Moderator-
LOL people who can’t admit they’re wrong, They only updated the RWD version, not the Transverse version. You can see it in the torque. The 2nd gen has about 25 more hp than the 1st gen. The 2019 Edge ST has the same power as the 2015-18 sport.
Most of the colors can be found on other vehicles like Explorer which should be in stock at dealers now with pics.
You can see them all here. https://www.ford.com/suvs-crossovers/edge/?gnav=header-all-vehicles
Pretty sure both are RWD just with different size battery packs. Longest range should be 300. The smaller battery pack is probably 150-200 miles. Also heard rumors of a high performance AWD version with multiple motors.
Adding Trailer Hitch and Wirng to 2015 Edge SEL
akirby replied to Dmtaurus's topic in Cargo, Hauling, Roof Racks & Towing
The factory produces about 250K vehicles per year which includes Edge, Nautilus and the soon to be discontinued MKT and Flex. Edge is around 140K plus Nautilus at 30K (US sales) plus Canadian sales plus European exports so yes, they do make at least 200K vehicles. But that was just an example. Multiply that by all of Ford's vehicles and the savings are staggering. -
They didn’t really start calling it sync 2 until sync 3 came out. It was somewhat confusing.
Technically MyFordTouch is still Sync (Sync 2 to be precise). I think he's installing MyFordTouch but has a problem with the version shown versus what he updated.
Well even if they only save $10/vehicle not running the extra wiring that's a couple million bucks a year savings. I think most people who want a hitch get the factory option. I would normally have ordered but didn't want to wait and the one vehicle we found within 90 miles that we liked didn't have it, so I added one to our 16 MKX (hidden hitch - which is no longer offered - it tucks up under the bumper so all you see is the receiver) with the Curt (I think) wiring harness. I only used it to pull a small utility trailer a few times so I tapped into the rear power point and plugged into the factory taillights. It would be a lot easier if they'd leave the wiring - at least on the upper models. Call it tow pkg prep. Easier to bury the price on Titaniums and Reserves. -
Ah I see now. So you want to play your guitar using the car stereo as the amplifier. Doesn’t that make it pretty hard to steer? A Bluetooth adapter is probably the best solution but the delay might be a problem.
Those adapters will work with sync 3. what exactly are you trying to connect? There may be other options. Here is a comprehensive discussion on options from the f150 forum. https://www.f150forum.com/f118/no-longer-have-3-5mm-line-now-what-do-i-do-350965/index10/
Exactly. It's the fans. Very common problem.
No but there are different ones for AWD vs FWD. This might help:
In that case it's almost certainly the fans. With the engine running put A/C on Max and both fans should be on. If not replace the fan and controller as a unit with Motorcraft parts (not Dorman).
Put flex fuel (e55-e85) in my EcoBoost 2.0, should I worry???
akirby replied to DrivingofftheEdge's topic in 2.0L EcoBoost
Dropping the tank might be the only way. How much is in it now? If it's a half tank or less you might be able to fill it up with pure gasoline and dilute it enough to get by and do it again at 3/4 tank. But use pure gasoline not E10. Octane isn't the problem - ethanol has a lot higher octane than E-10. -
The clutch on the rear diff is electronically engaged via the solenoid when rear torque is needed. I'm not sure if anything else in the FWD drivetrain is connected to the PTU. If not then removing the gears and driveshaft seems like it would work. But if you're going to do that much work why not put in a new PTU yourself, add a drain and change the fluid regularly? Should be a lot less than $1500.
Lost keypad entry code
akirby replied to jhenkin's topic in Alarms, Keyless Entry, Locks & Remote Start
You can’t change the factory code - only add additional codes. You need 2 keys anyway - go get another one and you can get the factory code. -
It is not based on any existing vehicle platform - it’s a new dedicated BEV platform. Expect sub 4 second 0-60 performance with handling to match.
2018 - 2019 Edge Key Fob programming
akirby replied to tk2fast's topic in Alarms, Keyless Entry, Locks & Remote Start
Of course not. That defeats the purpose, which is to prevent someone unauthorized (a valet, a mechanic, a thief who has one key) from making a duplicate fob. Only the owner would have two different fobs so that makes it reasonably sure that you're the owner or at least authorized to make a 3rd fob. -
NO paddle shifters on the 2019 Edge FWD... WHAT??
akirby replied to tk2fast's topic in Transaxle (FWD)
Is the FCA in auto mode or manual mode? Is the edge in Sport mode auto? -
No way around paying a dealer or a locksmith with a Ford diagnostic computer. -
Actually it engages the brake on the spinning wheel AND cuts torque if necessary.
