Moderator-
Your mirrors are probably not adjusted correctly. You should not be able to see the side of the vehicle.
It’s not plausible at all for the reason mentioned above - there is nothing in the intake to clean the back of the valves.
Hitch cargo recommendations
akirby replied to sreeve29's topic in Cargo, Hauling, Roof Racks & Towing
Get a hitch from etrailer.com and install it yourself for less than $200. -
Ford to cancel its Ontario-built Edge crossover
akirby replied to handfiler's topic in Articles, News & Reviews
Not true (yet). Under consideration to be replaced with the new similar sized BEVs but that hasn’t been decided and probably won’t S is more of a negotiating tactic for the new union contract. -
Just replace it.
Pennzoil Platinum full synthetic also meets api sn plus now.
Is it really worth the investment? Wouldn’t you get a lot more with a tuner?
Some dealers aren’t following the repair procedure. Try a different dealer.
Which brake fluid should I be using out of these 4?
akirby replied to ThugFordEdge3.5's topic in Brakes, Chassis & Suspension
Never heard of brake fluid viscosity being an issue even in cold climates. Brake fluid is super thin to begin with but I guess low viscosity wouldn’t hurt. -
I don’t see how any of them would perform any differently. -
Go register at blueovalforums.com - all the order guides are posted there.
Ford has had ST-Line models in Europe for many years - alongside ST models. This is not new.
Wouldn't it be cheaper/easier to just buy one of these and wire it into the connector? https://www.amazon.com/BESTEK-300W-Power-Inverter-Adapter/dp/B07Y9M1H88?ref_=s9_apbd_omg_hd_bw_b2RkW&pf_rd_r=92K5TKT119G0JCSES4CF&pf_rd_p=ef88a328-5802-52f1-a22b-1f46a5201df0&pf_rd_s=merchandised-search-10&pf_rd_t=BROWSE&pf_rd_i=583328
Ive said this many times. I would have preferred the 2.0Leb over the 3.7L in our MKX. I just miss that almost instant torque off the line.
I just bought a Rennstand safe jack - should work great on the MKX or any unibody vehicle. A little pricey though. https://www.4wheelparts.com/p/safe-jack-rennstand-by-safe-jack-18m-rs3/_/R-SAJK-18M-RS3?gclid=EAIaIQobChMIrbfKg_LC6QIVF6SzCh2vqgbNEAQYASABEgK8mvD_BwE&ecmp=s:google_9816045574_100845004460__pla-670529025983_Safe Jack_S/J18M-RS3_base_US&utm_source=google&utm_medium=cpc&utm_campaign=shopping&emlprox=out&ppcfon=1&gp=1&ef_id=EAIaIQobChMIrbfKg_LC6QIVF6SzCh2vqgbNEAQYASABEgK8mvD_BwE:G:s&s_kwcid=AL!7836!3!430284196293!!!g!670529025983!&utm_source=google&utm_medium=cpc&utm_campaign=SC Shopping - NTM Desktop&ecmp=s:google_9816045574_100845004460__pla-670529025983
Can I disable artificial engine sound in cabin?
akirby replied to Jombi's topic in Interior, A.C., Heat, Interior Trim
Reports were it was completely disabled but I don't think we ever got an official answer. -
Also true but that's what the software update disabled midway through the 2019 model year. -
It was disabled sometime during the 2019 model year. Software updates will disable it on early build 2019s. -
Accessory power stays active after pressing off button
akirby replied to drm1harley's topic in 2015 Edge & MKX
You probably just need a new battery. They rarely last more than 3-4 years on modern vehicles. A weak battery can cause all sorts of strange issues. I’d replace it then see if you continue to have problems. -
Auto Stop Eliminator For The Nautilus
akirby replied to handfiler's topic in 2019-Current Edge & Nautilius
Use less brake pressure. -
Not destructive at all. I have pool noodles to cushion it. I’ve used tennis balls and a laser pointer but this works well. No damage.
