Everything posted by kc300c
Love the look. Really nice!
Not sure what you mean when you say "bars". The 50W LED bulbs in my kits are direct replacements for the front and rear turn signal bulbs in all model year EDGEs and have dual function just like the dual filament stock bulb.
- 35 replies
The quickest and easiest way to resolve and/or prevent hyper flash is to use high power LED bulbs that are at least 30 watts. The higher wattage will not trigger the hyper flash because it's drawing the same amount of current as the stock bulb. So no need for resistors. I have actually put together an LED bulb pack for the front and rear turn signals and reverse/backup lights. The turns are 50W bulbs that has ten 5W CREE LEDs and the reverse bulb is a 25W using five 5W CREE LEDs. The bulb pack will be owing on sale later this month. Keep an eye out for them.
- 35 replies
Jtuder, I'm not sure how the the DRL installation would have affected the high beam shutter, since the white headlight trigger wire from my DRLs connects to the headlight bulb wire which is totally isolated from the the shutter operation. Can you confirm that the white DRL trigger wire is connected to the correct wire color per the instructions? Edit: Just read your last post about your dealer fixing the broken shutter. Glad to hear that. I have to think the shutter issue was coincidental to installing the DRLs.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
Looking to add modifications to my 2013 SEL Black Ford Edge
kc300c replied to TYYLER's topic in Accessories & Modifications
Psssst. Over here.......... -
Welcome Carol. You're going to love your new Edge.
Welcome to the forum and the Edge family. There are a lot of great folks here that are happy to help out. All you have to do is ask. Enjoy your new ride,
Love the logos and blacked out trim pieces. Really unique.
Edge SE owners: I started a new thread in Classifieds specifically for the SE. My objective is to inform Edge SE owners that my EDGE-2 kits are totally compatible with the SE and that my DRLs do not need the OEM factory wiring to work. Our kit includes a wire harness and controller along with everything else needed to install and operate them. Link to Thread: Edge SE Owners, You can have LED DAYTIME Running Lights on your SE Edge SE black plastic bumper insert vs. EDGE-2 LED DRLs:
- 326 replies
- LED light bar
- LED strip
(and 4 more)
Ford Edge SE Owners Get rid of those uninteresting black plastic covers in your bumper Replace them with our HEAD-TURNING super bright and fully functional EDGE-2 Vertical LED DAYTIME Running Lights (DRL). Don’t worry that your SE doesn't have the factory wiring. You don't need it! Our EDGE-2 kits come with everything you need to install and power the incredibly bright LED DRL lamps. FEATURES: - Simple drop-in replacement - Included wire harness & controller feeds power to the DRLs - True automatic DRL function (Turn the ignition key on, DRLs come on / Key off, DRLs off) - Exclusive hi power amber LED turn signal with crystal clear light bar. - Clean & true OEM look. - Simple installation. Included installation kit comes with everything you need. (All you supply is a screwdriver, pair of pliers and about an hour of time) - Easy to follow written instructions, with lots of photos, makes the install a breeze. - Watch our detailed installation video below to see just how easy it is. Add SAFETY & STYLE to your Edge SE ORDER your set of EDGE-2's TODAY! www.DAYTIMEBrightLites.com
- 6 replies
- bumper
- bumper light
(and 7 more)
From the album: DAYTIME BrightLites - "We make your stock lights BrightLites"
Edge SE OEM factory black plastic cover versus new EDGE-2 Vertical LED DAYTIME Running Light with built-in turn signal. www.DAYTIMEBrightLites.com© Copyright © 2013 DAYTIME BrightLites, LLC. All Rights Reserved.
New EDGE-2 LED DRLs, LED side mirror puddle lights & Interior LED products www.DAYTIMEBrightLites.com© Copyright © 2013 DAYTIME BrightLites, LLC. All Rights Reserved.
DAYTIME BrightLites, LLC forum signature banner www.DAYTIMEBrightLites.com© Copyright © 2013 DAYTIME BrightLites, LLC. All Rights Reserved.
- led puddle
- mirror
(and 8 more)
DAYTIME BrightLites, LLC forum banner ad www.DAYTIMEBrightLites.com© Copyright © 2013 DAYTIME BrightLites, LLC. All Rights Reserved.
