enigma-2
    294
  1. Makes you wonder "how" this nut got loose..... ummm?
  2. Definitely a large difference between the two. Mercon V Recommended by Ford for use in Ford, Lincoln, and Mercury vehicles that require Mercon V or Mercon type fluid. It can also be used in most pre-2006 GM vehicles and many imports. Mercon LV Stands for "low viscosity" and is fully synthetic. It has excellent low temperature properties and shifting characteristics at high and low temperatures. It's also backwards compatible with previous generation Dexron fluids. However, Mercon LV is not compatible with earlier Mercon fluids, such as Mercon V, and should not be mixed with them.
  3. I was looking in other forums. A few stated that it would work (pressing the vol) others said wouldn't. Think they had different radios. Couple (back in 2022 or 2023) said it worked after a software upgrade ( why i mentioned it.) There's probably no way it can be done on your radio. Pressing & holding the volume knob was to only way I've ever read about (other than those radios that had a dedicated knob for it.) The only advantage I've noticed on mine was it makes the interior of the car dark at night. But, I usually leave my navigation running when I'm on the road. (On my Sync 1 system it's called "Display". On/off/status bar.)
  4. Just looked at the Ford Accessories Ambient Light Kit and it only fits 09 through 19. So the factory kit doesn't fit. Wonder if there are there any aftermarket kits that would fit his 2022 SEL?
  5. This became a problem about a year ago due to an Easter Egg accidentally added by Ford during one of their updates. It was eventually fixed with a follow-up update. Did you have an update recently? With that problem, users were setting their clocks to 24 hr display and it automatically switched to the 12 hr. Ford was monitoring those forums and churned in to offer assistance. Don't think that Ford is no longer monitoring this forum, so you need to report this to get them to work on a fix.
  6. Try pressing and holding the volume knob while simultaneously rotating the volume dial. (This may not work on the Edge.) Seems like Ford could enable this in a future software update. .
  7. Have you tried pressing and holding the volume knob? Works on some cars. If it works, it takes 2-3 seconds to activate. I have a hard button on my 2009 MKX for this. Never use it personally.
  8. There is a "rectangle" right above/next to the main headlight cover, which is a one-way vent. Supposed to let the moist air out (think of moisture as a pressure) but prevent air from entering. Usually driving with your headlights on will produce enough heat to dry out the fixture. Others that have had similar problems, replaced this vent and used a hairdryer to dry out the interior. Another possibly is the seal around the two halves of the headlight has cracked and is letting moist air in. Fix is to run a bead of clean sealant over the joint that connects the two haves.
  9. What year car? Are you thinking that the lights come on only with the parking lights, or function normally and also with the parking lights and ignition off? Edited; Was reading about the kit on Ford Accessories.com. Set your own mood – and choose your preferred interior LED lighting color – with this Interior Light Kit. It includes a LED-generated light in the cupholder area, and separate light bars for the front wheel wells. Surprised to learn that the interior light kit also included light bars for the front wheel wells. (My factory lighting doesn't have these.)
  10. My Lincoln dealer uses the RDU vacuum equipment to suck out the PTU fluid and pump new fluid in. Something like this might mat the job easier next time (I havent actually used this, I'd rather pay the dealer to do it.) Thorstone Automotive Fluid Extractor Pump with long rubber hose, Oil Change Syringe with Hose, Manual Fuel Suction & Filler, Fluid Oil Change Evacuator (7 Oz./0.21 Qt./200 CC) https://a.co/d/4f4gFIf
  11. What's wrong with your blower? If it's just noisy, try lubing the bearing first before replacing the motor. Mine was getting noisy, I dropped it lubed the bearings. Still quiet over a year later.
  12. 86k sucks. You would think that the leasing agent would take care of maintenance. Oil changes but not coolant. Maybe the previous owner thinking it was a rental and their going to get rid of it after a couple, beat the shit out of the car. (?) My dealer drops the subframe to change water pump on all Edges/MKXs. Said it's faster. Think he quoted $2600 or thereabouts. Probably over 3k now. Its hard to give up a car you love when all it needs is a RDU. If it were me and that's all that's needed, and you already have a new unit, no question that puppie gets a rear end.
  13. I worried about the wp failing, and talked to one of the mechanics at Ford service department that I trust. He said that the failures were mainly happening in 07-08 engines and related to poor maintenance. Customers not getting oil and coolant changed on schedule. (The 07-08 engines were shipped with the old gold coolant. Ford also found that on engines built before 04/01/2008, the water pump inlet tube was susceptible failing due to coolant corrosion.) While he admitted that all water pumps will fail eventually, he said that they should go at least 200k or more with proper maintenance. (Mactfordedge has several YouTube videos where he ran Lulubelle over 300k without a failure.) Wish I could say that about the PTU ....
