dabangsta
    55
  1. How would a powertrain warranty cover wipers? Bumper to Bumper is 3/36k. Either way, I think they just were just venting on a misdiagnosis and some out of pocket costs associated with it, and turned it into a learning experience. I am maybe 30% into the features my SEL has that my 2017 Escape didn't have, and that last 1% that I don't know about are the toughest ones.
  2. It isn't an option in my Driver Assist list in my 2019 SEL. I have a button near the light switch to temporarily disable it (it will be enabled next start up). If you have an ST then you can set Sport mode.
  3. That goofy cubby area in the center console under the dash (in front of and over the power port on the passenger side), with no rear facing access. I don't see how it is useful for anything. Also the center console storage, glove box, door storage...are small. I tried putting the contents of my old 2017 Escape into the same compartments in the Edge, and they don't fit, at all. Only part bigger is the little tray in the console storage area, which was gum, chapstick, pen and pencil.
  4. The 2020 SE has no packages, it comes standard with the 8 inch SYNC 3 unit and front rain sensing wipers. I also think that I would have been okay with an SE as I got used to SYNC 3 and CarPlay/Android Auto, but the SEL had enough of the additional standard and options that I like it, I would love HD radio and the better B&O radio, the forward sensing system, acoustic side windows, etc, but with the Assist+ and Convenience Packages, I get close.
  5. Did you try the key fob in the key backup slot in the front of the inside of the center console storage area? While test driving vehicles I got to try that out since the remote fob on a 2016 I wanted to try had a low battery. Also used that slot on my 2019 to get the door code. But it sounds more like an issue with the starter if not a battery wiring issue. If it was a fob issue it would say authorized key not detected (or similar). The fob proximity signal and button press are separate from the internal proximity for starting with the PATS signal, but I think it would take a significant issue for PATS to no longer be recognized but the fob is.
  6. So you have the bi-xenon HID 401A with the tech package (Nav, BLIS, remote start, etc) correct? That means yes, that inside bulb is the DRL. I don't know if that is a configurable one or not. Is it an H15 HID bulb?
  7. 2019+ Edge all Series/Group from SE up got bi LED low/high beams. Prior to that, only Titanium/Limited had optional HID. I haven't checked how they are for oncoming traffic, they are whiter than I am used to, but they have lots of shadow/dark areas that halogen projectors don't seem to have. As I get older I am having more issues with bright/misadjusted headlights from oncoming traffic, but it also probably has to do with more and more OEM LED and people installing LED bulbs in housing that they just do well in.
  8. My 2019 Edge was built 1/6/2019, prior to the date that the new block was put onto the line and used. I thought that since it was a VEP engine it wasn't affected like the Cleveland (USA) block, but I guess only time will tell. Mine already had the EGR cooler issue with overheating and leaking coolant and fixed.
  9. Wrong bolt pattern, and with adapters they would stick out too far more than likely. Oh, and Welcome!
  10. Living on the edge with only one key! This is the first of many things that are difficult and expensive and could easily leave you stranded. I just bought my Edge, and even though CarFax showed the dealership "rekeying", "adding key(s)", it only had one fob, and no emergency key. There was no way I was leaving with that setup. They got a second fob and programmed it in (not cloned), but still didn't have the emergency keys in the fobs. Instead of waiting around that day (it wouldn't have happened, that lock smith couldn't do them) I waited a couple of days and they sent someone. They said that the key blank was on back order, the ones I got seem aftermarket, very similar to the one I bought from China for $3.
  11. Ford offers summer only tires on a lot of vehicles, including the Edges with the ST Performance Brake Package, and the Explorer ST has them as optional as well. I run summer UHP (BFG G-Force Sport Comp 2) on my Fusion (2012 Sport with the 3.5, AWD), and they are pretty greasy when it is near freezing. I live in the desert southwest and it rarely gets near freezing. This is a second car (my primary), and I have left it sitting to drive other vehicles in the evening. It is AWD and I have chains, but I probably wouldn't drive it up the mountain when it has snow or ice. When I had Continental ContiProContact tires I drove it to Denver during a snow event, and other than some bad habits creeping into my driving (speeding up in turn lane to make a light...oops) it did great, but even just the cold with the UHPs make them a handful.
  12. I am new to the Edge, so since it is a 2019 or newer (ST), I think they all get updated to 3.4 of SYNC. What year, what version of SYNC (2, 3), if SYNC 3 do you have 3.0, 3.3, or 3.4 or newer (the darker blue UI)? My 2019 had 3.3 from the factory, never updated. It was the light blue UI similar to the 3.0 version in my 2017 Escape. I downloaded 3.4 and installed it, and it has done a few smaller updates via WiFi (WiFi didn't work to get version 3.4). Since I don't use the built in NAV, I didn't check for map updates, they are not free (I don't have a subscription for them).
