Driver floor is SOAKING WET
WWWPerfA_ZN0W replied to Blue_Edge15's topic in Interior, A.C., Heat, Interior Trim
Do you have a sunroof/BAMR, Stratoblaster? Clogged drains in the sunroof have been down to lead water down into the passenger side of the cabin in the Taurus.- 480 replies
- missing floor grommet
- new Ford owner
- (and 3 more)
Any how to's for the VTA mod floating around specific to the Edge?
WWWPerfA_ZN0W replied to LNCHBOX's topic in 2.7L EcoBoost
Corrected that 4 ya -
Welcome, looking forward to seeing pics of your new ride when it comes in!
Welcome, great story and gorgeous color!
What warranty do I have on Motorcraft/Ford batteries?
WWWPerfA_ZN0W replied to trockli's topic in Recalls, TSBs & Warranty
That post is solid gold, omar, thank you! trockli, you need a new dealership to work with Anyway it seems we need to move up to agm batteries to get a good service life these days. -
Is the 2014 new to you, toast? Is it an Ecoboost or the 3.5L engine?
The first generation 2.0EBs are notoriously dirty engines. Using full synthetic low volatility oil is a good preventative.
It's supposed to go to alternate cylinder firing, thus initiating air cooling, when such an overheat occurs. Of course, this is very limited protection, and am glad it worked out for you!
Chronic Dead Battery Issue is Back?
WWWPerfA_ZN0W replied to JackJack's topic in All Wheel Drive (AWD)
It is definitely a frustrating issue. I would put a device on the battery to shut off all :accessory" power after a certain amount of drain. As a failsafe. Too many modules, and shifter, and CD player, etc. that are in play. -
They should have pulled codes at least, but anyway, let's see how long this paradise lasts ... Any chance they updated the PCM or disconnected the battery for some time prior to your experiencing the rough idle issue?
Shift to Park Warning when it's in Park
WWWPerfA_ZN0W replied to AmyLovesHerEdge's topic in All Wheel Drive (AWD)
Thank you If you have any pics and could upload them, that'd be a bonus! -
I would first exchange out the power steering fluid with good fluid. I know macbwt used Mercon LV in his 2011, but the spec is still Mercon V. Your choice. All you need is a turkey baster, a used oil receptacle, and at least 1 quart (pref 2) of Mercon V. Suction out the old fluid (engine off). Do not take out so much fluid you cannot see it in the bottom of the reservoir anymore. After filling the new fluid to the FULL mark, turn the engine on and work the steering wheel lock to lock a few times. Then repeat the process a couple more times. Should be good after that. Let's see if it makes a difference, I think it should.
Sorry to hear about the incident! Hope they get it fixed up good as new. -
2013 Ford Edge Sport TCO after 3 years
WWWPerfA_ZN0W replied to arabski's topic in Owner Impressions
Good info :thumb: Hope you will be getting into another Edge soon! -
Bad batch? -
That would be long enough to "lose touch" with the feel of the Edge steering. Some vehicles have more assist than others, and when I first started driving mine, it took me a while to get used to it. That aside, did the fluid look clean, didn't smell burnt, etc.? If that is good also, then maybe the feel will loosen up with some drive time. Cars really don't like being stored for long periods of time. They have to be exercised regularly to "stay in shape".
This thread may be of some help to you: http://www.fordedgeforum.com/topic/12851-brightest-leds/
If you use a polish, use only finishing polish so as to protect the clearcoat.
Corrosion happens in the absence of battery protection products/felt pads. Clean it up good and away you go. Not sure why it appears that blue, might have more copper in it than normal. Hopefully it is not bad enough to have to replace terminals/cables. As far as warranty, since the dealer installed it, it should have the longest warranty offered by Ford (7 years?), IF you paid for the battery. Otherwise, I am not sure ... should at least clean it up 4 u. If not replace it entirely. Make sure they do a load test on the battery after cleaning it up, in your presence. -
I will add Kwik Stop/Kwik Star to the list of "good fuel" places. And in my area, Sunoco and "discount" brands are selling at the same or GREATER prices than top tier like Shell & BP. World upside down or what LOL.
Very encouraging, all this without a tune
