garycrist
Everything posted by garycrist
I have 285 35 22s
Back in the corner of the shop, is a piece of greasy-dirty 4X4. It's kind of gnawed up too. It is used as a door, hood and trunk modification device!🙄 Bending err adjusting the post on a door to either make the window roll-up better or cure a wind noise was another trick I've used too! Back to yours, watch-out for "hood flutter" at speed! You only want enough preload on the hood for it not to flutter at YOUR top speed. That keeps the life of the hood, rubber bumper and it's mount last longer.
Adjust the rubber bumpers under the hood. It takes minutes!
Glad you got it fixed.
When I sold Yokohama tires back in the late 80's, the only tire to have were the A001s for the track, in most of the road racing classes. For the street were the A008s. One would last 1K-8K with the BETTER driver receiving fewer miles. While the other tire would last 30K-60K with the BETTER driver receiving the best mileage! The quizzical looks and questions would flow after I made those statements. So, getting "short" wear life out of HP products is expected. That is why they gave the Joker option. "Speed costs money. How fast do you want to go?"
2007 - 2011 tail light swap, now have fast signal!?
garycrist replied to hdmapp's topic in Mods & Tech
I just read through this thread. The earlier Edges had the computer as stated above, run the "flasher function". If one goes with a LED assembly or light a resistor MUST be put in series. In the above the problem with the dual fitment is if the dual filaments were wired in series or parallel. So in order to do the math (I'm too lazy so I'll plagiarize) and cut and paste. Read redmondjp explanation and MATH.😀 https://www.vwvortex.com/threads/resistance-of-1156-bulb.2375533/ -
Might I ask where in the trouble shooting guide, does it say disconnect the battery?
Without more info, I would guess the hamster wheel needs lubing.
center console switched, now engine won't crank
garycrist replied to lumaie's topic in Interior, A.C., Heat, Interior Trim
Check and see if he plugged in the gear shift connectors and he did not blow a fuse. Pop the cover off and look. -
I see the red calipers, didn't some of those pads have normal rapid wear? Take a picture of the 4 rotors through the wheels and post them here. We will quickly help determine if a quick pad change will work.
Have you done a master reset of the Sync system? If not Ford has a reset procedure for all of the Sync systems. https://www.ford.com/support/how-tos/sync/getting-started-with-sync/troubleshooting-apple-carplay/ GL
I can offer you a suggestion. It might be possible to un-stick the seat belt if over-extended with a thin flexible piece of steel. (read Slim Jim) Try slipping it on the inside of the belt and move the tool down till resistance is encountered. ( the belt seam) I've unstuck a few. Watch the video to learn MY the cheat!
I have a man we have worked with for many years on a different site. He has given me permission to forward his information to anyone needing a Ford ESP plan. He is the General Manager of the dealership so there will be some rules, as we do not need his e-mail box filling with B.S. PM me and I'll be glad to forward Joel's info to you.. The process is simple as sending in the VIN year and mileage and picking one's plan/plans. It is my understanding these are at his cost. Gary P.S. In Florida, it is an insurance policy and is handled in state. I make no money too!
Did anyone answer FREE TOWING from every insurer one has in one's pocket?
I hope you did not get hosed from your repair. IIRC the reservoir is pressurized! If you overheated the 1st time, it is possible someone drilled a vent hole to prevent the coolant from spewing out from a blown head gasket.
Rather than lugging those jumper cables around, I purchased one of those little LIPO batteries for jumping my stuff. Now with the new Edge, I carry a breaker bar and socket for the tires and 165 foot pounds of torque.
Don't forget about bias-ply tires and flats all of the time too. A 4 way and jumper cables in the trunk just for back up.
The only people that seem to have transmission problems, are one's w/ no maintenance.
When I have all of the rig a ma roll on, The ST is just like some of my friends that want to drive it. They get on some twisties and I scream at them like I do the ST. GET OFF THE FKN BRAKES!
I'll bet Florida sellers have to have an in state Insurance License.
Aren't Ford ESPs based on the new car's original date of purchase and 0 mileage?
Sticking caliper pistons, especially the plastic ones if still used, may (will) swell over time and usage. On metal pistons, a rust belt will form on the surface of the piston outside it's seal. The dust boot is just that as it only keeps dust our! Squeezing those pistons back in, takes a chance of a sticking piston and can be a crap shoot. While bleeding brakes, DO NOT PUSH TO THE FLOOR! Master cylinders wears too. One only pushes so far and a ring of gunk and a ridge will build up. Bleeding the brakes or just resetting the pads after their replacement, one must be careful not to push too far down, lest a master cylinder failure may happen from a torn seal.
Brake problem 2010 Edge has me scratching my head.
garycrist replied to AllanD's topic in Brakes, Chassis & Suspension
As a shot in the dark, have you tried to cycle the ABS valves? Or, try going down a gravel road and do some lock-ups to exercise the ABS valves. I could be wrong but, I've seen lots of recomendations along that line. Also addressed here already too. Let us know...
