Everything posted by securinu
i will copy the page out of the service manual so you can follow and post it later but it is at work
these are contacts from ford so they are the exact size for the factory connector. they slide right in and lock in place.
so i have the connectors from ford that fit in the harness and snap into the molex is anyone interested in these ??? i figure to $15 shipped with the 2 wires to plug into the molex the wire to go to the headlight switch and the various connectors. did mine today in 15 minutes its a snap.
i will email you your cash just print and spend
I own a stereo shop i am going to do mine tommorow if all goes as i anticipate i can make up harness & ship out with all connectors needed. i will figure out cost and post back when done.
in need of a wiring harness
securinu replied to damouse19's topic in Interior, A.C., Heat, Interior Trim
we sell and stock them including the antenna adapter and sub harness if you have the subwoofer. -
i doubt the dealer will touch it saying they wont re-engineer ford parts. they dont want the liability
thats about it no noticable increase in power but at $42 for life it will pay for itself quickly even with the cleaning kits
New Sync Update is availble
securinu replied to Lex Talionis's topic in Audio, Backup, Navigation & SYNC
aftermarket is looking beter and better, this is a crock . aftermarket is way less money way more features and you can update for FREE if need be. -
it is the tire with an asterix in it in the guages when you first start.
no mine is tachless never had an issue . also if you get a kinetik you will only need one battery i just put an khc1800 in mine. here are the specs. Kinetik HC1800 Power Cell Full size powerhouse. Fits vehicles with larger battery boxes. Capable of powering nearly any system without compromise. Specifications Weight: 54 lbs. Ah: 81 Amps: 1900 Dimensions: 10" x 6.5" x 8.2" Suggested Retail: $419.99 http://www.kinetikaudio.com/default.asp
Painting my dash....over the GLARE!!!
securinu replied to wthrower's topic in Interior, A.C., Heat, Interior Trim
We use Sem at our shop , you will need to remove from vehicle to do it properly. you need to scuff it with a scotch pad and then use an adhesion promoter similar to primer then paint . several light coats work best . if you do a heavy coat your gonna have runs . also make sure you use the adhesion promoter or it will bubble as well. -
it gets better with miles mine didnt get good mileage to over 5k miles. the new engines are so tight they need to really break in
Aftermarket Head Unit in 2008: SOOO Easy!
securinu replied to JC4ME's topic in Audio, Backup, Navigation & SYNC
Whats the toggle for anyways???? -
Also if you didnt use the brown white wire for horn output you can change it to a factory security rearm in the setting and use a relay to splitone of the 2 front door trigger wires. if your amps kill the battery in 3 minutes you need a different battery . Try Kinetik
no the windows dont roll up and i have yet to do window rollup yet as there is no room in the drivers boot to feed the driver wires . all the rest can be accesed in the driver kick. I need to get the front fender off to drill and run a new grommet for the door as there is no room to drill a new hole. As for 12 volts the best thing to do is run up to the battery since it is right there and if you pull the battery there is a huge grommet.
Mounting a Garmin Nuvi in an MKX?
securinu replied to tji's topic in Interior, A.C., Heat, Interior Trim
lincoln = http://www.panavise.com/f/comm/indash/inda...813165144361272 Ford = http://www.panavise.com/f/comm/indash/inda...734596112182433 there are hundreds of different mount so we dont list them all. we have the edge in stock the MKX takes a day to get we dont see a lot of them. -
we sell the panavise mounts. they use screws behind the trim by the radio. -
sounds like a ground issue somewhere. electrical gremlins like that are usually due to bad grounds.
Pioneer Navigation/DVD System :(
securinu replied to sonyguy19's topic in Interior, A.C., Heat, Interior Trim
Well it seems everyone is confused. You dont need the ford harness or the $138 one either . We do these all day long. What you need it the Avic D3x which included bluetooth and ipod cable a dash kit and wiring harness from Best kits or metra. Its about a 50 minute install. if you want to get any of the above pm me for pricing . you could do your own install or we could wire it for you except for 2 outside wires which are very easy to get to. -
well you could alwyas add a wheel tilt sensor this time. I have one on mine and if it goes off the alarm actually only pages my remote . That way no alarm on car theives dont know + i go outside with my new Glock 22 and take care of business. It helps that i work with the Police Dept ( we have a bloodhound that is tracking trained and they get to use her) and i get away with stuff i probably shouldnt.
Pioneer AVIC D3 Installed :)
first of all the gps antenna doesnt need to go outside it can go underneath the dash above the radio. I used the factory Sirius antenna for my XM Navtraffic tuner. If you dont have that option and you have the small antenna you can put it under the glass in the slide area on the driver or passenger side. I have pics of one we did at work someplace . if i find them i will post. i tried to remove the factory antenna and put it there like (GM) but there isnt enough room. -
Should I let the dealer install a BAMR?
securinu replied to pables's topic in Interior, A.C., Heat, Interior Trim
it will be the big Sebato roof i bet nice but not even close to cover both seats. Also it wont have power shades like the BAMR
