hilokamper Posted August 18, 2019 Report Share Posted August 18, 2019 (edited) 2011 Edge Limited (72k MILES) Replaced SAS (Steering Angle Sensor) was getting Code P193C. Cleared code with Forscan (had to use reset all adaptions to clear) no warning lights (DTC) until I restarted car. Upon Restart all the same warning lights came back on BUT I'm not getting any DTC's showing up in Forscan. I'm using latest Forscan software update. Warning Lights I'm getting are: Brake, ABS, Stability Control, Stability Control Off at the bottom of dash. PLUS the warning popup on the left side: "Service Advance Trac, Check Brake system. Anything I can do to pull more DTC codes ? also do I need to do a SAS calibration since I replaced the Angle Sensor ? I Can't see anything in Forscan to do it (although I've seen on a Ford Forum that Forscan can do it on Superduty trucks.) If I had a bad Wheel Sensor or Cracked Tone ring wouldn't I get DTC codes in Forscan relating to the individual issue ? Edited April 11 by 1004ron Rearranged images Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 18, 2019 Report Share Posted August 18, 2019 Per Buck Newby's video, no calibration needed after SAS replacement Quote Link to comment Share on other sites More sharing options...
hilokamper Posted August 18, 2019 Author Report Share Posted August 18, 2019 I saw that Video before I started my Replacement. I didn't see where she mentions anything about calibration / relearn. Her's is an older model the SAS module is a different # and connects different than mine did (mine snaps into the back of the Clock spring and is mounted as a 1 piece unit). Since Forscan doesnt have any procedures to so for my Year, I'm guessing it still does not require. Just wanted to be sure I'm not missing it in forscan. Still searching why I'm getting DTC's I've had a few white knuckle experiences in the last few weeks driving with all this rain in South Florida. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 20, 2019 Report Share Posted August 20, 2019 The same procedure applies for 2007-14. No calibration needed. Are you getting the same DTCs afterwards? Tone ring/wheel speed sensor issues are starting to crop up on 2011-14 MYs, so you should get eyes on them and see if there is an issue. Quote Link to comment Share on other sites More sharing options...
bb56 Posted January 12, 2022 Report Share Posted January 12, 2022 (edited) I know this is an older thread but I thought folks should know that when I broke the wheel speed sensor while changing a rear wheel bearing in my 2011 AWD limited, I had to wait a few days to get the replacement. During that time, all the same lights were on and the "Service AdvanceTrac" message came on every time I started the car. My new part is supposed to be here today or tomorrow, and I hope I don't have to reset the ABS or anything. UPDATE: It was plug and play simple. Once installed (10 minutes) all my warning lights on the dash went back to normal without having to reset anything. Edited January 14, 2022 by bb56 Update ease of fix Quote Link to comment Share on other sites More sharing options...
Nancy Posted January 23, 2022 Report Share Posted January 23, 2022 My Edge is doing that same thing today just when I crank it what did you have to do.. Dealership isnt opened today? Quote Link to comment Share on other sites More sharing options...
Meme Posted January 31, 2022 Report Share Posted January 31, 2022 Hello Nancy. Were you able to get it sorted? My 2011 Edge brought up same lights like the original poster showed and wondering if it is safe to drive it to th eldealership to check it out? Thanks bb56 for the update. Quote Link to comment Share on other sites More sharing options...
HoltLD Posted September 11, 2024 Report Share Posted September 11, 2024 I have 2013 Lincoln Mkx basically a ford edge. I have all the same issues. I have replaced the wheel speed sensors and the SAS and everything cleared for a couple weeks. Today all the same lights pop up and still getting the P193C DTC any suggestions? Thanks, 1 Quote Link to comment Share on other sites More sharing options...
PatrickGuinalia Posted October 9, 2024 Report Share Posted October 9, 2024 Hey guys! Also reactivating the topic, I had the same problem on my Edge AWD 2014 3.5. The car was off, I simply turned it on and the parking brake, ABS, traction control and stability control lights were on, accompanied by two warnings on the left screen of the dashboard: check brake system and advancetrac service. (picture 1) The codes shown on the forscan were P193C and U3000-49. (picture 2) When searching here on the forum and also in various videos on the internet, many people recommend replacing some internal components of the ABS module. However, sometimes this warning does not occur, and no warning light comes on on the dashboard, which appears to be an intermittent error. So I'm still unsure whether to disassemble the part and send it for repair, as it's a very expensive service and I'm afraid it won't be resolved. Yesterday I disabled the AdvaceTrac, ABS and TCS options in forscan, and the error message on the left screen 'check brake system' does not appear. In this case, with these lights deactivated, another code showed on the panel: U0415:56-2F. After researching, he led me to a person who discovered a problem with one of the ABS sensors on the wheels. (picture 3) Now I'm in doubt as to what the reason for the problem would be, because the mechanic recommended replacing the abs module, but I have three codes: P193C and U3000 together, and when these are erased and their indications are turned off in the forscan, U0415 appears. The car's brakes work normally, when traveling or in urban traffic, no problems when using the brake pedal, no strange noises or anything like that, everything is normal with or without the warning lights. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted October 9, 2024 Report Share Posted October 9, 2024 I would spend the time to look at all the ABS sensors and wiring, and since you can data log, show each wheels ABS speed and see if one isn't correct to help determine which one it might be. Hopefully someone can post the error code breakdown for the :56 part and what status of 2F is to help. If the ABS module is getting incorrect data it might be causing it to also set a code, I know it says it is an internal fault but if an ABS sensor is grounding (in some cases the wires are too short or too long and wear on suspension parts, in the rear I think) might cause it. Quote Link to comment Share on other sites More sharing options...
