enigma-2 Posted January 29, 2025 Report Share Posted January 29, 2025 There may be a couple of other checks that come to mind. Gas cap gasket or cap not clicked when being replaced. Wiring to the purge valve. Corrosion in the connector, Micky chewing on wires .. Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 30, 2025 Report Share Posted January 30, 2025 CEL triggered again on the way home from work. Gas tank filler cap seal is good. Just read codes and installed a 3rd party evap valve. First evap valve replacement in Oct 2021 at 71K miles and second at 110K miles. ---------------- ===PCM DTC P144C:00-EC=== Code: P144C - EVAP System Purge Flow Performance During Boost Status: - DTC Maturing - Intermittent at Time of Request - Malfunction Indicator Lamp is On for this DTC - Test not complete Module: Powertrain Control Module Freeze Frame #1: Freeze Frame #2: -EVENT_TIME: 254234679 s (Thu Jan 30 16:15:12 2025) - Event time -TOTAL_DISTANCE: 177194 km - Total Distance -FUELSYS: Closed Loop - Fuel System Status (Open/Closed Loop) -LOAD: 62.35 % - Calculated Load Value -ECT: 93 °C - Engine coolant temperature -SHRTFT1: -3.12 % - Short term fuel trim 1 -LONGFT1: 7.81 % - Long term fuel trim 1 -SHRTFT2: -2.34 % - Short term fuel trim 2 -LONGFT2: 8.59 % - Long term fuel trim 2 -MAP: 144.0 kPa - Manifold absolute pressure sensor -RPM: 2784 1/min - Engine Revolutions Per Minute -VSS: 118.0 km/h - Vehicle Speed -SPARKADV: 10.00 ° - Spark Advance -IAT: 12 °C - Intake Air Temperature -RUNTM: 1429 s - Time Since Engine Start -EVAP_PCT: 0.00 % - Commanded Evaporative Purge -FLI: 59.61 % - Fuel Level -BARO: 98.0 kPa - Barometric pressure -VPWR: 13.01 V - Control Module Voltage -TP_REL: 34.12 % - Relative Throttle Position -TAC_PCT: 44.31 % - Commanded Throttle Actuator Control -RPMDSD: 600 1/min - Desired Idle Speed RPM -O2S12: 0.66 V - Heated Exhaust Gas Oxygen Sensor (bank 1, sensor 2) -O2S22: 0.50 V - Heated Exhaust Gas Oxygen Sensor (bank 2, sensor 2) -TQ_CNTRL: None Requested - Torque Control Requested -ENGOFF_TIMER: 32784 s - Timer since Engine Off -APP_FLT: No Fault - Accelerator Pedal Position Sensor Status -MISFIRE: No - Engine Misfire currently detected -IAT_F: No Fault - Inlet Air Temperature Sensor Status -ETC_TRIM_LRN: Yes - Throttle Angle Offset has Learned -TP_F: No Fault - Throttle Position Sensor Status -MP_LRN: Yes - Misfire Profile Correction Learned -MAF_F: No Fault - Mass Air Flow Sensor Status -MAP_F: No Fault - Manifold Absolute Pressure Sensor Status -APP1: 1.92 V - Accelerator pedal position sensor 1 -APP2: 0.96 V - Accelerator pedal position sensor 2 -TP1: 2.84 V - Throttle Position Sensor 1 -TP2: 2.18 V - Throttle Position Sensor 2 -GEAR: 5 - Gear Commanded -GEAR_OSC: 5 - Gear Command by Output State Control -TSS_SRC: 2771 1/min - Actual Turbine Shaft Speed -OSS_SRC: 2770 1/min - Actual Output Shaft Speed -TFT: 63 °C - Transmission Fluid Temperature -TR: Drive/OverDrive - Transmission range ===END PCM DTC=== ===OBDII DTC P144C-C=== Code: P144C - EVAP System Purge Flow Performance During Boost Status: - Confirmed - malfunction is confirmed 1 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 30, 2025 Report Share Posted January 30, 2025 Glad you found the fix. Personally I wouldn't have used aftermarket, but maybe its good enough. What brand did you go with? Always good to know if aftermarket works (and holds up.) 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 30, 2025 Report Share Posted January 30, 2025 Generally I use OEM but for this being a non critical device and two OEM ones didn't last as long as I'd expect, I went with the DORMAN 994073 at around half the price from RockAuto.com. 2 Quote Link to comment Share on other sites More sharing options...
omar302 Posted January 31, 2025 Report Share Posted January 31, 2025 (edited) Strange you're having to replace it 3 times now. Glad your able to fix it easily though. Edited January 31, 2025 by omar302 Didn't read the thread correctly. Quote Link to comment Share on other sites More sharing options...
