Turning off my double honk
Jackm
Hey y’all, I was just wondering if anyone has found a way to turn off the double honk when you close the door of a running Edge? I have a Ford Edge 2018 SEL FWD that I use for DoorDash and I leave my engine on so I don’t have to start stop it a lot in the cold. This unfortunately has the side effect of honking in neighborhoods. If someone could help me out it would be much appreciated
Forscan is the answer
Give the forum search a try, I'm sure you'll find a few threads explaining how to do this using Forscan.
  • Thanks 1
Definitely use Forscan, especially if you're using it to make deliveries. You can also use it to enable Secure Idle so no one can steal your car while you're away from it
