EDU: Changing Oil in 2.7L Sport/ST
WingNut
just a quick weigh in on the cartridge filter, the best choice in my experience is to loosen the 'cap' / filter holder until the seals are free so the air lock is broken, then go underneath to drain the pan, plug it again, and go back up top to remove the filter and replace it. this allows the filter housing to drain and as much of the oil in as possible to drain as well.
I'd like to see Purolator make a BOSS filter for this application.. i've used them exclusively (Pure One before that) with Mobil 1 for years in whatever I own.
  • Thanks 1
  • 6 years later...
hi folks -- original owner of a 2022 ST, and decided to start doing my own oil changes again now that I'm retired. But I'm having trouble finding a good video etc. for an ST, and I suspect it's not the same as for other Edges? if anyone can direct me to a video or other instruction I would greatly appreciate it. Thx john p
  • Confused 1
2 hours ago, STBEAST said:
What is the torque spec for the oil filter housing?
No idea, never used a torque wrench on that.
Turn it down until it bottoms out and that's it - its seals on the o-rings and doesn't need any torque for that.
  • Like 3
  • 1004ron changed the title to EDU: Changing Oil in 2.7L Sport/ST