  14. Thought smurf snot was gen x slang for the color your snot turns (blue) after snorting adderall. Tish, tish Cerberus .... 😊
  15. Apr 25 2018 6410 - 2014-2019 Various Vehicles - Equipped with a 2.7L and 3.0L GTDI Engine - Oil Pan Leak. Some Ford and Lincoln vehicles equipped with a 2.7L or 3.0L EcoBoost engines may exhibit an oil leak from the engine oil pan RTV seal. Replace the oil pan by performing the published Workshop Manual (WSM) service procedures. After removing the oil pan, it is suggested to allow the crankcase to drain overnight to minimize the chance of residual oil contaminating the crankcase sealing rail. Remove all traces of old RTV, clean the engine sealing surface with only Motorcraft® Metal Brake Parts Cleaner then wipe with Motorcraft® Metal Surface Prep Wipes, and allow to air dry as directed in WSM, Section 303-00, RTV Sealing Surface Cleaning and Preparation. If possible, after the new oil pan is installed, allow the new RTV sealant to cure for 4 hours before refilling the engine with oil. Ford is investigating this concern. Monitor OASIS for future updates. Just to replace, between 2-3 hours. But following the Ford procedures above .... I'd call local dealer and get a quote. Metal with gasket is probably better, but you'd probably pay double.
  16. Yes. Any circuit that's active when the car is off, such as circuit #1 for example. But if the camera is always on, wouldn't this drain the battery?
  17. Wonder what they are using for "synthetic media"; some type of plasitc? With motorcraft you don't have to question, you know it's good enough. What kind of metal? Metal can corrode. Plastic is not as strong but doesn't corrode. Personally, I would stick with Motorcraft. Delco is also a good brand. Can't go wrong with either. Still thinking about having local dealer change my 3.5 water pump as a proactive measure. Thought I'd do this around 150k but service manager felt I could go 175k before changing. It'll be Motorcraft of course 😁
  18. Follow up. Just happened to my daughter's 2013 Escape. She ran it over to local Ford dealer, insisted they fix it (she's bullheaded as he'll, have no idea where she gets it from). Mechanic came out, his wife is a teacher at same school where she works, so she trusts him, and he told her to just to rip it off as it's unneeded. Said its really for looks. He said that he had removed his, on both their cars. So she had them rip it off, didn't charge her and now she's happy.
  19. Toms Oil did testing on oil filters years ago, Fram was one of the worst. Mobile One was the best (and most expensive), Motorcraft was second and still rated excellent. GM Delco was also rated excellent. (Mopar was an aftermarket filter.) Can never go wrong with Motorcraft parts.
  20. You should be aware that Ford sells an add-on kit for four front sensors, wiring and a module. I looked at having my local dealer add this option years ago and decided that drive by feel was just as effective. If I remember correctly, I think the dealer quoted me 3 hours labor + price of the kit. It involved drilling holes in the bumper cover, installing the sensors, running the wiring harness and revising the body control module software to accommodate the circuit and register the upgrade with Ford (or Lincoln as in my case) for future software upgrades. I don't believe that you can just add additional sensors to the existing module because it's only energized in reverse, and the front circuit is only energized in drive. (Plus there's the question of how much load these modules are designed to carry.) There are also aftermarket, wireless kits available and don't depend on the BCM. (Yuck pooee.) Suppose you could always drill holes in your cars side to mount sensors. (Good luck on that.)
  21. $250 ($270 if you want them with "EDGE" or "ST" ingraved in them. Fairly easy install. Red and other colors. (Ough, ough yellow .... 🙂 Can download installation instructions to see if this is something you can do (fairly easy as these are just covers.) Requires 20" wheels for the 19 ST. https://www.calipercovers.com/product/mgp-brake-caliper-covers-10247sclcrd-10247smgpbk-10247smgprd-10247smgpyl-10247sedgbk-10247sedgrd-10247sedgyl-10247sst1bk-10247sst1rd-10247sst1yl-10247sstobk-10247sstord-10247sstoyl-10247scusdf-10247sc/
  22. This may fit you car. Listed as having a 7" length and black. Seller has excellent feedback and allows 30 day returns. In feedback, purchaser has problem and seller worked with him. https://www.ebay.com/itm/375374742190?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=8acyaogvtew&sssrc=4429486&ssuid=Snv36mbbRk2&var=&widget_ver=artemis&media=COPY
  23. I'd imagine the simplest way is to look at the purpose of the circuits. For exampke, Circuit 32 is for the radio (and associated equipment) and if the radio turns off when the car is off and door opened, that's a timed circuit (it also shuts off after a specific amount of time, and the door hasn't been opened.) And Circuit 9 is always on, always looking for the signal to unlock to door. Whether the circuit is continuous or timed is determined by the SJB. As you have the repair manual, I'd start by looking at the blank fuse positions and see if the manual shows if they're monitored or unmonitored. If the manual doesn't detail this, you could simply check the fuse location to see if the blank has power with the door open. If it does, its hot at all times. If it doesn't, close the door, put the car in accessory and see if it has power then. (And goes off when car off/door ooen.) Personally, I'd check the wiring at the mirror to see if you can find what your looking for. (I have my radar detector wired into it. I needed power off, when car off. But if I remember correctly, there was also a circuit with continuous hot as well.) Keep us updated as to what you find. Like to know what you decide.