Great to hear your install went well and you're liking your new lights. Glad you like the parking light wiring configuration. FYI, For those that may not know, it is perfectly fine to attach the white DRL trigger wire to the center parking light wire.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
EDGE-2 Vertical LED DAYTIME Running Light IN STOCK - ORDER NOW! Made specifically for the 2011–2014 Ford Edge. Order online today: www.DAYTIMEBrightLites.com ADD SAFETY WITH HEAD-TURNING STYLE (As if the Edge needed any help with this ;-). Totally Unique: - Automatic DRL functionality (on/off with ignition key) - Direct replacement for the stock Ford bumper light. - Perfect for Edge SE owners - Easily replace boring black plastic cover on Edges without the factory accent lights (SE models) - 18 watts of power! - Built-in Amber LED turn signal utilizing the brightest most dependable Osram LED chip technology - Crystal clear vertical turn signal light bar for a clean, uniform and high tech look - Night Dimming Function (DRL automatically dims to 70% with headlights) Simple installation: - Detailed easy-to-follow written instructions with photos and wiring diagrams included. - Online step-by-step installation video. - Standard install time is 45 to 60 minutes. - Email & Phone support available, including nights and weekends. ONE-OF-A-KIND FEATURES & FUNCTIONS: True factory DRL function – Included wire harness and controller provides hands off automatic operation. (Ignition key on, DRLs turn on. Key off, DRLs turn off). Edge SE Owners (without factory lights): - Our EDGE-2 DRL system is the perfect solution. - The EDGE-2 DRLs comes with a kit with everything you need to easily replace those boring black plastic covers High Tech Optics: - How do you produce a wide horizontal beam of light from a vertical light? With sophisticated optics. Our engineers spent many hours designing the bright chrome reflector with even more time spent in designing the crystal clear lens. We molded five vertical prism bands into the lens to help refract the vertical light horizontally. These features allow our DRL to achieve an incredible 140 degree beam spread making your Edge more visible to more drivers. LED Vertitcal Turn Signal Light bar (Truly UNIQUE) -Crystal clear light bar – Provides a clean, modern and uniform overall look of the DRL (no out-dated amber plastic lens), retaining the look of the original Ford accent light pipe. -High power amber LEDs – We use high power Osram LED chips with custom optics to produce the brightest and widest light beam, providing the highest visibility. Exclusive Headlight Dimming Function: - Our EDGE-2 DRLs automatically dim to 70% of full brightness when the headlights are activated - Provides a stylish accent light, many times brighter than the original factory Edge accent light. - We incorporated this exclusive feature to avoid blinding oncoming drivers with our DRLs at full power. (Turn signal LEDs continue to function at 100% high brightness). Items included in Kit: (Everything needed to install your new EDGE-2 LED DRLs): - 2 each, EDGE-2NA vertical LED DAYTIME Running Lights - 1 each, DRL Controller & Wire Harness - Installation connectors and wire ties. Tools required: - Screwdriver and pliers (yep, that’s all you need). Specifications: For use with 12V vehicles only Total Power Output: 18W DRL LED Color: White ~6000K Number of white LEDs: 12 Number of Amber LEDs: 12 Total number of LEDs: 24 100% SATISFACTION GUARANTEE: If after 14 days of receiving your EDGE-2 DRLs, you find you are not completely satisfied, return the kit to us in good condition with original packaging and we will refund your entire order amount, including the original shipping charge! One Year Full Replacement Warranty. DAYTIME BrightLites, LLC "We make your stock lights BrightLites" Contact us at info@DAYTIMEBrightLites.com
- 31 replies
- 2
- bumper strip
- bumper led
- (and 8 more)
Right now, I am going to stick to my earlier statement and policy, that the EDGE-2s should not be wired in any other way (other than the use of the OEM plug) then what is stated in the installation instructions. (white trigger wire to headlights, black trigger wire to turn signals). I am looking into the alternative wiring methods that have been brought up here, but until we determine whether these methods are OK or not, I cannot recommend them. If we OK these wiring changes, you can easily reconfigure the wiring at that time.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
Thanks for the info on your temperature tests. The concern I have about having the amber LEDs constantly on as DRLs, is not damaging the LEDs themselves or the housing, but damaging the electronic compenents of the inernal controller. The additional heat from running the amber LEDs continuously may not be enough to melt the plastic components, but could damage the DRLs controller circuits. Again, I strongly recommend not configuring your EDGE-2s in a way that allows the amber LEDs to run continuously. Just want to confirm that it is perfectly safe to connect and power my EDGE-2s using the existing OEM plug. You will loose the automatic DRL function, but if turning the EDGE-2s on and off manually each time does not bother you, then you are in good shape. Concerning Edges with the amber parking light DRLs, I am working on a wiring method that will allow the EDGE-2 turn signal to function properly. Hope to wrap that up very soon. My Canadian friends here are on the forum are helping me find this work around.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
Being able to power my Dr L's off of the factory wire harness plug would make the install much easier and help reduce the cost a bit I'm not having to provide a wire harness relay. would any forum members that work for Ford or that works for dealership, mind commenting on whether reprogramming the computer setting to allow the vertical lights 2 function as DRL's would actually Void the warranty? I don't see how changing a setting that in fact can be changed, would void the warranty. maybe I could see it, if you actually have to create your own custom code, but if its just a matter of selecting a pre-configured setting, then I am skeptical that it would affect the warranty.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
That would be awesome Norm. I can't wait to hear what you find out. Can you see if they would give you the detailed procedure and any of the specific code numbers and/or settings so that customers can take the info into their own Ford dealer to make the change? There's no sense in every Ford dealer's service department having to reinvent the wheel to make a simple programming change.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
If you look closely at my install video, you can see how chewed up my bumper tabs are after installing and uninstalling over 3 dozen times. You all don't need to worry about this happening with just a couple of installs. I am still using the orginal stock clips, so the clips will last forever. If some of the tabs get bent, you really don't have to spend a lot of time trying to get them back in position perfectly. They will still grip hard.
- 326 replies
- LED light bar
- LED strip
(and 4 more)
So glad you like your new EDGE-2 DRLs. You are so right about not being able to get the true look of the lights from photos or video. The camera just cannot capture it. That's one of the most difficult things about marketing them. Having HIDs does not affect the function nor the installation of my DRLs. So no need for concern on that. Can't wait to see the pictures of your Edge with the new lights shining. :-).
- 326 replies
- LED light bar
- LED strip
(and 4 more)
