Revved up with anticipation over here! Best of luck with all these fixes, you are working MG overtime -
Yeah, you are caught in this insanity, feel for ya! At least they gave you a decent sized rental, many people are stuck in sub or sub-sub compacts True, no substitute for the Edge. Will they at least put it under cover or something? Or will you have to go there weekly to wash & wax it?
Windshield Wiper & Windshield Washer Problems
WWWPerfA_ZN0W replied to EdgeofKnight's topic in 2012 Edge & MKX
Most likely the multifunction switch is bad and needs replacement. http://www.fordedgeforum.com/topic/17087-wipers-stuck-on-intermittent/?do=findComment&comment=123058- 1 reply
Can someone help diagnose this leak?
WWWPerfA_ZN0W replied to wlepse's topic in All Wheel Drive (AWD)
How much is the fee they are asking? If they find something covered by warranty, they probably will waive the fee and you will pay deductible if any. -
Did the dealer check with ford to see if there is a software update for the camera that might fix the issue? Any other dealerships (including Lincoln) that you can try? I had hoped some folks from NJ would chime in on places to try for good service.
So you had more than 50K on the Edge before the PTU issues happened? The PTU issues do seem to not have been resolved. It might be as simple as extending the vent into the engine bay, and adding a bit more fluid, or it may take regular change intervals of say 25K - 30K miles.
Answeres for all Audio/Video questions
WWWPerfA_ZN0W replied to Vfords's topic in Audio, Backup, Navigation & SYNC
Do you have a link to this player, Feirstein? Would like to upgrade my system at some point, and would be nice to get the hirez in play -
Driver Side Door Mirror
WWWPerfA_ZN0W replied to Gary W.'s topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Sounds like a memory seat/mirror function. Do you have that feature on your Edge? -
May be why there is a delay in supply of new-design tanks as well.
Did Ford Owner Website Screw Up Again?
WWWPerfA_ZN0W replied to ls973800's topic in Owner Impressions
Sometimes they update and move stuff. Such as with owner manuals online. May re-appear in a day or two. Definitely could be more communicative/user-friendly in their change management. -
Do document everything, whatever costs related to this issue especially for later reimbursement. Contact Ford Canada, do they have a Lincoln Canada? Lincoln is worth trying if Ford doesn't work out. You should lodge a complaint with Ford regardless so they can't say they didn't know about it. I can't find aftermarket tanks either right now for the Edge, but will keep looking. Is cross-border pickup an option for you? Otherwise Levittown can ship to CA.
Nice! Torrie is one of a kind when it comes to tuning & customer response
Apparently, it's not a "fatal" error for the stock tune to have this particular category of code, so the vehicle can continue to run fine. Diagnosis is the same. Update calibration, check PCM wiring/connections. If code still present, replace PCM. So most likely, MPT is not using the correct strategy code, or the PCM was updated after the last time you pulled the code to give to the tuner.
Hope they can get it straightened out for you. Torrie is 24/7 (crazy guy) practically, don't know how he does it. Do you have any mods on your Edge that might need to be accounted for in the tune? BTW, you are SURE they used the right strategy code? Worst case, PCM might need replacement. From the FSM for 2007: P060A - Internal Control Module Monitoring Processor Performance Description: Indicates an error occurred in the powertrain control module (PCM). This DTC is set in combination with P2105. Possible Causes: Software incompatibility issue Damaged PCM Diagnostic Aids: Verify the PCM is at the latest calibration level. Application All Continuous Memory GO to Pinpoint Test QE QE18 CHECK FOR CORRECT PCM OPERATION Disconnect all the PCM connectors. Visually inspect for:pushed out pins corrosion Connect all the PCM connectors and make sure they seat correctly. Carry out the PCM self-test and verify the concern is still present. ============= PROM - Programmable Read Only Memory: Customer Interest Engine Controls - MIL ON/DTC P060A/P061B/P0600/P2107 TSB 09-13-6 07/13/09 MIL ON WITH DTC P060A, P061B, P0600, P2107 AND/OR U0300 FORD: 2008-2009 Focus ISSUE Some 2008-2009 Focus vehicles may exhibit a malfunction indicator lamp (MIL) on with diagnostic trouble code (DTC) P060A (internal control module monitoring processor performance) or P061B (internal control module torque calculation performance) stored in the powertrain control module (PCM). DTC P0600 (serial communication link), P2107 (throttle actuator control module processor), and/or U0300 (internal control module software incompatibility) may also be present. ACTION Reprogram the PCM to the latest calibration using IDS release B61.10 and higher or B62.01 and higher. This new calibration is not included in the VCM 2009.7 DVD. Calibration files may also be obtained at the website. WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part. OPERATION DESCRIPTION TIME 091306A 2008-2009 Focus: Check 0.3 Hr. For DTC1s And Reprogram The PCM (Do Not Use With 12650D, 12651D, 12651D4) DEALER CODING CONDITION BASIC PART NO. CODE RECALEM 04
Let's see if it helps at all. Were the fans running in the parking lot?
Then it must be the pet raccoons body slamming into the Edge in preparation for Wrestlemania! Maybe someone tried to hack into the Edge with some sort of rudimentary tool? An implosion of some sort (can't think of a reason why)? I looked on my driverside door, no issues.
Form letter response. Sorry, but I have not seen Ford of Canada really prove a positive relationship with their customer base.
I see sawdust has a taste for the Orange Crush No rattles and no winking allowed! -
Just completed a mostly highway circuit this AM (30 min in all), temps rarely above 192F. Even with idling for a couple of minute, temp didn't rise at all. 40F day. Not windy, rainy though.
Led Puddle Lights
WWWPerfA_ZN0W replied to Muser99's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I guess we can now refer to the OEM lights as "nostalgia lighting" or "gaslamp lighting" No puddles can escape these babies! -
The testers are at least 5x the price of the cap Basically a pump with adapters that fit a variety of radiators/degas bottles + an accurate gauge is what you are paying for. Even Harbor Freight's kit is $84! You CAN get a MITYVAC kit for $35. Maybe AZ or AA rent these things out? Maybe they can check the old one at the parts counter? Check for codes while you are there. For reference, the FSM recommends the UView 550000 (pressure tester) and 560000 (combustion gas tester) units. I am still concerned that the coolant level does not rise above cold full when engine is hot. Pls doublecheck carefully, it may not be a whole lot, but there SHOULD be some difference, maybe a 1/2 an inch or so.
Don't remember, did you change the degas bottle cap by any chance? If it is not holding pressure, the cooling system won't work as well.