  13. Thanks, that attached workshop manual pdf is very handy! Lens appears to very easy to separate. With the 201a group I have the bottom cluster with the 2 screens.
  14. Once we signed all the papers on the 2019 Edge SEL, they detailed it one more time. Somehow they got that slick nasty spray on the back side of the cluster. I didn't notice it until the sun hit it, but I would have noticed it on the test drive. Can the back of the clear plastic lens be accessed non destructively and easily? It doesn't seem to be going away, it isn't going to evaporate it doesn't look like.
  15. No, the 2009 Edge didn't get global window open. On my vehicles that have it (2012 Fusion, 2015 Fusion, 2017 Escape until a dealer flash disabled it, 2019 Edge) you press unlock on the fob, then press and hold unlock again until the windows come down.
  16. On the Tucson it has some interesting small instrument cluster differences. I like that when you fill it up with gas, it has a separate screen for "since fill up" with miles, average fuel economy. It also has "this trip" that starts when you start the vehicle (and same miles and average mpg). It does only have a single accumulated miles style trip. It also has accumulated time vehicle has been stopped with the auto start/stop (this was a 2022, with 34,000 miles, and it had 35 hours of time in stop mode!). The "analog" speedometer is to the far left, and tach to the far right, so you really have to use the digital speedometer in the middle, it is hard to read the analog speedo, small numbers and weird graduation marks (100-160 mph is very compressed, the entire thing is not linear). I haven't really explored the different views in the Edge, but I already really don't like it. I like having instant mileage, average mileage, miles to empty, and miles since trip was reset...all in one view. I don't find that with the Edge, but maybe it is Trip2. I also like a tach to be able to stay off the gas enough to not spool up the turbo (unless I want to), but I got the feel for that before, so I should get it again. I also tried out the Edge adaptive cruise "stop and go" starting at a stop light and setting it, and letting off the brake. Once the car in front of me left, my car followed it up to 20 mph, then I could set it to the speed of the road. I got the emergency keys cut today (it only had one fob, I made sure that it had 2 fobs with 2 emergency keys), they told the dealership it would be done by VIN but they removed the lock set and and pins and coded it that way, but they didn't have another blank and wouldn't do a third (on my dime, the dealer paid for the first 2), but I feel better having a way in the vehicle if the battery dies. Ordered carpet floor mats, as I live in the desert and these slick plastic all weather mats are not needed and are annoying), batteries for the fobs (2045, crazy large), that third fob (a refurbished one with a blank emergency key), a touch up paint kit, a cargo net (well, 2...one for across the back, and one for the floor using the LATCH on the back of the seats). Updated SYNC to 3.4 to get the new look, and it is much more responsive than 3.0 (from my Escape) and 3.3 (factory install on Edge, never updated). Trying to figure out that silly cubby in front of the center console, above the passenger side power point. I can't even think of something I could 3d print to make it useful. Filling up the foam compartments under the cargo floor around the spare, much larger/taller than the Escape, so I can do a decent tool kit.
  17. Lets see if I can attach a small image from the order guide, your image is not showing up (first post thing like most boards?) These are the 2 offered wheels for the 2008 Limited (the standard 18 inch and optional 20 inch):
  18. Good luck with this. The tech spec from Ford for yours seems incorrect, showing all engine and drivetrain types with the larger 345mm rotors front, 315/316 solid rear. I guess your best bet is to measure the size. Even if you put in your VIN in fordparts it will likely show you a whole range of available sized rotors. The 17 inch wheel thing is weird to this day since 2015+ has been 18 or larger wheels, no more 17 inch. I guess the spare still has to fit over them? My 2019 shows 316mm rotor for FWD and 345 for AWD and ST (front), and 316mm rear solid, for FWD and AWD, and 345 rear vented for ST.
  19. Yes, thank you for the clarification on the two and what Ford calls them. Lane Keep Assist is standard on all. I do have an SEL with Co-Pilot360 Assist+ so it adds the adaptive cruise with lane centering. When test driving it, I tried them out and never could get them to assist, or center, but I only drove it a few miles.
