johnmarkp Posted August 1 Report Share Posted August 1 I just started getting a clunk sound when I take my foot off the gas. I also get it when I am slowing to a stop at a couple of miles per hour. I will put it up on stands tomorrow and check the CV joints and anything else I can wiggle on the front end. Has anyone has a similar thing happen? Quote Link to comment Share on other sites More sharing options...
kruzr1 Posted August 3 Report Share Posted August 3 I also seem to have this issue. However, sometimes it seems to come from the front and other times the rear. But it's not the same sound or feeling. I also have the event when coming to a stop at around 11 - 13 mph. This has been previously mentioned in the forum here. I'll probably take it to a shop I trust where they can put it on a lift and get a better look at it then I can. I still have my extended warranty. Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted August 7 Author Report Share Posted August 7 With on side of the car jacked up I get a clicking sound when I move the front wheel back and forth in the direction of rotation. It is the same for both wheels. (the other front wheel is on the ground). Is this normal? I can't remember if it made this sound in the past. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Tuesday at 10:55 PM Report Share Posted Tuesday at 10:55 PM A little more clarity needed. Are you saying you put your hands on the tire and then rotate the tire forward and backwards? When doing this you get the clicking sound? What happened to the clunking sound? These are completely different noises. As far as the clicking sound, check the cv joints / boots and check your brakes. The brake pads may be loose in the calipers. As far as the clunking sound, this sounds more like something transmission related. Check your driveshaft, universal joints, mounting points and check your torque mount. Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted Wednesday at 08:21 PM Author Report Share Posted Wednesday at 08:21 PM The more I think about it. The clicking sound when I jacked up the wheel is probably normal when the car is in park. I think I have heard it before. The clunk when slowing down is slowly getting worse. Time to a drive to the dealer. Luckily it is still under the Ford extended warranty. Quote Link to comment Share on other sites More sharing options...
