Everything posted by securinu
Extruded "U" Nuts
try auveco
Ford Remote Start Question
securinu replied to kiese02's topic in Interior, A.C., Heat, Interior Trim
go aftermarket it will be cheaper and have way more features. Mine does remote start it will also hit the rear defrost with the push of another button and also the heated seats. This cant happen with the factory as they are all push on for the seats and the defrost. http://www.aboutsecurityconcepts.com/Car_A..._Start_s/62.htm -
Stay Away from Retro-solutions HID !
securinu replied to BlazedUp's topic in Interior, A.C., Heat, Interior Trim
i wonder if ford would be happy to hear they covered a repair that shouldnt have been under warranty. Maybe todd can call ford and let them know, it should be easy to find out what dealer it was and get them to reject the claim. -
just to clarify so if anyone copies and pastes its BlazedUp Not being a douchebag like him just making sure if you want him gone he is gone. Also where are the mods on the board?? this type of crossposting would be grounds for removal on other boards i moderate. -
HID Conversion Kit $57.99 Lifetime Warranty.. Ships Next Day Satisfaction Gauranteed.. www.TopHIDKits.com Add at the top blazed, why dont you try them and see if they work , then go pound sand were all tired of your 3rd grade tantrum. -
well maybe its like i hear all day long , " Can you come look at my stereo , its all hokked up right but it aint working." Then i guess it aint hooked up right now is it???? -
Changing Head Unit with keeping Rear Seat DVD
securinu replied to blumi's topic in Audio, Backup, Navigation & SYNC
you dont absolutely need it but it does make it much easier. Plus it gives you VSS, Dimmer , Back Up etc. We have a harness just for the dvd retention. -
Changing MKX headunit questions
securinu replied to brucknerdoc's topic in Audio, Backup, Navigation & SYNC
not if you replace the headunit. no aftermarket will work if you change the headunit. -
oh also you will need a peswips to maintain the steering wheel controls as well. -
yes this is what you need . we do these all the time for the dealers and we stock them http://www.peripheralelectronics.com/ select your car then scroll down to fordah The FORDAH is an essential installation accessory for select 2005-Up Ford/Lincoln/Mercury vehicles with MSCAN Data bus radios. Using this interface will enable factory features such as rear seat entertainment (RSE), rear seat controls (RSC) and the premium amplified systems , and even THXII data controlled digital amplified systems when the original radio is removed. Other features include data bus driven retained accessory power (RAP), vehicle speed sensor (VSS), illumination, reverse output, parking brake outputs for an easy navigation or non-navigation radio installations. There’s also a 5 volt data controlled regulated amp turn on for factory installed subwoofers and other vehicle key features that would otherwise be lost. The FORDAH also works with Peripherals line of steering wheel control interfaces (PESW series) for most aftermarket radios. The PESW series line of interfaces will allow the SWC to control your aftermarket radio. -
here is the stuff i use it comes from the pro detail suppliers that the dealers use. Works awesome. http://www.tcpglobal.com/detailsupplydepot...emno=MAL+100116
Toyos proxess ST 2 Great Tire
securinu replied to securinu's topic in Interior, A.C., Heat, Interior Trim
thanks , yes a bit noiser but hey thats why i do car stereo right???? Great handling tire, i had this little civic think he was going to get around me on a corner when his lane ended. These tires held the lane flawlessly, and his rear erector set wing did nothing to help him except to look stupid. I never understand those big cheese cutter wings on the rear of a front wheel drive car. -
Re-Programming Edge for Differant things...
securinu replied to modette99's topic in Interior, A.C., Heat, Interior Trim
Why is it everyone elses resposibility to read the manual for you . I'm guessing your the one stuck someplace because you dont know how or where to do something simple to get back on the road. -
i had the same issue and the dealer replaced the seat under warranty. but i do a lot of work for this dealer so i get some things done that other might not get. 1 RO had the following on it 1) Driver seat replaced 2) headliner replaced due to sagging and it still sags at the back of the rear BAMR openong. 3) dash pulled to replace gasket under windshield 4) battery replaced wont hold charge 5) steering wheel controls replaced volume down wasnt working. 6) front brakes replaced as they would make a grinding sound when applied 3-4 times after 4 or more hours sitting. 7) center console lid replaced as it squeaked when you would have an arm on it while driving.
2007 Edge Vizualogic DVD Headrests
securinu replied to ehunt05's topic in Interior, A.C., Heat, Interior Trim
or more the fact that he is supposedly selling on his first post . people need to be careful who they send money too. no one on here needs to lose $ to some scam . -
first post and selling in the wrong forum -
ok had them a couple of weeks and there great. very good dry handling and handled 5" of snow very well . A little noiser than the stock conti's but for the handling its well worth the difference. -
Successful aftermarket remote start install
securinu replied to awake33's topic in Interior, A.C., Heat, Interior Trim
park lights are purple/white in the driver kick 12V+ -
park lights are purple/white in the driver kick -
Wiring an amp from stock 6cd headunit in 09 edge
securinu replied to mahonee's topic in Audio, Backup, Navigation & SYNC
you can mantian the steering wheel controls with an aftermarket deck , and you will have more control over the sub with the new deck. also the door speakers will sound better with an $80 pioneer deck than the factory deck any day of the week. -
TSB 07-16-11 08/20/07 ROOF OPENING PANEL SQUEAK/RATTLE FORD: 2007 Edge LINCOLN: 2007 MKX ISSUE Some 2007 Ford Edge and Lincoln MKX vehicles equipped with a roof opening panel may exhibit a rattle or squeak from the rear glass area. This may be caused by the delamination of the rear trim ring hook and loop (Velcro) adhesive. Inspect the rear trim ring and if loose, determine if the loop tape has delaminated from the plastic trim ring. ACTION Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE If delamination of the hook and loop has occurred, use the following procedure to correct the concern. If no delamination has occurred, follow normal Workshop Manual (WSM), Section 100-04 diagnostics. 1. Remove rear trim ring per WSM, Section 501-17. 2. Inspect all loop tape locations for delamination. (Figure 1) 3. Remove all delaminated loop tape from module. (Figure 2) 4. Clean trim ring attachment surface with a Isopropyl Alcohol or Rubbing Alcohol (IPA) wipe (Figure 3). 5. Allow surface to dry. 6. Apply Motorcraft® Instant Gel Adhesive to trim ring surface. (Figures 4 and 5) Apply loop pad to trim ring. (Figure 6) 8. Allow adhesive to dry per Motorcraft® Instant Gel Adhesive recommendation. 9. Reinstall trim ring to vehicle per WSM, Section 501-17. 10. Clean roof opening panel glass with Motorcraft® Ultra Clear Spray Glass Cleaner or equivalent. WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part. Parts Block OPERATION DESCRIPTION TIME 071611A 2007 Edge/MKX With Roof 0.4 Hr. Opening Panel: Reapply Loop And Pad To Trim Ring, Includes Time To Remove And Install Trim Ring, Clean Glass DEALER CODING CONDITION BASIC PART NO. CODE 7050036 24
yeah its a TSB thats been out almost 2 years reglue the trim around the rear glass.
2010 Cargo net and hardware
securinu replied to Gary F's topic in Interior, A.C., Heat, Interior Trim
how about the power liftgate got one of those available.
