P/N FT4Z-6111600-AB I think.
Could probably do backward facing seats?
Do I really need new rotors at 60k?
WWWPerfA_ZN0W replied to normcloutier's topic in Brakes, Chassis & Suspension
Telling it like it is -
2015 Edge Sport broken trans/PTU?
WWWPerfA_ZN0W replied to redlancer's topic in 2015+ Edge & MKX Generation II
More than likely PTU, it is not engaged in P or N, but is in all other gears. -
Thats why you get the Edge with the BAMR LOL ...
What does a P0016 have to do with water pump failure? Video
WWWPerfA_ZN0W replied to macbwt's topic in 3.5L
Sorry to hear hill! This is an event with rather catastrophic results unfortunately, and not enough owners are aware ...- 10 replies
- p0016
- water pump failure
(and 3 more)
Pretty sure it is not removable
It would pull the vaporized oil-fuel mixture out of the mix, but it would not prevent fuel from continuing to get into the oil past the rings. The fuel would already have contaminated the oil in the crankcase, but the catchcan would allow intake "air" to be that much cleaner, also reducing carboning of the intake valves in the process.
AWD by any chance? Sounds more like PTU/driveshaft issue if so.
What actually have been change in 2017?
WWWPerfA_ZN0W replied to t0lkman's topic in 2017-2018 Edge & MKX
Apple CarPlay and Android Auto -
That is for the 2011-14 Edge, and I believe for the 2010 up Taurus, etc.
Welcome & congrats, great lookin' ride!
An older thread, but still useful http://www.fordedgeforum.com/topic/12362-ford-logo/
EBay is the most popular source, I think there are a couple of recommended vendors named by members of this forum, hope they chime in.
The blue does fade over time, it seems quicker in some vehicles than others. Some take it apart to repaint, others get stickers or simply replace the emblem entirely.
A Little Nervous...need your reassurance
WWWPerfA_ZN0W replied to Buddylee1114's topic in Welcome Forum!
Welcome to the community, BuddyLee, nice ride! The first thing I have to ask is do you have a Ford extended warranty. It is hard to say if the miles are highway or city miles, what the balance is, but a lot of people give up their rides either becoz they are out of warranty, or major but routine maintenance is beginning to crop up. Coolant, spark plug, and pcv valve come to mind right away. A drain and fill of the transmission fluid is also highly advisable. This will give you a known starting point, and worryfree miles of smiles. Is your Edge AWD? -
The hub bore is the main problem, as it is too small to fit on the 2007. The 2007's hub bore is 70.6. So you would have to bore out the PI wheels or find adapters to fit. Don't know how well the adapters would work out though.
Looking for advice on new A/S tires - Michelin Premier LTX?
WWWPerfA_ZN0W replied to trockli's topic in Wheels & Tires
Let us know how the tread life works out on the Spec X's. -
Hope the steering feels lighter & more responsive as well! -
There are different levels of Techron products. For longterm cleaning (ie 1 bottle in 3 months to a year), you would use Techron Concentrate Plus, for example. If you were throwing Techron ProGard with the non top tier fuel, that would probably be better, but even then it would go for 1,000 miles, no need to do with every tankful. Can't say nonTT fuel + Techron = Chevron, but it certainly would be a much improved product. Since the base fuel is only produced by a few refineries, and the main difference is detergents, you would think so, right? But with any station, the difference is going to be the transport tankers and how well they are maintained. Never pump gas if you see the tanker at the station. All the sediment in the tank will have been stirred up and will end up in YOUR vehicle's fuel tank. Ugh. Instead, I WOULD use synthetic marine oil like TC-W3 or the Marvel Mystery Oil, usually at 1 oz of the product to every 5 gallons of fuel pumped. Add before pumping fuel, first tank doesn't matter, but if you add on the second tank as well, then you need to know how much to add. These products burn cleanly and have lubricating properties that help injectors and fuel pumps stay happy despite winter fuel. Always look for a busy station because even if non Top Tier, the fuel has had less chance to go stale/pick up contaminants from the storage tanks.
Traction Control Lost Its Mind !!
WWWPerfA_ZN0W replied to grantmcf's topic in All Wheel Drive (AWD)
Didn't you own an edge in 2012? And it's kinda hard for anyone to help you when you generally don't respond to their comments/questions. The Edge has AWD, not 4WD, but still should have worked on slick roads. Sometimes it will get all confused because it can't find traction on any wheel, in which case turning off Traction Control is needed. There might be electronic gremlins in your Edge, though, ones the computer does not know what to do with. Which Ford dealer did you go to? Lithia Ford or somewhere else? -
Driver floor is SOAKING WET
WWWPerfA_ZN0W replied to Blue_Edge15's topic in Interior, A.C., Heat, Interior Trim
Do you have a sunroof/BAMR, Stratoblaster? Clogged drains in the sunroof have been down to lead water down into the passenger side of the cabin in the Taurus.- 480 replies
- missing floor grommet
- new Ford owner
- (and 3 more)
Any how to's for the VTA mod floating around specific to the Edge?
WWWPerfA_ZN0W replied to LNCHBOX's topic in 2.7L EcoBoost
Corrected that 4 ya -
Welcome, looking forward to seeing pics of your new ride when it comes in!
