Welcome back from the MIA zone Did you ever get an LED light bar put on? -
New 2017 Edge, loaded, day1 notes
WWWPerfA_ZN0W replied to jlkansascity's topic in Buying, Leasing & Ordering
Congrats on the new ride, put up some pics! I find it very mysterious there being no mention of FWD vs AWD, so I am guessing you went with FWD, judging by tank size -
This was taken under 87 gas, right? Was engine warmed up at the time? I would like to see similar graphing, along with engine temperature, for 93 gas. Also set all O2 sensor readings to V, not mA, for uniformity. It seems like Bank 1 has issues being a little rich at idle, which I would attribute to possibly a mildly leaky injector (s) or spark plug gaps getting too large. 93 may be helping with those issues. How many km on your Edge? Might be ripe for a plug/PCV valve job. The smell is strongest at the driverside wheel well, you said, is why I am not suspecting PTU, especially without visible leaks. No harm in fluid exchange however. Check the PTU-driveshaft seal carefully, as there can be a leak from that area also sometimes.
Helps to be aware and proactive. Well done!
The EVAP purge valve, got it Will look at the graphs when posted.
17". Checking on Tirerack.com is usually the easiest way to confirm. http://www.tirerack.com/wheels/results.jsp?autoMake=Ford&autoModel=Edge+SEL&autoYear=2013&autoModClar=FWD&package=false
Just to confirm, this is the purge valve underneath the Edge, next to the canister itself? Good find, hope it is the longterm fix!
Somewhat early to have this issue! You can try unplugging and reseating the solenoid connectors. Then disconnect the battery for 30 minutes/clear the code. See if the code comes back. If it does, then at the very least both solenoids are likely to be needing replacement. What type of oil/filter do you run in the Edge, and what are the change intervals?
Looks like an album from SEMA LOL.
Speed adaptive volume
WWWPerfA_ZN0W replied to wildbillpookers's topic in Audio, Backup, Navigation & SYNC
Well, that's a humdinger. Maybe your dealer can figure it out together directly with Ford Customer Service. Just like they did when one member was having problems with a backup camera that required a software update directly from Ford. -
Do I really need new rotors at 60k?
WWWPerfA_ZN0W replied to normcloutier's topic in Brakes, Chassis & Suspension
Based on your evaluation of the rotor condition, I'd say money grab. Much more important to service the calipers, make sure the brake fluid looks good, etc. -
I assume you have Torque Pro, so you have datalogging capabilities. But if you want to screenshot, this is the bare minimum to look at: SPEED RPM O2 sensor Bank 1 Sensor 1 O2 sensor Bank 1 Sensor 2 O2 sensor Bank 2 Sensor 1 O2 sensor Bank 2 Sensor 2 Long Term Fuel Trim Bank 1 Long Term Fuel Trim Bank 2 Short Term Fuel Trim Bank 1 Short Term Fuel Trim Bank 2 one at idle after startup, one at idle after engine is warmed up (190F/88C + degrees), and one at speed/cruising after engine warmed up. This should tell us, in general, if there is a fuel/ignition issue we need to look at. We are getting more users reporting in with "bad fuel" issues, so that may also be in play. I would normally suggest using Forscan Lite, as it is a better/more powerful tool than Torque Pro, but with a less friendly user interface. Hopefully won't need it.
Did you purchase from a Ford dealership? Do you have a Lincoln dealership nearby? That's one diagnostic option. I would agree with raw fuel in the cats being a possible problem here. You may need to replace all injectors along with spark plugs to fix this. Hopefully the coils are OK.
Well in that case bore sdapters should work fine.
Isn't yours a 2015+? You can use adapters for the bore, but the lug pattern is also different. So IDK
Should be in the MENU for the head unit. Menu Structure Note: Depending on your system, some options may appear slightly different. Press MENU. Press the up and down arrow buttons to scroll through the options. Press the right arrow to enter a menu. Press the left arrow to exit a menu. Press OK to confirm a selection. Audio Settings Speed Compensated Volume Automatically adjusts the volume to compensate for speed and wind noise. You can set the system between 0 and +7. -
I'd do the stripes on the Edge, if I could get the GT hood on there :D
I don't see a working demo with fog lights, are they projectors or just blanks?
Forscan users test Silent Mode Function?
WWWPerfA_ZN0W replied to jmr061's topic in 2015+ Edge & MKX Generation II
Many people like driving around with minimal light intrusion in the cabin, whether for privacy or to keep kids asleep etc. Used in police cars on a regular basis as well. -
The only set I would get is from http://drivebright.com/home/shop/ford-edge-led-tail-light-set-standard/ http://drivebright.com/home/shop/ford-edge-led-tail-light-set-lh-rh-complete-replacement-tail-light-assembly/ They are on sale right now. Look for other products you might want from them as well.
A group 65 battery from Motorcraft Tough Max series, or if you can swing it an AGM type group 65 battery from Odyssey. AGM battery lifespan is typically 7 years or more. If it gets cold enough in your area, also use a good full synthetic motor oil with 0W20 viscosity rating. Full synthetic 5W20 recommended year round. This is for the 3.5/3.7 engines. For the 2.0 Ecoboost, 0W30 or 5W30 is appropriate. Mobil1, Pennzoil Platinum, Quaker State Ultimate Durability etc. Amsoil is more expensive and not sold in stores, but that is my preferred goto.
Inspect all the plugs and coils carefully. If not replacing the #1 coil, move the 123 coils to 456 and the 456 coils to 123. It is suspected that extra heat trapped in Bank 1 degrades those coils faster. So even if they are working fine now, you could prolong overall service life with this swap. One thread with useful info on spark plug replacement (might be a bit different for the 2011-14 3.5s on exact details): http://www.fordedgeforum.com/topic/8724-sparkplug-replacement-job-info-with-photos/ The misfire can also be caused by a dirty injector, so run some Techron Concentrate Plus or BG 44K cleaner through the tank first. Winter fuel isn't the best to begin with and using fuel from non-top tier gas or not-so-busy gas stations can result in water & contaminants in the fuel. Definitely, cylinder 1 is a weak spot, but it is also at the end of the fuel rail, where such contaminants tend to accumulate.
Cabin filter. Mildew on evaporator. Clogged evaporator drain vent. These are the most common reasons for such smells. So take out the cabin filter. Run Lysol through the system with heat on high for 30 minutes. Check again. Disconnect the evaporator drain line at the joint behind the carpet at the driver side footwell. Blow some compressed air through it. Once confirmed clear, reconnect the joint. Put in a new cabin filter and retest.
