I realize this is ancient, but if you are still experiencing the problem, one area to suspect first is the connector that plugs into the light. Check for green fuzzys (corrosion), even a small amount can cause problems.
Radio now turns on by itself on every start
enigma-2 replied to Davidoo's topic in Audio, Backup, Navigation & SYNC
Do you use Android Auto or Car Play? Wonder if it may be commanding the audio on. -
European rear fog lights
enigma-2 replied to scorpionking0102's topic in Accessories & Modifications
Its been my experience that either will fit perfectly. I'm only guessing but I would assume the difference could be as small as different suppliers or a small, non important modification. Several sites state that the B version supercedes the A, indicating that when the A runs out, use B. If they were truly different parts, the part number 449 would change. -
Check fuse #76 (30a) in the engine fuse box and fuse #10 (5 amp) in the interior fuse box. Both control the liftgate.
Hard to tell by looking at the picture, think its called the roof drip moulding. I had something similar on my 09 MKX. Had the Ford garage replace it. They said that it's glued on and can't remove it without damaging it. Anyway the new came primed and they painted. I required that they use Lincoln OEM only, not Asian look alike. They told me the price and I changed my mind. Part alone was ~$225 range (with shipping.) Lincoln part numbers for my 2009 MKX are 7T4Z7851729CA for left side, 7T4Z7851728CA for right side. Also wanted them to repair a small scratch on my front bumper cover. Small scratch. Think they quoted $1500 and a free tube of Vaseline. (Dupi color was only $20. Close enough.)
deleted
deleted
This has been seen many times here in the forum. Any possibility you can run the codes? When you open the liftgate, it unlatches and then what happens? Does it make any kind of feeble attempt to raise or is it dead? If dead, my first suspect is your vehicle battery is getting weak and needs replacing. (#1 cause #1). If it tries to open and fails, try lifting the liftgate full open and see if it holds its position. If it doesn't, the pneumatic lift arms are getting weak and need replacing. (The motor lift needs the lift of the pneumatic lift arms to raise it the first 50% of the lift.) Any binding when opening manually? If the Hatch stays full open (or nearly full) the pneumatic lift arms are good and the liftgate module "could" be at fault. You'll need to have the dealer replace it as it needs programming. If the module is failing, it should set a BCM code.
Doors don't unlock when you grab the handle
enigma-2 replied to nate39's topic in Alarms, Keyless Entry, Locks & Remote Start
Of you're still having this problem, there's an easy fix. You can control various systems on your vehicle using the information display controls on the steering wheel. Goto "settings", "locks", "remote unlock" and then you can choose between "drivers door only" or " all doors". -
Its my understanding that all grades of gasoline have exactly the same heat energy and using premium does nothing to increase hp. On engines designed for premium, using regular will drop hp slightly as they were designed for premium. (Higher compression.) But engines designed for regular wont benefit from premium. (As I understand it, premium may mask the knock sensor signal and cause the engine run too lean.)
Good luck with that. @SEGREY from Ukraine (earlier in this thread) said he tried it & it didn't fit. You got my curiosity up now, let us know if it fits or not. -
Wow..! You been busy. I need a beer just to get through reading your post 🙂 Curious. Did you have to pull the intake manifold to change the back 3 plugs? How long did it take? Did you replace the fan assy with Motorcraft or aftermarket?
Battery, yes. 8 to 12 years is normal battery life. I had a sensor fail, would fail and come back to life. On and off for a year or so. Finally failed. When I had it replaced I had all four replaced. Car was 12 years old. Specified Motorcraft senders, dealer was used to supplying chinese and they sometimes fail after a couple of years. He had to check all over the country to find Motorcraft, so few requests for OEM. Finally found four in Louisville. He told me they had around a 20% failure rate, not right away, year or two in use. I replaced all four as I didnt want to get one fixed and turn around and have another one start. But if you only replace this one, its possible you'll get a year or two more out of the rest. Motorcraft will run around 2x to 3x more expense, but then I only use OEM. Dealer likes to use NAPA and that's just cheap junk in my opinion. Hate NAPA.
$16 on Ebay. Free shipping. https://www.ebay.com/itm/274379868057?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=vpU8hSqCT7S&sssrc=4429486&ssuid=Snv36mbbRk2&var=&widget_ver=artemis&media=COPY
What's wrong with dropping by your local dealers parts department? He should be able to find the part for you.