  20. Just bought a used 2019 Edge. Carpooled with a relative this weekend, and did 650 miles behind the wheel of a 2022 Hyundai Tucson. I have not spent any time driving the 2019 Edge. I have put 10 miles on it going to the grocery store one time. I have not really spent much time in a vehicle with: adaptive cruise lane centering lane following OEM LED headlights push button start/proximity lock/unlock I tried them all out this weekend in the Tucson. Adaptive cruise is pretty nice. I found myself going to where it would actually brake because normally I would either tap brakes and coast until I could get in the other lane, or get closer to the car in front. I can't wait to try it out in the Edge. I need to adjust to using it versus normal cruise, and not sure I would use it around town. Lane centering (slight shake of the wheel and alert if I crossed), I sorta fought this and the lane following. I would probably not use it that much, it got brain dead when cresting a hill in a turn with nothing on the horizon, but still had road lines. I will try it on the Edge as well OEM LED Headlights...so many dark spots and weird bright areas (on both vehicles), pretty confusing. The fogs help a little with fill, but they have a very narrow pattern (as they should). I have never been flashed in an OEM headlight equipped vehicle before, and got flashed in the Tucson. Keeping the fob in my pocket is nice and I have to play around with it in the Edge, but so far I like it. I do have to watch having the fob with me when I wash my Edge, as I did get the liftgate (power, with sensors) to open when I didn't want it to. The Tucson has the super huge set of LED accent lighting (an inverted triangle) that are also the turn signals, and turning on the turn signals I see reflections off very tall overhead signs and bridges, took some getting used to. Overall I rate the Edge better build quality, and even though the specs don't bear it out as the cargo space is close, it seems more usable in the Edge. Much better power in the Edge, and it seems like very similar fuel mileage, I bet maybe 1 mpg better highway (my wife got 33 on mixed highway/freeway in the Edge, I got 30 mpg highway only in the Tucson.
  21. There are DIY ways to install SYNC 3 (gathering the pieces like the screen, apim, center panel, etc), or buy already built systems already configured. I have decent success with SYNC 3 and don't require an aftermarket head unit, but the 9 speaker setup in my 2019 is a bit of a let down
  22. I tried a few different ones on my 2017 Escape out of curiosity, because the bluetooth adapters that emulate a thumb drive didn't work either, and nothing worked. I had these for other reasons and borrowed one to try as well. My Escape had SYNC 3 and a CD player (which I hated that it still had), but music on a thumb drive works as expected. I am beyond happy to not have to deal with optical removable media in a car. While I generally use CarPlay or Android Auto and stream, or on those rare 15 minute occasions I don't have internet access on my cell phone.
  23. Replaced our wrecked and totaled 2017 Escape SE. 2019 Edge SEL, 201A package, Convenience Package, Co-Pilot360 Assist+, bright machined with painted pockets wheels, and pano roof. Magnetic Metallic with Ebony interior. I would rather an MKX or Nautilus but either out of our price point, or really out of our price point. Not a creampuff, and not low on miles (58,800), but well equipped, and some of the chips and scrapes can be cleaned up. It already suffered the EGR cooler failure 20,000 miles ago, and 2 other warranty items, one a new BCM, and the other one isn't real clear to me. I won't be the daily driver of it, but it will get plenty of highway/vacation/long weekend work outs, we usually drive around 20,000-22,000 miles a year. So far, first impressions...it is an appliance. Looks too much like Korean manufacturer SUV and bland. It is a pretty good cross between my 2015 Fusion and Escape. If I had ordered it new it wouldn't have pano roof (I have enough headroom, but it is about 2 inches less than the Escape), and possibly not the Co-Pilot360 Assist+, but everything else is great and worth the original cost. I will miss the paddle shifters (very handy when towing), and the ability to have a roof rack. The $1500 headlights scare me, but not enough to get an extended warranty, gonna roll the dice on that one. Both of the keys are missing the emergency blade, need to pick them up tomorrow. Need to add a third key, a dash cam, change the number of turn signal blinks for the toggle, arrange all my emergency stuff in the compartment around the spare, figure out a good cord method for Android Auto and CarPlay (maybe try out a wireless adapter for it), and try to get some carpeted floor mats as I don't need the all winter weather ones. Pictures later, it is too late and magnetic doesn't do well in the dark (and I am sure we are all seen a stock magnetic edge).
  24. Yup, only low profile S type chains for the 235/60/18 wheel/tire combo, all other sizes are no chains or cables. The 2019 owners manual also states the same, but smallest OEM tires are 245/60/18 so it probably wasn't updated. I think socks would be fine, never used them, and CA has some very vaguely worded descriptions of what a traction device is, and if an R1, R2, or R3 scenario, and then it can be up to an individual if chains or cables are required or if the sock is sufficient installed or just carried.
  25. I frequently see this from other vehicles that are generally not driven hard, but for one reason or another (like...me in my lowly 11 year old sedan having the gall to pass them) they go WOT for a sustained period of time. Most of the time it is the 2.0 Ecoboost Escapes and Fusions. The smell of sulphur from them running extremely rich (not as bad as failing cat). I think that light black smoke from a turbo engine going WOT due to being overly rich is common. I never could get it to happen in my 2017 Escape with the 1.5, but it was driven at 75% most of the time, never babied, even by my wife. Same with the tuner E85 crowd, but the smell is is different, but the tale tell soot on the bumper cover tells the real story.
