Just installed Power Stop Geomet rotors and Z17 pads on 2019 ST
Finally got the time to install the rotors and pads I got in June on my ST.  Not that hard to do if you have the right tools.  The 7mm and 11mm Allen sockets and the 18mm standard socket are not normally found in most tool sets you buy.  A 1/2 inch impact wrench is also a good idea to have for the job.
I can't find the thread here, but the idea to use a bolt through the holes for the anchor plate to remove the rotors is spot on.  Both front rotors would not budge using a rubber mallet.
I only had time to do the break in.  So I cannot comment on how they function yet.  The front pads had a lot of life left and the rotors were in pretty good shape.  The rear pads were completely worn out and needed to be changed.
I'll report back on how the brakes perform.
Should go away. Mine are growly if only my wife drives it for any amount of time (2-3 weeks). She is not an aggressive braker and once I drive it once there is no hint of noise for a few weeks.
It took me quite a while to get rid of the machine marks on the rotors, maybe 1000 miles?
She is the primary daily driver of it. I drive it occasionally during the week, but I am the long distance vacation driver. I went with the same rotors but a less aggressive pad.
  • 8 months later...
Update.  From a performance standpoint I am very happy with the Powerstop rotors and pads.
I am not sure what to think about the amount of rust I am seeing on their "Fully Coated" rotors.
I sent them an email with this picture.  It will be interesting to see what they say.
I think this is an unacceptable amount of rust on rotors that I installed 9 months ago.
I would like to hear what others think?
I will have to see how the coated rotors look on my 2015 Fusion that is driven in rain, snow, "salted" roads, but the ones on my Edge that lives in the desert are still shinely coated and no signs of rust. The wear pattern is great. One small groove I can barely feel with a finger nail. They still take a beating and don't overheat/shudder on long down hill descents, or high effort short stops (not quite emergency stops, but close).
I don't have discolored lines/marks like you do in that image. I only have 31,000 miles in the 17 months on it since replacing the brakes, I haven't recently checked the pad depth.
I guess Z17 are low dust ceramic, so on my 2019 Edge (non ST) I did the same rotors and pads.
I got the Z23 (carbon fiber/ceramic) pads and the same geomet coated rotors for my 2016 MKZ. I haven't installed them yet. Since I drive my MKZ more and am the more aggressive driver of the household, I tend to go more for the drilled, slotted, carbon metallic pads.