Update. Went to VA yesterday for my annual examination. Discussed prescriptions with the VA nurse practioner and she told me that as I now have qualified for disability, all of my prescriptions are now free. Even Jardiance (retail is $650 month) & Ranolazine (retail around $200a month). Couple that with the cost of the policy of $80/month going to $127 next year .... (Plus some of my meds are moving from a less expensive tier to a 15% copay tier for 2025.) But the cost without disability is only $11 / month. So if your a vet and haven't signed up for VA coverage, think about it.
Most likely they are looking for a less expensive replacement. For reference, the original PTU fluid is made by US Lubricants. It's their 300 Waylube, rebanded under the Ford label. These are at the very top of lube products.
Ha! You just wait until they figure out that those sneaky Canadians have been putting in "their" software for dozens of years..! And you been wondering why your navigation screens would pop up with "go north, young fella" every once in a while.
- 1 reply
- 3
@edjunior You won't have any problems with Medicare. I'm on original Medicare with a Plan F supplement and a Plan D for drugs (although that may change. I'm going in on Monday fir my annual and plan on discussing the move to VA for prescriptions.) I also use my family doctor for all my normal needs and only use civilian hospitals (under Medicare) when I have the need.) @dabangsta You were injured during the Gulf War and are entitled to disability. Tendinitis is good for 10%. (At least thats what I got and mine is really bad - helicopters.) Sleep stuff etc. is hard to claim on, but there may be something, never know. Could be related to your combat experiences. I came back and had a wife and two kids so there was no time to work out my problems. Drank a lot, flashbacks, etc. Did drugs in Nam but haven't touched any after returning. (Haven't touched a rifle or handgun either - smile.) Shit passes slowly. Anyway, for 10% you would get $171 a month and thats tax free. But Biden opened up easy to qualify for things like exposure to burn pits and a bunch of other stuff. Doesn't hurt to talk with your doctor at your next visit.
Just thought I'd talk to any fellow vets on the site. I go to the VA once a year for an annual physical, assigned to a great Nurse Practioner (she's as tough as any Marine I ever served with.) I use my Medicare for my medical but still maintain my VA status with an annual physical. (May drop my Part D drug plan and got with the VA next year inasmuch as all Plan D's are raising their rates, deductibles and moving drugs from lower to higher tiers in the formulary. She's been on me for a few years to file for disability. Don't believe that I'm disabled, but she finally talked me into filing for Agent Orange exposure, loss of hearing and tendinitis. Sent me to several doctors at different places and got results showing that I'm 80% disabled. (80% rating is worth $2k a month. Tax free.) So the purpose of this is, if your a vet, you're entitled to VA Health care. Get a full blood panel and complete physical. You can get your prescriptions through the VA (really cheap) plus a bunch of other stuff, like insurance (can apply up to age 80, no underwriting) college (for the younger guys, etc.) So if you're a vet and not hooked up with the VA, look into it. You earned it.
2011 Ford Edge Seat Not Working
enigma-2 replied to 2011fordedgeselca's topic in Interior, A.C., Heat, Interior Trim
When I wrote this I forgot that I also had a similar problem on my 09 MKX. Passenger seat would go back but not forward. Replaced the switch assembly and has worked perfectly ever since. -
homelink won't close my garage door
enigma-2 replied to ben senise's topic in Alarms, Keyless Entry, Locks & Remote Start
Closing had different conditions than opening. Most issues are related to the sensors (they don't come into play during opening.) Other than that, it really sounds like the homelink is sending the wrong close code. Try resyncing the homelink unit with the opener. If the door opens ok with homelink, try staying in the same space a d closing. If it still doesn't close, I really suspect a paring problem. -
Fluids: • Oil (at 7.5k) • Power steering (40k) • Brake (30 - 60 k depending on environment) • Transmission (60 k) • PTU (30k) • Coolant (30k) • Blinker (60k) • RDU (90k or after anytime car driven through deep water) • Can of fuel injection & system cleaner (1-2× year) Filters: • Air cleaner • Cabin filter • Climate controlled seat filters (30k) • Fuel (150k I think) Mechanical: • Clean Throttle body plate • Clean Mass Air Flow • Change EGR (150k) • Change water pump (3.5L engine at 150k) • Change spark plugs (90k max) • Spare Tire pressure (2× year) • Wipe all weatherstripping with 303 protectant (annually) • Wipe wiper blades with alcohol and treat with 303 protectant (2x annually) • Clean headlights with Meguiar's G12310 PlastX Clear Plastic Cleaner & Polish and recoat with Meguiar's G17804 Keep Clear Headlight Coating • Change accessory drive belts (150k) • Rotate tires (every oil change) • Lube door & liftgate hinges, door locks & liftgate mechanism (spray silicone) • Walk around car and check all light bulbs for operation