Tmaf901 Posted January 31, 2025 Report Share Posted January 31, 2025 On 1/29/2025 at 11:42 AM, 1004ron said: Yesterday on my way home from work with just over 1/4 tank of gas the check engine light came on. Stopped to gas up at Costco later and read the codes and got P144C - cleared codes and it hasn't reappeared. Looking to replace the evap purge valve for the second time on my Edge. Considering a Dorman replacement this time - $40 on RockAuto.com 2017 FORD EDGE 2.7L V6 Turbocharged Vapor Canister Purge Valve / Solenoid | RockAuto Welcome to the club of 17’ Edge Sport owners 2.7L EcoBoost who have to replace purge valves yearly :). I just did mine again as well. When my check engine light comes on in October/November it’s not even worth me checking the code anymore. It’s a different code each time, replacing the purge valve fixes it. This year my Autozone part was under a warranty. I didn't have to pay, they just replaced it. This one looks different than the others I have put on. We shall see :). (Lets update each other in a year lmfao). 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 31, 2025 Report Share Posted January 31, 2025 Looking at your results, it seems that your fuel trims are a wee off. (Could be the way your car responds however.) Still, I'm kind of wondering if there isn't a small vacuum leak going on, on the evap purge line. (?) Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 16, 2025 Report Share Posted February 16, 2025 Two tanks trial on the Dorman resulted in no fault codes and no stuttering immediately after gassing up, and just for to satisfy the tinkerer in me I tried a $9 solutions which also had a flawless two tank trial. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 28, 2025 Report Share Posted February 28, 2025 The $9 experiment was a failure. Reinstalled the Dorman one and a trip to work without codes. Quote Link to comment Share on other sites More sharing options...
RPGR90s Posted 23 hours ago Report Share Posted 23 hours ago 2019 Edge ST with 105k miles Recently the check engine light came on and my scanner revealed the two error codes. Since the purge valve solenoid is right on top of the engine, I thought I would replace this first. Dorman 994-073 Vapor Canister Purge Valve I tried clearing the codes but my cheap scanner won't allow me to do that, so I was hoping the codes would clear themselves, assuming the purge valve is now working. I have also cleaned and inspected the fuel filler area, but it appeared very clean and tight. I would also like to inspect/replace the charcoal canister but I cannot find it's location. If anyone could tell me, I would be most appreciative. Thank You!! RPGR90s 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 9 hours ago Report Share Posted 9 hours ago It's really not that hard to find Quote Link to comment Share on other sites More sharing options...
1004ron Posted 8 hours ago Report Share Posted 8 hours ago (edited) @RPGR90s I have used the Dorman evap purge valve and it did not work, or didn't work for long. I don't know what it is and why the third party valves don't work but can confirm that the Motocraft replacements do work. The current one I bought from this eBay seller and its been working for one year. Genuine Ford Vapor Canister Purge Solenoid GL3Z-9B325-B | eBay Get the free Forscan Lite to use with an OBDII adapter to read and reset codes. You'll find the PDF's in this thread showing the location of the canister - it's not easy to access. Edited 8 hours ago by 1004ron Same topic threads merged Quote Link to comment Share on other sites More sharing options...
RPGR90s Posted 7 hours ago Report Share Posted 7 hours ago 1 hour ago, 1004ron said: @RPGR90s I have used the Dorman evap purge valve and it did not work, or didn't work for long. I don't know what it is and why the third party valves don't work but can confirm that the Motocraft replacements do work. The current one I bought from this eBay seller and its been working for one year. Genuine Ford Vapor Canister Purge Solenoid GL3Z-9B325-B | eBay Get the free Forscan Lite to use with an OBDII adapter to read and reset codes. You'll find the PDF's in this thread showing the location of the canister - it's not easy to access. Thanks for the reply. I pulled off the Dorman unit and tested it with a 12v battery and it appears to open correctly as well as hold suction. As far as the under vehicle cannister, the only thing I found was forward of the muffler that has some hoses going to it and an electrical connector. It mounts right up against the floorpan just forward of the muffler. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 2 hours ago Report Share Posted 2 hours ago I did all sorts of bench tests on the Dorman and based on those tests I assumed it must work, but after a good web search found that for reasons unknown the 3rd party evap valves don't work - installing a Motocraft confirmed the search results. Quote Link to comment Share on other sites More sharing options...
