omar302 Posted April 21, 2018 Report Share Posted April 21, 2018 Great that it worked. So now we know what it takes for an OEM Halogen to HID conversion. Direct swap plus As Built Data modifications using ForScan: 726-45-01 xxxx XXxx xxxx change value at XX to 7F 726-50-01 XXxx change XX value to 10 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 21, 2018 Report Share Posted April 21, 2018 Time to post up in this thread http://www.fordedgeforum.com/topic/23250-comprehensive-list-of-possible-forscan-mods/ Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 21, 2018 Author Report Share Posted April 21, 2018 One more q. Does anyone have experience with 726-26-02, one place lists it as frequency and another lists it as change to linear power. Im trying to turn off the PWM to my OEM HID headlights and just use straight dc, I currently use a relay and capacitor and it works, or if I didnt, the HIDs would flicker. Thanks Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 21, 2018 Author Report Share Posted April 21, 2018 Additional info, 726-02-02. Is xxxx-xxxX-xxxx, the capital X is 0 or 1. 1 Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 22, 2018 Author Report Share Posted April 22, 2018 Does anyone know which parameters to change so that DTCs wont come up and tell me my high beam and low beam headlights are out? Ive looked at several options but I dont see what appears to correspond. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 23, 2018 Report Share Posted April 23, 2018 Don't remeber reading any similar issue. Did you try this? 726-25-02 xxx* xxxx xxxx Headlamp Style Cfg: 0=BI_FUNC Halogen, 1=BI_FUNC HID, 2=Dual, 3=Quad Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 23, 2018 Author Report Share Posted April 23, 2018 (edited) Yes, it is configured that way. 726-25-02 0001-xxxx-xxxx. I had to set this parameter to HID already. Because if you dont set it, flash to pass (high beams on OEM HIDs) wont work either. I found this out by accident when trying to use flash to pass while DRLs were on. So the car already is set and thinks its got HIDs...at least in one place, but I think there are other parameters where HID should be set also. Edited April 23, 2018 by Ghhuff Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 23, 2018 Report Share Posted April 23, 2018 (edited) Found this in the F150 sheet: 726-27-01 0000 xxxx xxxx "Front Light Outage Detection Disable when adding aftermarket LEDs/HIDs in Halogen Bucket" Though, on my Edge Sport with factory HID it is set as follows: 726-27-01 0100 0001 0057 Edit:Also found this in the sheet: 726-26-02 xxxx xxxx x*xx Outage Headlamps Cfg: 0=none, 1=both, 2=high, 3=low Mine is set as follows: 726-26-02 0001 0000 0056 I would try this one first since it seems to match, for my Edge at least. Edited April 23, 2018 by omar302 1 Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 23, 2018 Author Report Share Posted April 23, 2018 Thanks omar302. I tried both and neither worked to prevent the dtcs from coming up. Quote Link to comment Share on other sites More sharing options...
Ghhuff Posted April 24, 2018 Author Report Share Posted April 24, 2018 (edited) I got the DTCs issue figured out, so that I no longer get DTCs on low and high beams. The parameters to set are 726-46-01 and 726-46-02. They are described as high beam open DTC and low beam open DTC. 0=unused, 1=used. 726-46-01 was 0001-0100-0076 on my car and I changed to 0000-0100-0075. 726-46-02 was 0100-0101-0078 on my car and I changed to 0000-0101-0077. This set the DTCs to unused. How I figured it out was I printed the as built data from a new Edge on the dealers lot that had HID and then compared page by page to my Edge build data. I found the differing parameters and checked their definitions. This is one more piece of the puzzle. ? Edited April 24, 2018 by Ghhuff 1 Quote Link to comment Share on other sites More sharing options...
Mino Posted January 18, 2025 Report Share Posted January 18, 2025 (edited) Hey @Ghhuff, Trying to do this myself, bought OEM HID headlamps to convert from the halogen to HID for my 2015 ford Edge, I changed the values for 726-45-01 and 726-50-01 based on the above but for 726-25-02 xxxX xxxx xxxx to select Headlamp type from 0=Halogen to 1=HID, when I change the value to 1 for HID and write it to vehicle it says its written and has gone through but when rescanning the car after the change it reflects its still set to 0 for halogen and wont accept the headlamp change to HID. Any thoughts on if you encountered this is or if I am missing something I didnt do for writing to the module that needs to change that hasn't? If I recall its change 726-25-02 to xxxX xxxx xxxx from 0 to 1 for HID 726-45-01 xxxx XXxx xxxx change value at XX to 7F 726-50-01 XXxx change XX value to 10 the second two changes went through no issues but not the Headlamp type. So headlamps work fine when IGN is in ACC/ON position but when engine is on after 5 seconds HIDs just flash and go dark, which is I assume from the change not going through for HIDs for some reason. Any thoughts or maybe I am missing something else you did? Would appreciate any help you can provide. Edited January 18, 2025 by Mino error corrections 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 19, 2025 Report Share Posted January 19, 2025 Headlamp Style Cfg 726-25-02: xxx*-xxxx-xxxx Values 0=BI_FUNC Halogen 1=BI_FUNC HID 2=Dual 3=Quad DRL Lamp Mask Cfg 726-45-01: xxxx-**xx-xxxx Values (value) DRL Lamp Cfg 726-50-01: xxxx Values 01=DRL Disabled 02=DRL Low Beams 04=DRL Front Fog Lamps 08=DRL Front Turn Lamps 10=Dedicated DRL Lights 20=DRL High Beams 40=DRL Low Beams and Dedicated DRL Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 19, 2025 Report Share Posted January 19, 2025 11 hours ago, Mino said: when I change the value to 1 for HID and write it to vehicle it says its written and has gone through but when rescanning the car after the change it reflects its still set to 0 for halogen and wont accept the headlamp change to HID. Make sure you are on the latest version of FORScan and have a supported adapter. Quote Link to comment Share on other sites More sharing options...
