                Posts139
                Days Won6
Everything posted by xK317Hx
	If you use the arrows on the left of the wheel you will scroll through more menus. Those indicate more options in that menu.
	Well Friday my camera decided that every other time I get in the car and back up the image would be upside down and not have the guided lines. It did this all day on Saturday too. Tonight it's just gone black no "see dealer" image just black and it will still beep of I get to close to something. I found a TSB for the upside down thing happening in cold weather does anyone know if that TSB would apply in the summer??? Really can't afford a big repair bill right now if the system has to be replaced.
	  2015 Ford Edge Introduced - Edge Going GlobalxK317Hx replied to LI Edge's topic in Articles, News & Reviews Nice video. I have better hopes for the placement and angle of the MFT screen after seeing it with people in the car. At first from the promotional photos it looked kind of high on the dash.
	  Wiring for Paddle Shifters - Sport & non-SportxK317Hx replied to omar302's topic in 2011 Edge & MKX Does the gear selector have the thumb button for shifting while in select shift mode? Maybe trace those wires to see where they go.??
	  2015 Ford Edge Introduced - Edge Going GlobalxK317Hx replied to LI Edge's topic in Articles, News & Reviews ALSO THANK YOU GOD FOR PUTTING THE INTERIOR DOOR HAND IN THE RIGHT SPOT!!!!!! LOL
	  2015 Ford Edge Introduced - Edge Going GlobalxK317Hx replied to LI Edge's topic in Articles, News & Reviews I'm kinda of disappointed in the center stack compared to the concept. Also was really hoping for a different gauge cluster instead of the cyclops we have now. I don't really care for the lower front facia of the sport but I will probably end up with the sport as I do think that engine is going to be fun.
	No.
	2011 edge with MFT. iPhone 5s. I receive all my texts and MFT will read them to me. I reach down hold the home button on the phone and ask Siri to reply to last text when replying.
	  Seat Heater Replacement AdvicexK317Hx replied to evh's topic in Interior, A.C., Heat, Interior Trim Unplug battery. Unbolt seat from floor. Lean seat back unscrew seat pan. Pop out any cable routers. Unplug green heat pad plug. Pull lower cushion off. Remove leather cover. Replace entire cushion.... It will rip apart of you try and pull the heat pad off. Install new cushion in reverse order.
	  Seat Heater Replacement AdvicexK317Hx replied to evh's topic in Interior, A.C., Heat, Interior Trim In my 2011 the pad is glued to the faom seat cushion. Lower and upper are seperate. I ordered the new lower cushion from here http://fordpartsdiscountoutlet.com/ford/edge-parts/
	Very nice! The only thing is I wish the new tails had the same "aero" shape on the exterior surface as the factory tails. Other then that these look great and seem very functional.
- 58 replies
		- LED taillight
- LED tail
- (and 8 more)
	Overlaying side profiles from the 11 to the concept I can see what they've done around the rear quarter window to give the illusion of less cargo area. I had the same conversation with a friend about the escape.
	Get ready for all the "hey look it's a Hyundai Santa Fe" comments. Personally I think it looks good...I could do without all the dead space on the rear below the taillights though. I attached a little gif of the current and concept morphing.
	  Ambiant lighting keeps coming back onxK317Hx replied to cnysport2011's topic in Audio, Backup, Navigation & SYNC I noticed whatever color you have it set to Will default to the lightest blue when you exit the vehicle.
	  Front Grill Paint - Opinions Wanted!xK317Hx replied to bullitt#193's topic in Accessories & Modifications Satin gunmetal
	If you want full maps with turn by turn you need to go back to the dealer and trade it in for one with nav. As far as I know you can't just add it.
	Also take the "e" out of the link you posted. That doesn't look like fords site it should be syncmyride.com
	Sounds like you don't have the GPS option with full maps and such. If your top right corner says "information" and not "navigation" then you don't have it.
	  BRAKE PADS...to many options, where do I start?xK317Hx replied to hehateme2812's topic in Brakes, Chassis & Suspension I've always been a fan if hawk pads. Is there any options for non factory rear rotors?
	Just to clarify, mine went through the update and when I got the prompt to hit ok to complete the install I did but then it went black screen on me. No radio audio or anything. Let the car run for about 30 -35 mins then turned it off/on and everything was fine.
	Thanks I let it sit for about another 20mins and still nothing. So I decided to turn it off for a few and then back on. Came up with a reg maintenance screen as was good to go.
	Awesome the update just black screen mine no response for 15min. Anyway to do a hard reset with a black screen?
	I've noticed that the Edge tends to have a tad bit more rear leg room that takes just a little from the cargo area. One of the reasons I got the Edge actually.