PatrickGuinalia Posted October 9, 2024 Report Share Posted October 9, 2024 9 hours ago, dabangsta said: I would spend the time to look at all the ABS sensors and wiring, and since you can data log, show each wheels ABS speed and see if one isn't correct to help determine which one it might be. Hopefully someone can post the error code breakdown for the :56 part and what status of 2F is to help. If the ABS module is getting incorrect data it might be causing it to also set a code, I know it says it is an internal fault but if an ABS sensor is grounding (in some cases the wires are too short or too long and wear on suspension parts, in the rear I think) might cause it. Hello friend! I tested all the ABS wheel speed sensors and they are correct, no sudden changes even with the warning lights on. Test: The code U0415 seems to only appear when I disable ABS, traction type and traction control in the FORScan. If I enable the options normally, it disappears and only P193C and U3000-49 remain. Maybe U0415 it's just a warning of incorrect panel configuration. Is there a test for the steering angle sensor, before definitively condemning the ABS module for repair? Quote Link to comment Share on other sites More sharing options...
Colbertsr Posted April 11 Report Share Posted April 11 (edited) 2014 Edge Limited 3.7 My ABS related lights, service advance track. I'm getting code U3000:49ab and occasionally p193c:00-6c comes but I think it is something I did wrong during testing. I've check wheel speed sensors and they are all reading the same. Is there anything else I should be checking, reseating, etc before replacing the ABS module. initially when lights were on there didn’t seem to be an issue (on for months), was braking well and drive normal. Until one day (month ago) i did slam on brakes it seemed to lock up instead of the normal abs pulse to keep the lock up from occurring. Recently over past week there is somewhat of a hesitation occurring for split second when driving over 30 miles that occurs pretty frequently and seem to be getting worst (more frequent). Could be separate issue but still only getting codes as mentioned initially. If I do have to replace ABS module , guessing I'll have to go to ford to get it programed. Any feedback would be greatly appreciated , Thanks. Edited April 12 by Colbertsr 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 11 Report Share Posted April 11 What is your model year? Can you add it to your profile signature? 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 22 Report Share Posted April 22 Looking up the U3000:49ab code indicates the ABS module's internal memory or its processing capabilities are not functioning correctly. The the U3000 part indicates a control module issue. The 49 signifies an internal failure. Could also be related to a low voltage to the module. As you're also getting a p193c:00-6c code, first check your battery. 1 Quote Link to comment Share on other sites More sharing options...
PatrickGuinalia Posted October 23 Report Share Posted October 23 (edited) About the problem I posted above a while ago: Technical Report – ABS Module Replacement and Programming on Ford Edge Vehicle: Ford Edge Year: 2014 Initial symptom: DTC U3000 stored in the ABS module, with dashboard messages such as “AWD off”, “Service traction system”, and delayed instrument responses. 1. Initial diagnosis The U3000 fault indicated an internal failure in the original ABS module. Over time, secondary issues appeared, such as irregular traction/stability operation and communication errors with other modules. 2. Replacement A new (used) ABS assembly (hydraulic + electronic) was installed, with the exact same part number as the original unit (Eletronic DT43-2C219-DA, hidraulic DT43-2C405-DB). The physical installation was carried out at a professional workshop, with no need for hydraulic modifications. 3. Programming with FORScan After installation, the programming procedure was performed at home by the owner using FORScan software. Steps executed: Connect the vehicle without loading any saved profiles, allowing FORScan to re-detect all modules. Identify the ABS module in the list. Save a full backup of the current As-Built data (“Save All”). Select “Load Factory As-Built” to download factory configuration for the vehicle’s VIN. Proceed with programming even when warned that “the number of blocks in the file and module do not match,” since the used module contained data from another vehicle. Once programming completed, the module rebooted and communicated properly with the network. 4. Results All U3000 and U3002 faults cleared. ABS, brake, and traction warning lights turned off. AWD, EBD, TCS, and ABS systems returned to normal operation. No active DTCs remained afterward. 5. Final note A slight brake pedal vibration was observed during initial braking, which is considered normal while the system self-calibrates after the module replacement and brake bleeding. If this doesn't work, you can also do brake bleeding through FORSCan. Below are the before and after images of the ABS programming, and the absence of warning lights on the dashboard. Edited October 23 by PatrickGuinalia 1 Quote Link to comment Share on other sites More sharing options...