Mino Posted January 19, 2025 Report Share Posted January 19, 2025 Thanks for the reply Wubster, I did all those changes and also ensured I am running the latest version of FORScan as well. Still for some reason 726-25-02 won’t let me write the value for HID. It basically says it does and asks me to turn ign OFF and ON again and when I check again it’s still showing as Halogen. I am all for any possible idea as to why that change is the only one not going through. Not sure if my car being a Canadian version plays any factor or not? I'm stumped 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 20, 2025 Report Share Posted January 20, 2025 22 hours ago, Mino said: Canadian version The only difference I can think of is that Canadian vehicles should have permanent day time running lights. This can be done by running the headlights at about 80% brightness if there are no DRLs. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 20, 2025 Report Share Posted January 20, 2025 What is your model year and trim level? Quote Link to comment Share on other sites More sharing options...
Mino Posted January 20, 2025 Report Share Posted January 20, 2025 8 minutes ago, Wubster100 said: The only difference I can think of is that Canadian vehicles should have permanent day time running lights. This can be done by running the headlights at about 80% brightness if there are no DRLs. I thought this as well, but with the message from ONEDGE16 with a Canadian Sport I assume there is a way even with Canadian vehicle as there should be a dedicated DRL. 8 minutes ago, Wubster100 said: What is your model year and trim level? As for model year and trim level. I have a 2015 Edge SEL, not a Titanium. I did confirm the wiring is same and its just BodyCM programming that determines it, it even lights up the lights on accessory without issue, but maybe there is another setting I need to do for it being an SEL? Would there be another setting I need to edit in FORScan that's blocking writing to block 25 to tell it the type of headlamp? 1 Quote Link to comment Share on other sites More sharing options...
5starChad Posted December 18, 2025 Report Share Posted December 18, 2025 Sorry to bring this post back from the dead but has anyone else done this? I got a set of oem hid housings with ballast and bulbs from a friends wrecked car. Just hook them up and make the changes in forscan and they work? 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted December 21, 2025 Report Share Posted December 21, 2025 Didn't the high discharge take a different harness? (Heavier gauge wire?) Quote Link to comment Share on other sites More sharing options...
5starChad Posted December 21, 2025 Report Share Posted December 21, 2025 7 hours ago, enigma-2 said: Didn't the high discharge take a different harness? (Heavier gauge wire?) Looking at it the headlight wiring is tied into the entire main harness. I don’t see different harnesses listed in the parts diagrams. Seriously doubt they’d spend all that money to make two different main harnesses just for thicker headlight wiring. If it was a smaller sub harness I could see it happening but that’s a major cost for the amount of vehicles they make to do a main harness multiple ways like that. Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted December 21, 2025 Report Share Posted December 21, 2025 I have the official printed version of the wiring diagram for the 2018 Edge. There is a good chance it is the same as the 2017. It shows that there is only one version of the wiring diagram for the headlamps. I think this is a pretty reliable source. It shows many instances where there are different wiring schemes for different equipment on the car. There are three fuses. F62 and F67. Both are 50amp that go to the BCM. One for each side. The third is a shared 10 amp, F20. (this might be for the HID igniter). I think there is a very good chance that they will work with the existing hardware and require a change with Forscan only. 1 1 Quote Link to comment Share on other sites More sharing options...
5starChad Posted December 21, 2025 Report Share Posted December 21, 2025 57 minutes ago, johnmarkp said: I have the official printed version of the wiring diagram for the 2018 Edge. There is a good chance it is the same as the 2017. It shows that there is only one version of the wiring diagram for the headlamps. I think this is a pretty reliable source. It shows many instances where there are different wiring schemes for different equipment on the car. There are three fuses. F62 and F67. Both are 50amp that go to the BCM. One for each side. The third is a shared 10 amp, F20. (this might be for the HID igniter). I think there is a very good chance that they will work with the existing hardware and require a change with Forscan only. I got some Osram Nightbreaker bulbs coming in next week and I’ll be doing the install. I got a printout of the as built from the car I got the housings from and my current as built information so I know exactly what is different and what to change in Forscan. Will report back once install is complete. 1 Quote Link to comment Share on other sites More sharing options...
5starChad Posted January 3 Report Share Posted January 3 Got everything installed and can confirm the changes here in Forscan is all that is needed. Everything works as it should. I made the changes line by line but also noticed the changes could be made in the list version of the tables. Both headlight type and drl function. 1 1 Quote Link to comment Share on other sites More sharing options...
