dajo2012
Everything posted by dajo2012
Charge my trailer battery while towing
dajo2012 replied to GMACFARLANE's topic in Cargo, Hauling, Roof Racks & Towing
https://www.etrailer.com/faq-charge-trailer-battery-while-driving.aspx -
Most warranties start on the date of manufacture so that would probably be started 2018 for seven years.
Its pretty hard to do a compression check on a diesel.
2019 Ford Edge ST Replacement Tire Options
dajo2012 replied to PokeTheBear70's topic in Wheels & Tires
I will be facing tire replacement soon on my ST. Can I ask how many miles have you got on original tires? -
Cold Air Intake Edge ST & Sport 2.7EB
dajo2012 replied to Xtra's topic in Accessories & Modifications
Why can't we use the original airbox lid? -
Ford Oem Oe Replacement Horn Fa1z13832b Image 1 Amazon Yes the 2020 is the same Tryed to send link but you will need to cut a paste.
Look right under the rear hatch button.
Clunk when baking out of a parking spot (FIXED: SSM 49769)
dajo2012 replied to Outlook214's topic in Edge ST
We have the summer tires also. It looks like they may make 18,000 and now have 12,000. That is an interesting theory on the tires, they probably ride a little stiffer also. -
Unfamiliar sound on my 2016 titanium edge
dajo2012 replied to Avi's topic in Audio, Backup, Navigation & SYNC
The 2020 also does not have a sound alert for lane keeping. -
Previous car was a 2012 flex with 3.5 EB. Spent a lot of time reading Flex forum and there was not a lot of discussion on transmission problems. The flex felt like it pulled much harder from a stop and it was not tuned. Both the Flex and ST have good passing power but the ST lacks from dead stop.
2016 Edge Sport wheels are peeling. Best way to fix??
dajo2012 replied to LipEdgeSport's topic in Wheels & Tires
My F150 wheels are peeling also. Almost never on salted roads. Wheel refinisher wanted $200 per wheel to redo and they don't have a good reputation for honoring their warranty. No best way (cheap) that I can think of. -
You need to check the belt routing it sounds like you trying to install it routed wrong.
Sync 3 and listening to text messages
dajo2012 replied to circatee's topic in Audio, Backup, Navigation & SYNC
That is how our 2020 works also, does not go away until close is tapped. Most other replies were for older models. -
I don't hear a clunk by my 2020 when backing up feels like it connects and disconnects. It is not a sharp thud by does feel not normal and something not experienced with any other car or truck. Car has done this since new and now have app 12,000 miles. Have not had any other issue with the transmission. Have not mentioned this to a dealer, figured it would get blank looks and we never heard of this before. Maybe should pursue this with dealer. -
locking doors while towing
dajo2012 replied to Edgeowner2021$'s topic in Alarms, Keyless Entry, Locks & Remote Start
The real reason we must disconnect the battery is because the ST has an electric parking brake and at some time it will set the brake and drag the real wheels. You may get by with it a couple of times before it does this. I installed a battery disconnect switch that is a push button inside the car and tow with doors unlocked but we don't carry anything valuable inside the car. It has been determined that the run the car every six hours does apply the current Edge, it did apply to my previous Flex. here is a couple of links that should help. I tow my 2020 ST. https://www.etrailer.com/Accessories-and-Parts/Roadmaster/RM-766.html?feed=npn&utm_source=google&utm_medium=cpc&utm_campaign=Google | Smart Shopping - Accessories and Parts - Maximize Revenue&ad https://www.irv2.com/forums/f85/2019-ford-edge-st-436787.html -
Have not had the trailer problem done yet but stopped at dealer and showed them the paperwork and of course they had never heard of it. My auto stop no longer shuts engine down even without the aftermarket module.
Replacing the entire oil cooler is not acceptable. I think I will take the PDF into my dealers parts department and ask them to get the nuts. I suspect that they have not had this come up yet and may not have a clue.
Overdrive on an Edge Sport?
dajo2012 replied to LAJAMA's topic in Cargo, Hauling, Roof Racks & Towing
I use my paddle shifters when towing a trailer. Don't know if 2016 has paddle shifters. -
Very interesting
I never changed mine yet. I was going to change it to shock proof but gave up, had less than 10k miles.
Yes I have and saw what you did. There was not much I recognized.
You have fuel injectors and not a throttle body injection system.
Edge turns over several times, doesn’t start,,,
dajo2012 replied to kapk22's topic in Accessories & Modifications
We were away from home and had to have a Ford dealer replace the pump. It was $700 or $ 800 the best I can remember. My issue was on all starts not just after fueling. It seems like you could put a pressure gauge on and see if the pressure is maintained after engine is shut down.
