed caliper and piston .. plus the caliper holding bracket ... with brake cleaner and a soft brush ... looks nice
Things I am going to try.
First ... screw in the piston ... turning it a lot more while compressing ... to see if I can get that extra 1/8 inch
Next ... order the DG9Z-2200 pads and try them if still can't fit the BRF-1474 pads
I'll post my findings but it will be a few days.  If I get the new pads I'll compare thickness.
Got outside today and figured out the problem and got the job done.
This is what I learned.   On my 2015 SEL FWD 3.5L ..  Replacing rear pads with OEM BRF-1474
I intended to be extra careful in turning the piston as I compressed the piston.  So, I did and the piston was still protruding and obviously not fully compressed ... even though it felt bottomed out.  It also would not turn any further.   So, I back off a turn on the piston and it then compressed further.   Still not fully compressed.  So, I started backing it off and compressing.  Finally got it fully seated.
Think of it as wiggling the piston back into its bore.   Left RIght Compress ... Left Right Compress.
Now, I  am thinking that  you can't compress the piston if its completely rotated in either direction.  That led me to thinking the above wiggle action was needed.   I don't feel like taking it apart to test this idea but pretty sure that is what is going on.
Anyway that was my experience and I hope it helps others.
Thanks everybody for helping out!
Actually, the BRF-1474 is in the above list I posted.  It is an older number superseded by the others numbers.  No one really knows what is behind a manufacturer's thought when they update to alternate p/n's.
You should not have to wiggle the piston to get it to compress.  It should be a straight forward process.
It might give you more trouble down the road so don't be surprised if it does.
I'm glad you got it fixed!
Thanks!   Yeah, just spotted the part number in your list.   I missed it earlier.
So, the piston doesn't actually wiggle.  That is just how I described:  rotate left, rotate right, compress ... repeat
It came to me while typing my above post that the piston doesn't like to compress when its at either end of turning,  either turned all the way clockwise or all the way counter clockwise.  So ... I think the actual remedy is to rotate the piston maybe 1/2 turn and then compress it fully.  This is what I would try next time.
Thanks!  Me too.
I understood " wiggle " vs " rotate back and forth ".  My point being that you should not have to do that at all.  It should be a straight forward compression.
If you have to rotate the piston back and forth, it means that there is something preventing the normal compression.  That means there is some type of " gunk " ( a general term to describe a build-up of rust, grime, grit, etc. ) either on the piston or in the piston chamber.
Just be aware in the future.
