Everything posted by securinu
just got them on today Toyo Proxess ST 2 http://toyotires.com/tire/pattern/proxes-st-ii 255/60/18 Will update after about a week or so , but so far so good.
Just popped these in last week 7" TFT LCD Monitors W/ Tilt. Hooked them up to the Pioneer f900bt Rear monitor output . They come on automatically when signal is rec'd Have a 2nd A/V in and wireless headphones as well. We just got them in the store they are inexpensive and are almost a dead on match for color. They will have it with built in DVD in about a month there current one with dvd has a zippered cover. Overall very good quality. We have put about 20 sets at the local ford dealer they are selling pretty good so far.
Fog Lights and Rear View Mirror Mods
securinu replied to TN_Yank's topic in Interior, A.C., Heat, Interior Trim
have a glass company pop it off for you . we use a local company to do it they do them all the time . best thing is keep it out of the su and the glass wont flex as much . -
Sport tails on Limited?
securinu replied to BAD03COBRA's topic in Interior, A.C., Heat, Interior Trim
http://www.partswebsite.com/fordpartswebsi...&type=parts -
Mods make this a sticky please https://www.fleet.ford.com/maintenance/owners_manuals/
if it is the stock battery i would say yeah it could be dead i ve had to have the factory battery replaced 2 x since may of 07 newer batteries are absolute crap . I have since put in a kinetik and dont have any problems with it whatsoever.
Replacement sport pedals
securinu replied to Lex Talionis's topic in Interior, A.C., Heat, Interior Trim
2010 taurus sho has them stock saw them on motorweek gonna go to ford tommorow to see if they will fit -
Yokohama Parada or Michelin Latitude Tour?
securinu replied to klc317's topic in Interior, A.C., Heat, Interior Trim
I am going wit the toyo proxes st2 255/60/18 i have the toyo on my durango and they lasted 85k miles on the first set. second set has about 60k on them with plenty of rubber left. http://toyotires.com/tire/pattern/proxes-st-ii -
Sirius Antenna - disable
securinu replied to doc johnson's topic in Audio, Backup, Navigation & SYNC
on the drivers side under the rear sill plate -
was able to prog it to set memory as well.
dont know its been near 100 for well over a week so no chance im turning on the heat anytime soon. sorry.
ahh good old fresblows.... my condolences...
No i install them all the time since i own a shop. And daily get people who shop fry's and ebay who want the cheapest part installed then cant figure out why it looks and works like crap. Go to a shop that knows what they are doing and you wont have to worry about it working or not. Them not knowing should be a clue for everyone not to let them work on your vehicle.
i did search but not with those terms. either way i found it does suck more in and blow it out with the bottom panel off. More with the glovebox open but dont really want to drive around with it open all the time. Where was it 115 i live in bwwod 40 east and we havent seen that for weeks it was 106 10 days ago but not 115
I opened up the glovebox to get my ipod with the a/c going and the airflow increased probably 20%. I am going to remove the under dash panel to see if i get the same effect. what is odd is that i didnt even have it on recirculate. Anyone else try this.
Wow thats great of you , do work for free ??? do you work for free????
Anyone install a PAC SWI-PS before?
securinu replied to wkevingossett's topic in Audio, Backup, Navigation & SYNC
probably 500 of them vey simple install. you need to ground the wire next to the feed wire and use the right resistor on the right loop wire. -
Side Marker Lights Blink W/Turn Signals
securinu replied to kempie's topic in Interior, A.C., Heat, Interior Trim
there are some connections that are sure to fail in MI weather. They should all be soldered and taped with heat shrink or at least heat shrink connectors with heat shrink over them. That scotchlok will fail in very short order. Other than that good idea. -
Aftermarket audio wiring harness recommendations
securinu replied to aldur99's topic in Audio, Backup, Navigation & SYNC
Amp trigger is a 5 volt feed if you put a 12volt from amp turn on or antenna feed from aftermarket deck you will get a loud pop . you need to add a 5.6k 1/4 watt resistor to te line to drop the voltage to the sub amp. -
If anyone is interested i will put together a pkg for an aftemarket stereo install . it will include the following (1) Fordah $129.99 radio interface to put in nav has VSS reverse and dimmer control. It also retains the aux in the console (1) Dash Kit $29.99 Double Din or single din with pocket (1) Antenna Adaptor $19.99 (1) Steering wheel interface $105.99 All this which totals $285.96 for $210 Shipped anywhere in the lower 48 $230 Shipped to canada or hawaii We accept paypal and all credit cards 1-800-216-0414 42 Steering Wheel Control Interfacing For most up-to-date applications go to: www. p e r i p h e r a l e l e c t r o n i c s . c om/ a p p s • Retain steering wheel control functionality when replacing the factory head unit • Features non-volatile memory which keeps all programming in memory even if the vehicle Battery is disconnected. • Works with Pioneer and Sony radios with external wired remote control input PESWIPS Steering Wheel Control Interface for Pioneer and Sony Radios P I O N E E R / S O N Y MSRP $105.99 • Retain steering wheel control functionality when replacing the factory head unit • Features non-volatile memory which keeps all programming in memory even if the vehicle battery is disconnected. • Works with Eclipse radios with external wired remote control input PESWIECL Steering Wheel Control Interface for Eclipse Radios MSRP $105.99 E C L I P S E • Retain steering wheel control functionality when replacing the factory head unit • Features non-volatile memory which keeps all programming in memory even if the vehicle Battery is disconnected. • Works with most Alpine, Kenwood, JVC, Blaupunkt, and Clarion Steering Remote Ready radios. PESWIAKJC Steering Wheel Control Interface for Alpine, Kenwood, JVC and Clarion Radios MSRP $105.99 FORDAH Radio Replacement For Ford / Lincoln / Mercury factory systems • For Use With Most Ford/Lincoln/Mercury CANBUS Equipped Vehicles • Supplies 12V retained accessory power, parking brake output, reverse output, illumination output, and vehicle speed signal output. • RCA Output From Factory Rear Seat Entertainment And Auxiliary Jack • Retains Rear Seat Entertainment Single Play/Dual Play Active. • Turns on the factory THX® amplifier when equipped. • Plug-n-play installation MSRP $129.99
